Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Thread Tools Search this Thread Rating: Thread Rating: 120 votes, 4.96 average.
Old 07-16-2010, 01:11 PM   #26161
das BENZin
My Ride: 1985 380SE 5.6
Holme, does the e36 M3 use flat tappet or roller cams?
das BENZin is offline   Reply With Quote
Old 07-16-2010, 02:18 PM   #26162
hcaleman
My Ride: E36 M3
Yeah I go about 6k miles or so on pure synth.
hcaleman is offline   Reply With Quote
Old 07-16-2010, 02:19 PM   #26163
HolmeSiR
My Ride: 95 Avus M3
I'm not sure to be honest. Whats the difference? Probably roller.
HolmeSiR is offline   Reply With Quote
Old 07-16-2010, 02:41 PM   #26164
The Law
My Ride: 1993 325i
Is that tech session open to all BMWCCA members? Can I just stop on by and meet some people or did I have to RSVP?
The Law is offline   Reply With Quote
Old 07-16-2010, 02:50 PM   #26165
das BENZin
The important part of the difference is if it's flat tappet DO NOT just go out and buy M1. Easy way to tell - do the lifters have rollers on them?
Old 07-16-2010, 03:11 PM   #26166
The Law
My Ride: 1993 325i
http://forums.bimmerforums.com/forum....php?t=1486038
Old 07-16-2010, 03:13 PM   #26167
silvere39bimmer
My Ride: E-36 M3
Yes anyone can come, feel free to come on out.
John
silvere39bimmer is offline   Reply With Quote
Old 07-16-2010, 03:32 PM   #26168
Impulsed7
My Ride: just an M3, sort of
They are not roller cams.
also, what do you think about the 5.7mm round? I've got some plans in my little head.
Impulsed7 is offline   Reply With Quote
Old 07-16-2010, 03:35 PM   #26169
das BENZin
I think the problem with the 5.7 is they've neutered the ammo they'll sell to the people. Low recoil and flat shooting, but it's just for fun.
To Holme - if you're not willing to order your oil online, and since Impulsed said it doesn't have roller cams, I'd give Shawn Ramey a call and see if he stocks the Brad Penn oil in a weight appropriate for your car (www.rameybuilt.com). Otherwise I'd get something like Motul 300V from lnengineering.com (NB: you're going to have to change it out every 3k). You can also sometimes find the Valvoline Racing stuff in a auto parts place (the REAL Valvoline racing, the one that says for off road use only on it).
Old 07-16-2010, 04:45 PM   #26170
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Dude, its a E36 M. Basically a M50/2 with a fancy manifold. It runs the same non M bmw llc oil as any other regular bmw.
Mobil1 0W40 is just fine for it.
Fuk valvoline, I'd never put that **** in my car, and mobile1 is what your benz and porsches come with, so its good frikin oil.
No need to go searching all over for some fancy oil.
Do you ride a sportbike?
Old 07-16-2010, 04:46 PM   #26171
das BENZin
I suggest you do some reading up on what has happened to oil, and on what are the needs of flat tappets.
If you think MB and Porsche using M1 has anything to do with the oil, you're mistaken. It's all about money. Yeah, it'll work fine for a roller cam, but it's not great. Even ExxonMobil says the only Mobil1 that can be used with flat tappets is the 15w.
Old 07-16-2010, 04:56 PM   #26172
Snik
Snik's Avatar
Not gonna argue with you man. I've been using M1 for a long time, and their reputation isn't bought. So yeah...
You check out any oil analysis comparison, M1 is good to go.
Porsche wouldn't run their oil if it was garbage. Same with castrol and bmw, its a partnership, castrol works with bmw developing these oils, I'd go out on a limb and say I'm pretty sure M1 and Porsche have done the same.
Old 07-16-2010, 05:02 PM   #26173
das BENZin
Again, the needs of roller cams and flat tappet cams are TOTALLY different. And ANY SM oil is going to be bad, with the exception of the 15w seems to be ok, though not ideal.
The current M1 formulas haven't even been in existance for a long time for you to have been using them for a long time.
On top of that, the factory fill oils have to be high detergent, which is another point against them, for the sake of the extended service intervals companies are pushing.
Find someone who has run Mobil 1 in a porsche on a track and ask him what happened to his oil pressure after 10 minutes.
It's not a bad oil for running a car with roller cams around the street, I agree. It's not a great oil though.
Old 07-16-2010, 05:23 PM   #26174
Snik
Snik's Avatar
Lol. Whatever man. We'll agree to disagree.
Old 07-16-2010, 06:43 PM   #26175
das BENZin
But see...there's a right and a wrong. Just ask all the muscle car and british car guys who had the combination of unhardened cams with flat tappet lifters and saw their cam lobes wipe away in a matter of hundreds of miles. Even with the nitride hardened German car cams, if you've got flat tappets SM oil (except for 15w) is your worst enemy, it just takes longer. It's not a Mobil thing, it's not a Castrol thing, it's an EPA thing. These other oils have the benefit of being "off road only."
Now, a newer car with roller cams is pretty much fine with SM oil, but just know that it's a marginal fine and I wouldn't do anything that significantly changes the pressure on the cams and valvetrain while still using that.
Old 07-16-2010, 08:07 PM   #26176
vze3t229@verizo
My Ride: E46 DINAN 3
Send a message via Yahoo to vze3t229@verizo
Just finished doing my wiring for my fan delet mod!!! It works well and keeps my temp in the mid/normal area of the guage. It's better than the clutched cooling fan and the electric fan is quiet as heck!!! Best investment I've done on my e36!!!
Jeff - BMW CCA Member
Checkerd Flag BMW,MINI & Smart
BMW Parts Advisor
MINI Parts Advisor
Smart Parts Advisor
SGT USMC/Disabled vet
93 E36/coupe 325is (sold)
03 E46/sedan DINAN 3
06 E83 SAV X3 (sold)
11 MINI Countryman S
02 E46 M3
vze3t229@verizo is offline   Reply With Quote
Old 07-16-2010, 08:13 PM   #26177
bpalm004
My Ride: E36 M3 Sedan
Just bought a new house and moving in this weekend!! Can't wait to get settled in!
bpalm004 is offline   Reply With Quote
Old 07-16-2010, 09:09 PM   #26178
nbarcelo
My Ride: German Engineering
Send a message via AIM to nbarcelo
Who's all going to Racewerks tomorrow? Anyone from the Yorktown area want to drive down?
Soon to come??
09' C63 AMG
09' MB SLK 300 AMG Series (sold)
95' BMW 318iC Boosted (sold)
nbarcelo is offline   Reply With Quote
Old 07-16-2010, 11:07 PM   #26179
Snik
Snik's Avatar
I think I'm doing the raceworks thing, so long as I get done bicycling in time.
Old 07-17-2010, 02:36 AM   #26180
marineifra
My Ride: 1995 ///M3
additional information required. seriously. link me to what you used please. i considered this a few yrs ago on my 325is but could never find the right fan or anyone to tell me what fan to use. and calvins fan sounds like a turbine powering up for full throttle every 7 seconds lmao
btw...someone change calvin's name on the forum from the law to fireball b/c apparently its ok for him to shoot fireballs at people in the parking lot of rib joints while hes leaving. just sayin
CNT C M3
Would you like something sandblasted, just shoot me a PM. Lets see if we can work something out
Originally Posted by nbarcelo View Post
Kiel was in the Marines and now he drives an M3 so he can talk however he wants to... jeesuh!
marineifra is offline   Reply With Quote
Rate This Thread
