Thread Tools Search this Thread Rating: Thread Rating: 130 votes, 5.00 average. Display Modes
Old 01-05-2013, 10:50 AM   #201
Pocket Rocket
My Ride: 1999 323i
I have a 99 323i with a rebuilt GM trans ($4000) installed by local indy (no local dealer) about 50k ago. It had been ok until a recent trip. I was about 500 miles from home and parked on uphill incline with with the engine running while I checked out of a hotel. When I departed onto the street I noticed it was slipping so I turned off into the first available lot. By then it wasn't slipping anymore.I did a quick visual and did see fluid dripping under the car or smell anything (what else can you check?) If I had been near home I would have had it towed in but since I was 500 miles from home, it was Sunday and I had my daughter with me I started driving again, all seemed normal. Then it happened again, about a month and 2500 miles later. This time, in front of my house, again the car had sat idling for a few minutes, this time with one side up on the sidewalk and the other wheels on the street, so about 6" out of level. Again it started slipping when I took off. So straight back into the garage and parked. Drained the fluid, about 6 qts. and it looked clean. When I dropped the pan the filter came down with it, I didn't have to pull it off the tranny. Could that be the problem? I plan to finish the service and see what happens.
Pocket Rocket is offline   Reply With Quote
Old 01-06-2013, 09:21 AM   #202
Pocket Rocket
My Ride: 1999 323i
So I did the filter and fluid change per the DYI. The filler plug was a bear, I ended up dropping the cross member right behind the trans (easy) and that allowed access with a 45 torx and 3/8 breaker bar with cheater pipe. I used some heat from a propane torch as well in case they used something like red loctite. The old filter dropped down with the pan and further investigation showed that it was a sloppy fit into the old seal that was still up in the tranny. That and there was only one of the orange seals instead of two like the new filter came with. I'm hoping that was the source of my problem. The new filter and seals required a firm push to install and is a nice tight fit. Refilled with Valvoline Import Full Synthetic, it took about 6.5 qt to fill. I did an oil change while I was at it since it was nearly time and the car was all jacked up and warmed up. Test drove it and it shifted normally but since it was an intermittant problem I won't know if the problem is solved. I plan to drain an fill the fluid again soon so I get a more complete change but I won't do it on the garage floor next time!
BTW one of the local parts stores (O'Rielly's) had the filter/gasket/seals in stock for $ 29.00
Old 01-06-2013, 09:42 AM   #203
7xWDC-MSC
My Ride: 2005 325xi
Originally Posted by Pocket Rocket View Post
So I did the filter and fluid change per the DYI. The filler plug was a bear, I ended up dropping the cross member right behind the trans (easy) and that allowed access with a 45 torx and 3/8 breaker bar with cheater pipe. I used some heat from a propane torch as well in case they used something like red loctite. The old filter dropped down with the pan and further investigation showed that it was a sloppy fit into the old seal that was still up in the tranny. That and there was only one of the orange seals instead of two like the new filter came with. I'm hoping that was the source of my problem. The new filter and seals required a firm push to install and is a nice tight fit. Refilled with Valvoline Import Dexron VI. I did an oil change while I was at it since it was nearly time and the car was all jacked up and warmed up. Test drove it and it shifted normally but since it was an intermittant problem I won't know if the problem is solved. I plan to drain an fill the fluid again soon so I get a more complete change but I won't do it on the garage floor next time!
Keep us up to date as to if it fixed the issue, I can tell you the filter should not drop with the pan, and with it missing an o-ring you said you were probably sucking air through the neck. Shame on the shop though for making that mistake.
The drain and fill plugs shouldn't be that tight, it's something like a 22 ft lb spec IIRC. Mine were cemented in place from age but I could still break them free with a regular 3/8 ratchet.
7xWDC-MSC is offline   Reply With Quote
Old 01-06-2013, 09:57 AM   #204
Pocket Rocket
My Ride: 1999 323i
Will do. I'm pretty bummed about the filter not being installed correctly. It was rebuilt by a tranny shop in Phoenix. The local independent shop recommended it and did the install, I don't know who did the original fill.
The tight fill plug issue is apparently common judging by the posts on the forum. Mine was very stuck, just as if red loctite had been use, it came loose with a snap. Luckily I had read all the woes of others and was prepared.
Old 01-06-2013, 10:45 PM   #205
Starless
My Ride: 02' 325i
Bad news for you. The old filter always comes out with 1 orange gasket, the other half is just stuck inside the hole and you must get it out. If you did not, your new filter installation is incorrect and will cause problems.
Starless is offline   Reply With Quote
Old 01-13-2013, 12:10 PM   #206
Pocket Rocket
My Ride: 1999 323i
The old filter came out with no orange seal on it and one stuck up in the tranny. The new one has two seals. Been driving a week now and it seems to be fixed, at least I can't replicate the failure. Also goes right into reverse now as opposed to the 1-2 sec delay it used to have on the first engagement of the day. So far so good. Not so good on the rebuild shop's part.
Old 01-13-2013, 04:28 PM   #207
7xWDC-MSC
My Ride: 2005 325xi
I'm glad that solved your problem and its a good thing you caught it before any permanent damage occurred. Again though shame on that trans shop.
Rubs the roundel on its skin or else it gets the hose again.
Old 01-17-2013, 01:17 AM   #208
Pocket Rocket
My Ride: 1999 323i
+1 on the libs. Former Masshole here but long ago.
Old 03-17-2013, 02:23 PM   #209
NCLee
My Ride: 2004 330xi
Send a message via AIM to NCLee
Thanks for the writeup!
I just finished this on my 2004 330xi. It appears the xi may be a little different: the fill plug is a 17mm hex bolt, instead of a T45, and it's on the side next to the drain plug. If you look up the 330xi and then the 330i on penskeparts.com (or presumably any other site with the parts fiche), you'll see that the diagram is the same, but only some of the parts are included in the parts list.
On the 330xi, you'll see item #10 in the list is shown as "SCREW PLUG, OUTER HEXAGON", part no. 24 11 7 507 787.
The 330i has listed as #9 "SCREW PLUG, INNER HEXAGON (from 03/03)", part no. 24 11 7 533 656.
The 330xi diagram has no #9 listed, and the 330i has no #10 listed.
I don't know why they are different - all the other parts of the job appear to be the same!
When I do this again, I am going to replace the drain and fill plugs completely, since their rubber gaskets are built in. I'd rather replace them knowing I have all-new gaskets.
Update: I just took the car for a drive, and WOW! The shifts are amazingly smooth. I can't even feel the shifts from 1-2 and 2-3. There is a slight bump from 3-4, and then 4-5 is extremely smooth as well. Is this my imagination, or can the fluid really make the shifts better? What is it about the new fluid that can help the feel?
What I've learned so far:
  • don't start working on the car unless you have a ride to the parts shop.
  • whatever you're doing, Mango's guide is probably right.
  • the Bentley manual skips steps. LOTS of them. Don't tear your hair out when the next step makes no sense.
NCLee is offline   Reply With Quote
Old 04-07-2013, 09:47 AM   #210
new61n
My Ride: 2005, 325CI
Originally Posted by swordsman11868 View Post
I think you are asking should you change the fluid after 178k miles?
I would say yes but be sure you do the procedure correctly. Any mistakes you make could easily cause the trans to fail.
If you are not 100% confident you can do the job just take it to a reputable BMW shop and have them do it. They will most likely not guarantee the work based on the mileage but your current trans fluid is way past being effective, i.e. it's filthy and like water.
If you do take it to a shop, I would NOT recommend doing a pressurized "flush", but just have them drop the pan, change the filter, and refill with either Dex 4 or Dex 6, whichever they or you decide (I like RedLine brand but YMMV). Make sure they explain to you their procedure. Then check their procedure against what everyone on E46F says to do, just to be safe.
I'm not a mechanic so this is just my .02. GL with whatever you decide and keep us posted!
-Daniel
If he wants to use a different fluid to his OE fluid, wouldn't he need a flush so he won't mix the two fluid?
new61n is offline   Reply With Quote
Old 04-07-2013, 11:28 AM   #211
Mhnd
My Ride: 2004, 330XI
I just finished this on my 2004 330xi. It appears the xi may be a little different: the fill plug is a 17mm hex bolt, instead of a T45, and it's on the side next to the drain plug. If you look ?
I have the same car year and model, my car has 140k now. What type of Oil you used?
Thanks!
Mhnd is offline   Reply With Quote
Old 05-07-2013, 09:18 AM   #212
jasonsjwou
My Ride: E46, GMC Conversion.
I have 2001 325ci, with 120kmi. I'd like to do this tranny oil change, but would it be safe to do it?
jasonsjwou is offline   Reply With Quote
Old 05-07-2013, 09:33 AM   #213
Sansho
My Ride: 2001 325i
The fluid is only getting weaker as additives continue to break down over time. I would change the fluid and filter.
One of the potential issues discussed is that new fluid will cause chunks of goop in the transmission to come loose. If you subscribe to that, then replace with the same fluid that's in there today ... not something that's compatible. You can get ZF fluid or also source it from VW/Audi and other manufacturers. Sorry, I'm not familiar with fluids the GM transmissions use.
Sansho is offline   Reply With Quote
Old 05-07-2013, 09:59 AM   #214
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
You are safe to do it. It will do a tranny good.
Do a filter and fluid change.
Engine swaps, HG, GM & ZF tranny rebuilds.
Over 2 Billion Served !
BMWCaptainE46.com
BMWCaptain is offline   Reply With Quote
Old 05-07-2013, 10:27 AM   #215
jasonsjwou
Sansho, BMWCaptain, thank you for your reply.
How can I tell which transmission oil I need to be using?
Mine is a 2001 325ci (2000/Nov build), with S205A option code designated "Automatic Transmission".
Do I have ZF or GM transmission?
Old 05-07-2013, 01:17 PM   #216
BMWCaptain
Probably a ZF tranny. Need to look under your car to verify. There is a data plate on the side for GM and on the back for ZF. Look at your data plate for the brand.
BMWCaptainE46.com
Old 06-20-2013, 12:38 AM   #217
Rezist09
My Ride: 325i sedan
2001 325i sedan zf transmission
180k what fluid can I get where to buy?
Rezist09 is offline   Reply With Quote
Old 06-20-2013, 12:54 AM   #218
blkonblk
My Ride: 06/2000 330i ZSP/ZPP
Amsoil (dealer) or Pentosin (online). make sure it's compatible with LT 71141
Life is a journey not a destination, so enjoy the ride!
blkonblk is offline   Reply With Quote
Old 06-20-2013, 12:58 AM   #219
Rezist09
My Ride: 325i sedan
Thank you how many liters? Also where to get the filter
Old 06-20-2013, 01:34 AM   #220
blkonblk
I bought 7 quarts but only used 5.5 quarts. 1 gallon and 3 quarts from an independent Amsoil dealer for $9 a qt. Cheapest Pentosin online is about $16 a liter.
Filter and gasket from the dealer, I also replaced both drain and fill screw plugs.
