Thread Tools Search this Thread Rating: Thread Rating: 66 votes, 4.70 average. Display Modes
Old 05-12-2008, 10:16 PM   #21
rix617
My Ride: '01 325i // '02 X5
take off the pulleys and see what they look like. if it looks like the one on the left, its mechanical, the right one is from hydraulic.
rix617 is offline   Reply With Quote
Old 05-13-2008, 03:16 AM   #22
ssm1991
My Ride: 2004 325i
Originally Posted by NickD View Post
Is there an easy way to know if you have a hydraulic or mechanical tensioner without getting down in there? I have 120k on my pullies and oddly none of them are making any sound as of yet. I am doing my water pump soon and figured I'd replace these as well.
The photo in the OP is the mechanical tensioner.
You can't get a replacement pulley for the mechanical tensioner anyway. There's no part number for it hence BMW doesn't sell it. You'd have to buy the whole hydraulic set if you want to change it.
For the hydraulic tensioner, the pulley is replaceable (11-28-1-748-131).
ssm1991 is offline   Reply With Quote
Old 05-13-2008, 06:23 AM   #23
NickD
My Ride: 1999 328i
Thanks for the great info guys! I'll have to go check this evening and get the rest of the parts ordered
NickD is offline   Reply With Quote
Old 05-13-2008, 12:19 PM   #24
jmueller
My Ride: 2001 330ci
You have to buy the whole mechanical set if you want to change it not the hydraulic set
jmueller is offline   Reply With Quote
Old 05-20-2008, 10:03 AM   #25
NickD
My Ride: 1999 328i
What exactly does the tensioner "squeal" sound like? In my car when the engine revs it has a sort of turbine-like sound. This just started recently.
Old 07-01-2008, 12:23 PM   #26
kp1pbr
My Ride: BMW 325i
Light buzzing squeeling noise
Hi, I just had my belt tensioners and belts replaced. Everytime I start up the car I hear a slight buzzing/squeeling noise. This noise also happens at idle too. Is this possibly the belt tensioners? Are they too tight and need to be adjusted? The other thing I was thinking that it could be the alternator failing but a voltage test was run and all checked out ok. But if the coils in the alternator are failing it may be making the noise. Anyone any inputs on tweeking or adjusting the tensioners? Or could it be the belts themselves?
kp1pbr is offline   Reply With Quote
Old 07-22-2008, 06:23 PM   #27
zactastic
My Ride: Merlin nonfixed gear
Send a message via AIM to zactastic
I have the belts to change them out... but before i start, do you know what foot pounds of torque i should be using while in there? or should i just tighten without the torque wrench?
-Zach
"There is science, logic, reason; there is thought verified by experience. And then there is California." -Edward Abbey
"Learning from experience is a faculty almost never practiced." -Barbara Tuchman
...the mod bug got me and my Alpine 330ci;there's a list somewhere...
zactastic is offline   Reply With Quote
Old 07-22-2008, 09:46 PM   #28
Trade Marked
My Ride: Needs New Shoes
Is this job going to fix this noise(in video)? Im 99% sure is coming from the pullies or the tensioner/ belt area. Advice is needed!!! Thanks
- Ryan -
Trade Marked is offline   Reply With Quote
Old 07-23-2008, 12:03 AM   #29
Trade Marked
Bump anyone
- Ryan -
Old 07-24-2008, 12:02 PM   #30
Trade Marked
Bumpity someone
- Ryan -
Old 07-24-2008, 12:08 PM   #31
zactastic
wish i could help you with that man. when was the last time you changed your belts? some suggests changing the mechanical tensioner if they need it when you're in there. i changed both belts yesterday. its an easy DIY: http://forum.e46fanatics.com/showthr...ight=belts+diy
-Zach
Old 07-24-2008, 12:20 PM   #32
Trade Marked
Belts and pullies were replaced no more than 2 months ago. Thats why i figured it was a tensioner or maybe a bearing
- Ryan -
Old 07-24-2008, 04:20 PM   #33
zactastic
if its really annoying and you think its obviously an issue that you cant resolve... ask a mechanic to inspect the noise... should be free. but some might charge you. good luck
-Zach
Old 07-25-2008, 05:48 PM   #34
FLAT_FOOT
My Ride: L3MANS
Send a message via AIM to FLAT_FOOT
I have the same noise...had my mechanic to take a look at it and said I need the belt change..the idle pulley and the belt tensioner...
never heard of Idle pulley...is that the same as deflection?
I go to RealOem...and see 2 different pulley. Adjusting and Deflection....could the adjust pulley be the problem as well?
http://www.mybannermaker.com/link.php?nurl=http%3A%2F%2Fwww.mybannermaker.com%2F][IMG]http://img238.imageshack.us/img238/6656/mybanner4908a36d1f0abir8.jpg
6 Feet Under!....
to be continued......
FLAT_FOOT is offline   Reply With Quote
Old 07-26-2008, 10:38 AM   #35
FLAT_FOOT
My Ride: L3MANS
6 Feet Under!....
Old 11-11-2008, 04:45 PM   #36
steve.325i
My Ride: 2003 325i
Belt tensioner& pulley OEM manufacturer
Hi, can anyone recommend or tell me if the manufacturer matters or if they the quality of the tensioners & pullys I am looking at are all the same?
I live in Canada so I preference would be to order from www.autopartsway.ca with their free shiping over $75.
Any other suggestions are welcome.
mfg: INA
www.bimmerspecialist.com/canada/parts/product_details/11281427252
mfg: ?
http://www.autopartsway.ca/autoparts...20Sedan~241030
mfg: Ruville
http://catalog.worldpac.com/marks/wi...Tension+Pulley
steve.325i is offline   Reply With Quote
Old 11-12-2008, 07:06 PM   #37
K:^P
My Ride: 00 323//65 Fastback
I bought Ruville. I believe it's OEM replacement.
K:^P is offline   Reply With Quote
Old 11-17-2008, 10:28 PM   #38
steve.325i
My Ride: 2003 325i
Thanks, I ordered the Ruville parts.
Old 11-18-2008, 11:48 PM   #39
SMBMW332is
My Ride: 00 328i, 95 332is
Thanks for this DIY, I need to replace the drive belt on my new E46 and I'm still waiting for the Bentley manual to show up.
SMBMW332is is offline   Reply With Quote
Old 12-04-2008, 03:23 PM   #40
ras2247
My Ride: 2003 330i
Is this any different in an auto?
ras2247 is offline   Reply With Quote
