Thread Tools Search this Thread Rating: Thread Rating: 130 votes, 5.00 average. Display Modes
Old 02-17-2009, 06:19 PM   #81
floor-it
My Ride: 04 M3 CV Mystic Blue
Just had mine changed on '01 330i . 152k miles, fluid was black.
Not sure if anyone's mentioned this but, I found it real easy to remove the pan by putting the jack underneath it when lowering it down. It goes down slowly and u can control so that it doesnt splash all over.
Likewise when putting it back on, use the jack to lift it up and u can bolt on very easily & accurately.
Fleet:
10 X5d
04 M3 Mystic Blue Vert (sold)
03 530i Titanium Silver (sold)
02 Suzuka Blue S2000 (sold)
01 Red 330i (216k miles, rebuilt auto tranny @ 200k)
00 Silver S2000 (sold)
floor-it is offline   Reply With Quote
Old 02-17-2009, 11:58 PM   #82
dh0licious
My Ride: '00 325i
Was this your first atf change at 152k miles? If so, are you pleased with the change - so far so good?
dh0licious is offline   Reply With Quote
Old 02-18-2009, 01:14 AM   #83
floor-it
Yeah this is the car's first atf change since I bought it new! At first I thought the car shifted smoother, but then afterwards, it was all in my head The car seems to behave just like before. I'm planning to keep it for a long time, so it needed to be done anyway.
I drove it to the mt for snowboarding over the weekend and it performed just as normal, so far so good!
Fleet:
10 X5d
Old 02-18-2009, 01:54 AM   #84
dh0licious
My Ride: '00 325i
Cool. Did you go with the Redline atf? I plan to keep my car for ages too so i definetly want to do this. I'm at about 80k miles now.
Old 02-18-2009, 02:04 AM   #85
floor-it
I just started reading the DIY at http://www.bimmerfest.com/forums/sho...d.php?t=166135 and followed what he recommend: Valvoline mercon V. After the DIY, upon reading further, seems like there are some other fluids people are using. So i'm not sure what's the best fluid to use. But so far the Valvoline seems to perform without any hiccups at all.
Not sure if that helped ya! haha.
Fleet:
10 X5d
Old 02-19-2009, 12:39 PM   #86
walkabout
My Ride: 325xi
Hi,
Just found out that my local Chevy dealer is selling GM dexron VI for $8 per quart and if I bring my own bottle they will sell me $3 per quart
walkabout is offline   Reply With Quote
Old 05-09-2009, 12:49 AM   #87
GeorgeM
My Ride: 99 323
20,000 miles and shifting fine. GeorgeM
GeorgeM is offline   Reply With Quote
Old 06-01-2009, 05:06 PM   #88
jregnaud
My Ride: 330i 03'
when doing this dyi, do you have to have replacement bolts for the pan or can you reuse the previous ones?
jregnaud is offline   Reply With Quote
Old 06-07-2009, 04:46 PM   #89
muniz_ri
My Ride: 2004 325i
I reused the same bolts but added loctite to each bolt. It's been about 4K miles since the change with no leaks or loose bolts. Best of luck!
muniz_ri is offline   Reply With Quote
Old 06-20-2009, 02:02 PM   #90
jaydeep
My Ride: 02 330I,92 E30 Vert
Originally Posted by walkabout View Post
Hi,
Which GM dealer? I am in CT too and wnat to change fluid.
jaydeep is offline   Reply With Quote
Old 07-30-2009, 08:59 PM   #91
walkabout
My Ride: 325xi
Jaydeep,
GM dealer in Wallingford
Old 08-06-2009, 09:09 AM   #92
skang330
My Ride: 2005 E46 330ci
Send a message via AIM to skang330
Nice!
skang330 is offline   Reply With Quote
Old 12-27-2009, 03:49 PM   #93
jpainter187
My Ride: '99 E46
Hey guys,
I have a '99 323i and plan to flush the ATF once the weather gets a little warmer... I was looking for some fluid that isn't too expensive and found Castrol Import Multi-Vehicle ATF. It says on that back BMW LA2364 and LT71141 are one of the recommended uses. Will this be okay for my transmission?
jpainter187 is offline   Reply With Quote
Old 12-27-2009, 06:54 PM   #94
33beto
My Ride: 08 328i Sedan(R.I.P)
Send a message via AIM to 33beto
Most likely is a GM tranny, so any dexron 6 will do.
33beto is offline   Reply With Quote
Old 12-27-2009, 09:10 PM   #95
jpainter187
My Ride: '99 E46
Well, I did a little more searching and have found others that have used this. But it says towards the bottom that it is not to be used for any transmission that requires Dextron VI. From what I've read, Anything that meets Dextron V is acceptable, correct? These are the recommended uses from Castrols website:
* Recommended for use in vehicles that require:
o Honda, Acura — ATF–Z1 (except in CVTs)
o Toyota, Lexus — Type T, T–III, T–IV
o Nissan, Infiniti — Matic–D, Matic–J
o BMW — LA2634, LT71141
o Mitsubishi — Diamond SP–II, SP–III
o Hyundai — SP–II, SP–III
o Volvo
Import Multi-Vehicle bottle
* Also meets requirements of
o ATF+3®, ATF+2®, ATF+®
o Ford MERCON®, MERCON® V (Not for use where MERCON® SP is required).
o General Motors DEXRON®–III H and prior (Not for use where DEXRON®–VI is required).
o Allison C–4
Old 12-27-2009, 09:30 PM   #96
John in VA
My Ride: 328i/325xi
If you want to do it properly, get the correct Texaco fluid:
http://forum.e46fanatics.com/showthr...250&highlight=
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 02-21-2010, 05:45 AM   #97
Nachos23
My Ride: 2009 335Xi Sedan
Send a message via MSN to Nachos23
Hey Guys;
Have been considering doing the flush, BUT, my 04 330Xi has 220,000km (137,000m) and is running original factory ATF. I've been warned about doing this flush with the milage on my tranny...... The basis for the warning is that considering the milage, removing/cleaning the "gunk" out may actually cause the tranny to stop working.... This advice comes from a high-respected friend who owns his own indy that services, BMW, Merecedes and Ferrari's. I had purchsed the kit last summer and mentioned to him what I was going to do and he STRONGLY recommended NOT doing the flush. He said that considering the number of issues they've had with no reverse or similar issues after changing the fluid on high milage BMW ATs, they NO LONGER will perform that service for clients.
My tranny is functioning correctly. It shifts fine (although a little slower than I'd like; possibly design??) and generally works ok!! Thoughts?
Also, has anyone upgraded their AT cooler? I'm considering Supercharging the car, but am concerned about AT over-heating (most common cause of AT failure in FI cars). Thinking an upgraded AT cooler would provide sufficient cooling to avoid that issue.... Thoughts?
My Rides:
2009 335i Xdrive
2000 Z3M Roadster
Nachos23 is offline   Reply With Quote
Old 02-21-2010, 08:46 AM   #98
33beto
Dont do it man. It will do more harm than good. already too many miles.
Supercharging is for stick trannys. Automatics are not strong enuff for the extra torque and stress a blower will put on a daily basis unless you lower the boost to less than 6 lbs which in my opinion would defeat the purpose.
Just my 02/cts.
Old 02-21-2010, 02:08 PM   #99
muniz_ri
My Ride: 2004 325i
Originally Posted by Nachos23 View Post
Hey Guys;
If it were my car I would change the fluid and filter, drive it for maybe ~2K miles and do it again to get rid of any loose gunk. If you don't plan on keeping the car much longer, then I wouldn't do anything, but what you have in the tranny right now is a black slurry of abrasive ATF.
Old 06-13-2010, 03:51 PM   #100
wardpower
My Ride: 99' 328i Sedan
I just did this DIY, great write up. Car shifts better, though not that much difference. I needed to do it because my transmission pan gasket was leaking. Now I'll have to wait and see if it leaks anymore. I bought Texaco 7045 ATF from the stealership and got robbed.
wardpower is offline   Reply With Quote
