Old 05-06-2002, 02:57 AM   #1
Salazar
My Ride: 323ci
Send a message via AIM to Salazar
Questions on system
Ok this summer I am planning on purchasing two JL w3 12's in a bandpass and sticking it in my trunk and I just have a couple questions on certain issues on it:
1 - If i had this system installed would it be able to work with the stock Bmw Business Cd deck that came with the car??
2 - If i indeed had to install a new deck to replace it, do you think it would touch any warranty issues??
Thx for taking ur time to read this and i hope somebody can help me with this dilema :smile:
Salazar is offline   Reply With Quote
Old 05-06-2002, 03:03 AM   #2
mcabr
Just Marinatin'
mcabr's Avatar
My Ride: Chikatetsu
First
It will work with the stock cd player. My girl has that set up. You just have to get the adapter to plug into one of the speaker output wires. The problem with that is that when you do this you dont' get as clean of a signal. More like sometimes it is not that loud. I would say definietly get the aftermarket stereo. That is what I did and my system sounds 10x better than hers. It doesn't touch on any warranty issues as long as you are slick about it. Have BMW do it just do it yourself and take it to a dealership and tell them that another dealer did it. They will never know the difference.
mcabr is offline   Reply With Quote
Old 05-06-2002, 03:07 AM   #3
bender
hammer talks like this
My Ride: 2006 Honda insight
Send a message via AIM to bender
You can keep your stock deck, I would recommend doing an EQ though... You have to use line out adapters to use the factory radio to run amps. they basically give the stock radio RCA outputs. When you do that, you don't get a lot of voltage going through the RCA's. By adding an EQ you get around 4-6 volts. I personally like JL's in a sealed enclosure, unless you have a badass custom installer....It wont mess up any warranty...
bender is offline   Reply With Quote
Old 05-06-2002, 03:16 AM   #4
Salazar
My Ride: 323ci
hey wut kind of aftermarket decks do you guys have?? the lcd??
Old 05-06-2002, 03:18 AM   #5
bender
I have a kenwood currently...I'm gonna swap for an alpine cda 7894 soon.
Name:	a_w indash.jpg
Old 05-06-2002, 03:39 AM   #6
mcabr
Just Marinatin'
mcabr's Avatar
My Ride: Chikatetsu
I have a panasonic
It has dual inputs for cd and md both in a single din deck. I am going to get that new alpine cda-7998. I want a screen but I just figured naaaah.
