Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Thread Tools Search this Thread Rating: Thread Rating: 120 votes, 4.96 average.
Old 10-17-2010, 08:08 PM   #28061
hook_7
My Ride: e36 m3
Originally Posted by Impulsed7 View Post
just come get it one of these nights. I'll post up tomorrow when I get off work, and just come get it. not sure what time I'll be done but should be before 5.
also, found out the ball joints are tapered, so any load on them locks them down. an impact gun would just destroy them, but thanks for trying.
Just text me when you have time. i wanna give you some money for it.
hook_7 is offline   Reply With Quote
Old 10-18-2010, 06:47 AM   #28062
hcaleman
My Ride: E36 M3
Tightening the balljoint on the subframe?
hcaleman is offline   Reply With Quote
Old 10-18-2010, 06:39 PM   #28063
hcaleman
My Ride: E36 M3
Anyone know a good place around here to get tires mounted and balanced at a reasonable price? If I buy another set of wheels I'm going to have to get the old ones unmounted from them, switch my Dunlops over (unmount and mount) and have them balanced on the new set, then have a new all-season set put onto my style 68s.
I don't really feel like paying 250 bucks to have all these tires mounted if at all possible.
Old 10-18-2010, 06:57 PM   #28064
bimmerfan08
My Ride: F
I went to merchants, cost me $75 to mount and balance 5 tires on my 325i
"You are free to make choices. You are not free to escape the consequences."
bimmerfan08 is offline   Reply With Quote
Old 10-18-2010, 07:06 PM   #28065
Shipkiller
My Ride: 2008 Z4MC & 2003 Z4
That depends. If you never drive your car over 80-90 MPH then any good shop can do it very reasonably as bimmerfan08 suggests.
If you do a lot of high speed runs and/or track your car, in my opinion there is only one place in Hampton Roads. Performance Tire and Wheel in Chesapeake.
http://www.performancetireandwheelsvcs.com/
The Hunter Equipment Corp. lists Rex (the owner) as the best mounting and balancing person in the Country.
"Bench racing" about track times driven by professionals are like a bunch of nerds arguing which Princess Leia is hotter, the slave Leia or the no-bra jail-bait Leia. No matter how compelling your argument is, the plain and simple fact is, none of you will EVER get to hit that.
Drives a 2008 Z4M Coupe' (His) & 2003 Z4 Roadster (Her's)
www.shipkiller.com
Shipkiller is offline   Reply With Quote
Old 10-18-2010, 11:16 PM   #28066
das BENZin
My Ride: 1985 380SE 5.6
How much can who does it matter? I mean, as long as it's a Hunter Road Force balancer with the latest tech, and the guy runs the balancer more than once (because the first numbers are always inaccurate, the road force thing seats it though and run #2 is accurate), I don't see what difference it can make. I'm presuming a shop that won't mess up your wheels and will actually balance them. There's a guy up in Williamsburg who does it for cheap as a side thing out of the shop where he works (like $40 for all 4), but I'm not sure if he's back in town yet (or if he's still doing it, he only does it when he needs money).
das BENZin is offline   Reply With Quote
Old 10-19-2010, 03:24 PM   #28067
Shipkiller
A great deal.
Yes, the machine does all the work, but setup and skill in operating the machine is essential.
Also you must take into account that at most tire shops/full service shops that the people doing the tire fitting and balancing are almost always the junior personnel with little experience.
Do you really want some 18-21 year old kid who most likely did not go to any type of accredited school and is learning 'on the job' mounting tires on your new $2000/set of wheels or have him doing a road force balance just before you head out to the track in which you are going to be doing 140 at the end of the long straight?
Go to a cut rate tire shop and watch how they perform the balance. If you are lucky enough to find a shop that has a Hunter 9700 series machine, most don't in this area... do they completely clean the inside of the wheel, or just knock off the old weights and attach the new ones on without proper prep... Seen this.....
Last month my best friend was having his new track tires (non-Rcomps) mounted and the tech decided he did not like where the machine said to place the weights, because he (the tech) wanted to 'hide' the weights...
He was NOT told to do that and it took two more tries to get it right. I mean taking the car back two more separate times. This happened last month...
I took my wife's Z4 Roadster to have an alignment performed. The Hunter Machine tell the operator when you plug in the type of vehicle (BMW) that after the alignment you must reset the Steering Angle Sensor. The shop decided that they knew more than Hunter did and did not do it, nor did they have the equipment to perform the reset. Consequently the DSC was all screwed up and I had to have the alignment performed again at another shop to get everything sorted out. Cost me double...
I guess it all depends on what you will settle for. Sometimes the best lessons are the costly ones....
I am not saying that all the bargain shops are bad and I am not saying that all high priced shops are great, but you really do get what you pay for. Most of the time.
www.shipkiller.com
Old 10-19-2010, 07:34 PM   #28068
das BENZin
Well, my friend works for a fairly fancy independent Euro repair shop in Williamsburg (his dad owns it), and he does a pretty thorough/clean job. Yes, he is young, but I have taken his balancing job to 150. And they use the Hunter 9700. They also have the 2-piece German wheel weights, which I like.
Old 10-19-2010, 09:34 PM   #28069
das BENZin
BTW, he says I can refer people to him. He's grkguy89 on vadriven.
Old 10-20-2010, 10:58 AM   #28070
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Originally Posted by Shipkiller View Post
A great deal.
all those sound like incompetent techs or techs trying to cut corners.
i dont think my car has a steering angle sensor, as its so old, but up to 130mph and not a shake, and my used tire guy mounted and balanced my wheels.
my bike, i mount my self and balance with a static balancer. regular trackdays in the 150+ and no issues, hell ive done 2 trackdays with "unbalanced" wheels on my bike... granted, the BMW is MUCH more sensitive, but if my boy can get it right, with run falats, regular tires, and even flipped bady worn tires, i dont think its that hard.
Do you ride a sportbike?
Old 10-20-2010, 02:55 PM   #28071
Shipkiller
What track to do you go to to be able to get to 150MPH?
www.shipkiller.com
Old 10-20-2010, 03:03 PM   #28072
Snik
Snik's Avatar
on my bike? lol ah, pretty much all of them except summit jeffereson...
Old 10-20-2010, 03:10 PM   #28073
Shipkiller
Oh, well that makes sense. Your bike has a much greater power/weight ratio.. On VIR North Course, the best I was able to do on the straight into turn one was 139MPH.
I get to do the complete course at VIR in Nov..... We shall see on that long straight... but I normally don't try to get to the fastest speed I can achieve while on the track. I am normally working on something specific.
www.shipkiller.com
Old 10-20-2010, 03:21 PM   #28074
Snik
Snik's Avatar
yeah, i said on my bike. like twice.
Old 10-20-2010, 05:23 PM   #28075
bimmerfan08
My Ride: F
Old 10-20-2010, 06:30 PM   #28076
330i SDJ
My Ride: '02&'97 M3, '71 2002
Registered for the TrackDaze VIR November event (both days). Anyone else going?
330i SDJ is offline   Reply With Quote
Old 10-20-2010, 09:32 PM   #28077
robb1887
My Ride: 00 Mshoe
Buying CSL reps 18x8.5 18x9.5 with Micheline Piolot Sports, with under 100 miles on them . Buddy is picking them up in DC tomorrow and my mom is visiting my sister in NOVA this weekend and will be bringing them back down with her on SUNDAY!
Is it Sunday yet?
robb1887 is offline   Reply With Quote
Old 10-20-2010, 09:34 PM   #28078
bimmerfan08
My Ride: F
I was talking to friend about it (cowmoo32) but I have class both days and Ill most likley be attending another skyline meet the weekend before
Old 10-20-2010, 11:07 PM   #28079
Impulsed7
My Ride: just an M3, sort of
Just going to put the warning out for the skyline drive meets, be careful. from my own and others experiences lately cops are really cracking down on these roads. try running to WVA from skyline drive because the entire state of VA has your description...
Impulsed7 is offline   Reply With Quote
Old 10-21-2010, 12:44 AM   #28080
das BENZin
That's why I stick to Race Wars. No cops out in the desert.
Rate This Thread
