Go Back   E46Fanatics > E46 BMW > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 4.71 average.
Old 02-15-2010, 06:37 PM   #20161
IB RearWheelin
My Ride: Rental...for now.
Originally Posted by bpalm004 View Post
The moderator said it's the same IP address??
Did the guy who pose as you also use the same computer as you???
I'm not trying to bash you I'm just trying to clarify this on your behalf. I'm sure you don't want another situation like before to happen again.
it can't possibly be the same internet provider address...i have a macintosh laptop running off of WIFI.
Originally Posted by nike001 View Post
Is this a joke? Do you really have so much money, you don't know what to do with it?
IB RearWheelin is offline   Reply With Quote
Old 02-15-2010, 08:02 PM   #20162
zx5rider
My Ride: TT Turbo 2003 330i
Send a message via AIM to zx5rider
I might have one you can have.
How do you get your signature to be that big?
I use a large picture but I always get stuck with a small azz sig.
Ok if u go shoot me a msg....about the sig my pics are linked from photobucket i'm guessing you just upload yours to e46?
Technique Tuning Turbo Stage 2|Magnaflow Catback|Tein Super Street|EAS Eagle Eyes Tail Lights|3500k Fogs|ATR CF Power Buldge Hood|BMW Performance CF Strut Bar|Dynavin V5|Infinity Reference all around
2011 BMW S1000rr
zx5rider is online now   Reply With Quote
Old 02-15-2010, 08:05 PM   #20163
zx5rider
I'm nou sure what yall are talking about but 2 computers using the same internet connection will have the same IP outside.
2011 BMW S1000rr
Old 02-15-2010, 08:07 PM   #20164
IB RearWheelin
my WIFI. same IP for everyone using the main source for internet. it's possible the pipes guy and I are using the same wifi source. he's my neighboor.
Old 02-15-2010, 08:11 PM   #20165
Swish
My Ride: 2004 M3 Vert
"If you want to move past racism, you have to STOP LABELING EVERYTHING BY RACE / 2000_328CI"
Swish is offline   Reply With Quote
Old 02-15-2010, 08:58 PM   #20166
hcaleman
My Ride: E36 M3
Originally Posted by das BENZin View Post
Is the vibration when you brake or all the time? Does the steering wheel vibrate or does it saw back and forth?
It's odd as it's not all the time. I first noticed it a week or so ago but it wasn't very pronounced and then went away. Today it came back with a fuy, very strong vibration through the steering wheel at 35 and higher. Pulsing in the brake pedal and chugging to slow down. I thought it could possibly be a bent wheel or completely screwed wheel bearing.
Got home and put the front end up in the air and checked both sides for play in the wheel bearings, they checked out fine. Driver's side spins freely, but passenger side definitely drags on part of the rotor. I also noticed the pass side had a lot more brake dust built up on it.
I have new pads, rotors, and caliper rebuild coming from bimmerworld so should be here by wednesday. I need to go pick up some new guide bushings too and might as well just get a set of SS brake lines while I'm in there.
Odd though after I put the wheels back on and took it for a drive around the block the pulsing was gone, I may be more of an issue when it gets up to temp, I'll see tomorrow on my drive to work
hcaleman is offline   Reply With Quote
Old 02-15-2010, 09:00 PM   #20167
hcaleman
My Ride: E36 M3
Cozilla, you still need the RTAB tool? I cut a new length of threaded stock for it today to replace the one I bent slightly. It's ready to use.
Old 02-15-2010, 09:03 PM   #20168
robb1887
My Ride: 3rdgen 4Runner
I also have a few from when I put in 'locking' bolts... if he cant manage to find one. You've been to my place before to look at your amps, so its not that hard to find if you wanted to swing by and grab one
robb1887 is offline   Reply With Quote
Old 02-15-2010, 09:32 PM   #20169
das BENZin
My Ride: 1985 380SE 5.6
Well, on my brother's e39 similar symptoms turned out to be a cracked thrust bearing. 2 dealerships missed it. Whenever the bearing would rotate so that the crack was in a certain spot you'd get a massive vibration, near that spot a minor vibration, and far away from that spot almost no vibration.
das BENZin is offline   Reply With Quote
Old 02-15-2010, 09:47 PM   #20170
IB RearWheelin
Old 02-15-2010, 10:07 PM   #20171
robb1887
Thats called the resonance frequency... haha, just took a class on vibrations not trying to joke.
Ohh Snik, I was thinking the other day about your rear shock replacement/system removal issues, and then realized that when I replaced my RSM's I went with RE's and they mount inside the wheel well so I dont have to be in my trunk anymore to replace my shocks... might be a good idea to pick a set up now to replace yours so you dont have this issue again. See below.
http://www.rogueengineering.com/Merc...Category_Code=
I can show you mine, if you cant quite see whats going on. Makes swapping out your shocks stupid quick. YAY Mcpherson struts haha
Old 02-15-2010, 11:26 PM   #20172
Snik
Snik's Avatar
My Ride: IR M3 Vert.
oh ive already figured it out bro, theyre GC RSMs, and all i have to do is unscrew the bottom nuts and it all pulls right out. No need to replace anything on the mount.
Shocks are on the way, Ruben shouldve shipped em today
Mcpherson struts? those are up front.
Stuff for sale!!!!!
Do you ride a sportbike?
Old 02-16-2010, 12:36 AM   #20173
Snik
Snik's Avatar
Stuff for sale!!!!!
Old 02-16-2010, 12:36 AM   #20174
Snik
Snik's Avatar
Stuff for sale!!!!!
Old 02-16-2010, 12:38 AM   #20175
Snik
Snik's Avatar
Stuff for sale!!!!!
Old 02-16-2010, 12:39 AM   #20176
Snik
Snik's Avatar
Stuff for sale!!!!!
Old 02-16-2010, 12:46 AM   #20177
Snik
Snik's Avatar
new F10 5er. Looking proper
Stuff for sale!!!!!
Old 02-16-2010, 12:47 AM   #20178
Snik
Snik's Avatar
Stuff for sale!!!!!
Old 02-16-2010, 12:49 AM   #20179
IB RearWheelin
bad azz interior. thats what I adore most. leather and woodgrain.
but good lord...talk about quickFAST shutter speed. brilliant shots
Old 02-16-2010, 01:08 AM   #20180
bpalm004
My Ride: E36 M3 Sedan
Looks like I'm pulling an all-nighter with this huge ass project...
bpalm004 is offline   Reply With Quote
Rate This Thread
