Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Thread Tools Search this Thread Rating: Thread Rating: 120 votes, 4.96 average.
Old 04-15-2010, 12:31 AM   #23101
idriveane34
My Ride: kills bugs
Originally Posted by snikwad View Post
Cory, if they're E39 fitment, its easy. Contact one of these vendors and tell them u need E39 - E34 hubcentric rings. They're not cheap tho from what I've seen. However, u could get hubcentric spacers more poke your hubs are 72.3mm I believe, and E39s are 74.6mm or something like that. Can't remember th actual numbers. Don't by plastic rings, they're cheap, but they don't last, the crack and fall apart. Need metal rings.
already got metal rings. they were cheap. the guys on the forum directed me to a great seller on ebay... from where they get their hub rings. apparently it's not uncommon. the e39 is the only bmw that has a different hub bore, iirc.
shhhh....
idriveane34 is offline   Reply With Quote
Old 04-15-2010, 12:38 AM   #23102
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Yep. E39s have bigger hubs for god knows why. And I don't think they ever did that again.
Do you ride a sportbike?
Old 04-15-2010, 12:41 AM   #23103
Snik
Snik's Avatar
That's why all them jokers on E39 style 5s every now and then you hear one saying they ride crappy and sh1t.
Old 04-15-2010, 12:44 AM   #23104
idriveane34
My Ride: kills bugs
most ridiculous thing (besides pigging out the bodies on the new ones) bmw ever did.
shhhh....
Old 04-15-2010, 12:51 AM   #23105
robb1887
My Ride: 00 Mshoe
... ughh... anyone wanna roll with me saturday to the ODU meet thing?
robb1887 is offline   Reply With Quote
Old 04-15-2010, 02:16 AM   #23106
Snik
Snik's Avatar
Not it, got softball and bbq with my scooter club, and work that night too. Cory, you watch your mouth about the newer body styles.
Old 04-15-2010, 07:25 AM   #23107
Focal E46
My Ride: is a DIYer
Originally Posted by bimmerfan08 View Post
Hey quick question for you guys, I need to replace my two rear tires soon, since I do alot of backroad driving theyre pretty worn down. The fronts are fine, Id say they have about 70% tread life remaining. So Im looking at two used tires to replace the rears before I sell it. My question is: Can I run a 235/45/17 in the rear or should I stick with a square set up of 225/45/17 all the way around as they are now (all the rims are 8" rims)? I found some 235's of my tires for a good price. Thanks
Yep, I'm running a squared setup with wider tires in the rear. I'm not sure how wide of a tire you can go on an 8" rim though. I have 225's on my stockers and they look like I can probably put 235's but not sure.
Focal E46 is offline   Reply With Quote
Old 04-15-2010, 08:46 AM   #23108
cozilla
My Ride: 2002 M3
Hey guys here is a teaser of the rear that I did last night. This project is super easy. Ill take a pic of my paint booth too and of me doing the front tonight if you want.
sig by roddykaregaran
cozilla is offline   Reply With Quote
Old 04-15-2010, 08:49 AM   #23109
Focal E46
My Ride: is a DIYer
Looks good! I thought you were going to do the inner part. How's the texture after the paint?
Old 04-15-2010, 08:50 AM   #23110
cozilla
My Ride: 2002 M3
Texture feels just like a regular door panel did alot of light coats. I ultimately want to dye the leather parts to cinnamon or imola.
Looking for this outcome for the time being http://forum.e46fanatics.com/showpos...7&postcount=37
Old 04-15-2010, 09:45 AM   #23111
jwm5
My Ride: station wagon
you should be fine running 235/45/17 compared to the stock 225/45 they will be slightly taller, but by such a small amount that it wont matter.
I run 235/40/18 compared to the stock 225/40 and have never had a problem,
jwm5 is offline   Reply With Quote
Old 04-15-2010, 10:14 AM   #23112
hcaleman
My Ride: E36 M3
Kiel, can you take some pictures of those taillights you have up for sale, I wanted to see where the crack was (visible from the outside)?
Place quoted me ~500 to spray my nose panel and front bumper with glassruit paint (decent german paint, have used it before on another car) if i bring the parts in myself. Good deal?
This is why bmw needs to bring M3/M5 wagons over here:
E63 AMG Wagon.
hcaleman is offline   Reply With Quote
Old 04-15-2010, 11:05 AM   #23113
robb1887
My Ride: 00 Mshoe
Yea Charlie. The price sounds pretty good
Old 04-15-2010, 12:01 PM   #23114
hcaleman
My Ride: E36 M3
Sounds good it is the place that did my powdercoating they run a body shop too. I may try to do it there then before we move south
Old 04-15-2010, 12:09 PM   #23115
fourwhls
My Ride: 323ci
Originally Posted by hcaleman View Post
Rear camber like a japanese VIP cruiser. The wheel design looks good on the car, the amount of tire stretch is stupid I bet.
Do you have access to black book rates?
Yes
Shawn
"If everything seems under control, you're just not going fast enough."
Mario Andretti
fourwhls is offline   Reply With Quote
Old 04-15-2010, 12:35 PM   #23116
bimmerfan08
My Ride: F
Originally Posted by Impulsed7 View Post
you would want 235/40R17... which if cory is not going to buy off of me, I have a set of two fuzions...
im gonna add that you got e46, so you could easily go way wider, 255/35 or so, 245/40 to be conservative.
thanks brad, however on an 8" rim the 255 would probably bulge a little
so you have smaller tires in the front?
Sounds good. I just did some calculations and for a 235/40/17 there is a 6/10" difference as opposed to a 235/45/17 where there is only a 4/10" difference from the fronts. Plus the 235/40/17 will be shorter....so Ill go with the 45 wall
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 04-15-2010, 03:04 PM   #23117
latino1ny
My Ride: BSM 335i
Whose all going to the meet at BG tomorrow?
'08 BSM E92 335i 6MT/KW V1s/matte black grills/blacked out side markers/complete LED interior kit/DCI/M-aero front lip/Alcantara shift boot/Clutch stop/CDV delete/LED reverse lights/muffler delete/Cyba scoops/3.8" Cyba tips
latino1ny is offline   Reply With Quote
Old 04-15-2010, 03:25 PM   #23118
robb1887
My Ride: 00 Mshoe
food, beer, drinks, pictures... chilling... Im booking out
Old 04-15-2010, 03:29 PM   #23119
Snik
Snik's Avatar
i'll pass thru..
Old 04-15-2010, 03:54 PM   #23120
hcaleman
My Ride: E36 M3
What time are you guys going there?
Rate This Thread
