Old 02-02-2007, 01:56 PM   #1
jyeh74
My Ride: 325i
license plate lights (LED) stay on
Hey guys,
I bought the 6 led festoon bulbs (39 mm) from superbrightleds.com and I noticed that the lights stay on even when I dont have my headlights on......do u guys experience this? Is there somethnig wit hthe led that triggers it to stay on?
jyeh74 is offline   Reply With Quote
Old 02-02-2007, 02:53 PM   #2
barchetta316
My Ride: 04 //M3
Send a message via AIM to barchetta316
Originally Posted by jyeh74 View Post
Hey guys,
I bought mine from autolumination.com and mine stay on to but then turn off. When i open my trunk they come on its weird.
barchetta316 is offline   Reply With Quote
Old 02-02-2007, 02:58 PM   #3
afx twin
My Ride: 2006 M3
i believe it has something to do with the fact that LEDs are way more sensitive to voltage than regular filament bulbs. our cars send out electrical pulses to check all the bulbs and it just happens to be that LEDs are sensitive enough to pic up this current and turn on. they do turn off though, once the system ecu shuts off.
afx twin is offline   Reply With Quote
Old 02-02-2007, 05:59 PM   #4
Bowser330
My Ride: 2004 330ci
right on.
mine stay on, although one side is stronger, but still dim, after i turn my car off. Once the ECU powers down though...they should go out. If they dont and stay on, then i would say thats cool as hell. ....say you park in a not so good area, with the LEDs on you might detour some would be car vandals, plus, they dont consume enough power to drain your battery significantly anyway, so win win.
Bowser330 is offline   Reply With Quote
Old 02-02-2007, 06:05 PM   #5
jyeh74
My Ride: 325i
i'll reinstall it and see if it stays on. how long is it suppose to last before they automatically turn off?
Old 02-02-2007, 07:23 PM   #6
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
I think this is why the LEDs burn out so fast. Every time you turn off your car they're still on for a while until the car shuts them off automatically
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 02-03-2007, 12:31 AM   #7
HighVoltage
My Ride: 2007 335i
Considering the relatively long lifespan on a typical led, this seems unlikely. The more probable scenario is that the leds are being overdriven either in forward baised or reverse biased condition. The later of which typically vastly accelerates premature failure with repsect to the prior.
HighVoltage is offline   Reply With Quote
Old 02-03-2007, 01:47 AM   #8
BimmerZealot
My Ride: N/A
Mine stay on but are MUCH dimmer then when actually on. Dim enough to not be noticeable unless you look under the trunk handle.
BimmerZealot is offline   Reply With Quote
Old 02-04-2007, 05:03 AM   #9
jyeh74
My Ride: 325i
BimmerZealot, how long do they stay on? Some people say it dstays on from 2-5 mins after. I wonder why...............
Old 02-04-2007, 02:50 PM   #10
BimmerZealot
My Ride: N/A
Under or around 1 min
Old 02-04-2007, 03:55 PM   #11
BMWPower06
BMWPower06's Avatar
My Ride: ///M5 & ///M3
Send a message via AIM to BMWPower06
my LED fender markers are the same way, they usually stay on for a couple minutes after i turn off the car
Current: E60 M5 6MT; E46 M3 6MT
Sold: E46 330CiA; E36 M3/2/5; E60 M5 SMG
DD: B8.5 Audi S4 6MT
BMWPower06 is offline   Reply With Quote
Old 02-17-2007, 06:42 PM   #12
jyeh74
My Ride: 325i
for some weird reason, when i changed my interior lights to led, the courtesy ones that come on dont work. I checked the fuses and they are all good. These are the two in the rear, the one in the front and the two by the foot on driver and passenger side. These courtesy lights don't work anymore. I tried replacing them back to the orginal halogens ones, and it still doesn't work. I thought I could have turned them off by hitting the middle light in the front for 3 seconds, but it doesnt turn back on. Anyone have any suggestions? I know the dealer is going to charge a grip for this if it's a wiring issue.
