Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Thread Tools Search this Thread Rating: Thread Rating: 120 votes, 4.96 average.
Old 10-06-2012, 04:42 PM   #34801
jwm5
My Ride: station wagon
I had just finished up some work and was driving by so I figured I would drive thru....couldnt have gotten there earlier.
jwm5 is offline   Reply With Quote
Old 10-06-2012, 04:50 PM   #34802
dcw242
My Ride: a dinosaur
I'll tell you what, the coffee from Bean There Coffeehouse and walking around looking at cars certainly cured my hangover. First time going, pretty chill.
Was considering doing straight pipes from rear axle back and using tips. found these but saw their price, figure 200 flat with shipping included plus 50-75 for cutting/welding. For that much, I reckon I might as well spend the extra cash and buy the Rogue Ikon and just do it right the first time. Thoughts?
http://www.borla.com/products/product_multi_detail.aspx?cat=3&type=63
dcw242 is offline   Reply With Quote
Old 10-06-2012, 09:05 PM   #34803
jwm5
I support the Rouge Ikon
Old 10-07-2012, 05:21 PM   #34804
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Made it back from Ohio to Florida with the M.
Slight headache and can't stop grinning.
Lost a turn signal in KY tho. Hit an expansion joint so hard I thought I would've lost all 4 tires. Was doing 85 when I hit it. Thing had no signs or nothing. I was lucky. But I guess it knocked the turn signal lose.
Car pulls like a freight train and ridiculously fast... and thirsty. I dare not touch sport mode.
I'm about ready to give the sedan away at this point. It's def made me not want to even drive it at this point because the M is a few universes better in EVERY single way.
Do you ride a sportbike?
Old 10-07-2012, 07:14 PM   #34805
Snik
Snik's Avatar
That's the goo side.silver is stripping off the wheels. but this side is currently missing a turn signal. Lol
Old 10-07-2012, 08:37 PM   #34806
jwm5
specs please whats the mod list it cant be stock.
Old 10-07-2012, 08:58 PM   #34807
Snik
Snik's Avatar
Cmon, you know Sink don't do stock.
01 IR on BLK
Cold weather package.
HK system
6 speed.
Dinan stg 1 ECU
Dinan strut bar.
Had Dinan stg 1 suspension, springs swapped for Tien springs.
CSL headers and sect 1
Topspeed muffler.
Drilled rotors OE size.
Ssk. Not sure of brand.
Power pulleys. Not sure of brand
OE denims retrofitted + AE 6k
6k HIDs and fog HIDs
LEDs interior lights and plate lights.
CF splitters and CF diffuser
Full CF interior trim, incl that eas CF steering wheel
M3 trunk lip
Fresh insp 2. Just gotta get ready to do valve adjustment here soon.
Might do rear bearings since I'm renting the tool soon.
906xx miles when I left OH.
3rd owner. Both owners are on M3forum. CA car.
It's LOUD!
Wind deflector included. Some small fixes due.
Sub/ski pass door won't lock.
Glovebox locked shut. Can't open. Both common
LCM needs reflash, as car came with halogens. So gotta fix that.
Old 10-07-2012, 09:06 PM   #34808
Snik
Snik's Avatar
Oh yeah. Alpine touchscreen HU with navi. XM stuff isn't hooked up. But I got it too.
iPod hookup and headphone jack Aux connection.
Upper center console compartment door is broken I think. Can't close it.
All very minor stuff. Got it all for $14k.
Took the stock HU, diffuser and headers. Told him to toss the rest.
Old 10-08-2012, 12:31 PM   #34809
jwm5
nice buy, good looking car, always loved Imola
Old 10-08-2012, 09:40 PM   #34810
dcw242
My Ride: a dinosaur
[pic removed cause shitty quality/composition ]
Trying to get flush and lower, I've got about 4.25-4.5" clearance in the front I'm trying to get down to ~3" and I've got about 20mm space in the rear and 13mm in the front for flush. Which would ideally just be a 20mm spacer in the rear and 12-13mm spacer in the front. However, my tires would rub, hard, even if I roll/cut the inside of my fenders. Currently sitting on 19x8.5 et40 with 235/35/19. Even if I wanted to stretch, the smallest tire in this size would be a 215/35 or 225/35, which wouldn't be much of a stretch at all. I think I'd have to use a 215/35 and still roll/cut fenders in order to get flush with spacers. Also, a drop to 215/35 would only be about a 1/4-3/4" drop in height, so I'd have to add some degree of camber to get the height I wanted. Adding camber could mean I may not need to roll/cut fenders. My only concern with camber is that because of the higher offset I may hit my coilovers, I'm a bit close now, as is.
I like the wheels I have on now, so I'm not in a rush to swap them, but it's going to be a lot of work to get the car to sit the way I'd like to with them. I think what the easiest thing to do would be to chalk up these 19's as a learning experience and move on to 17 or 18's with better fitment. Currently debating between TE37 Reps and ACS Type 2s. Rota Grids/TE37 reps look a little too aggressive for a sedan, but because of their availability/price they're a strong favorite. What I'd really like to do is find a set of 18" ACS Type 2 with a nice offset because I love the concavity of them. I like LM's and Style 5's a lot, but they're so overplayed by everyone right now. But, if I could find a set of Style 5's for the right price, I probably wouldn't turn them down.
Still newish to the whole wheel/offset/tire matching.
- Also, saving for the RE Ikon exhaust, but I had a setback when I lost my glasses at the ABR concert on Friday and had to buy new ones today. Hoping I can sell my OEM wheels here soon to make up the loss and then buy/install the exhaust before the end of the month.
Edit: Noticed my headlight trim doesn't seem to want to sit flush anymore. The bottom of the outsides don't seem to snap/stay in place. Any ideas?
Old 10-08-2012, 09:41 PM   #34811
Snik
Snik's Avatar
why are all your pics so cloudy and crappy
Old 10-08-2012, 09:50 PM   #34812
dcw242
My Ride: a dinosaur
because iphone has so many scratches on lense and i has no real camera
Old 10-08-2012, 10:22 PM   #34813
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
That's a <$10 fix and 30 seconds of your time.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 10-08-2012, 10:24 PM   #34814
E46_330i_Stud
Not sure why whole post isn't showing, but that's a less than $10 fix and 30 seconds on your time or less.
Old 10-08-2012, 10:41 PM   #34815
dcw242
My Ride: a dinosaur
Care to elaborate? Not something I ever cared to look into since I'm not a big picture taker.
Old 10-08-2012, 10:50 PM   #34816
E46_330i_Stud
Search on eBay or amazon for your desired color of back plate (if you have a 4/4s). MOST come with the tool needed (star shaped driver) and all you do is take out the screws and slide the back plate off and slide the new one on. Some of them suck and crack on install so be sure to read the reviews before hand.
Old 10-09-2012, 09:48 AM   #34817
robb1887
My Ride: 00 Mshoe
Snik, good news, I might have actual pictures up tonight of the E36 finally after all the stance/wheel/fender work. Took some on Saturday, but dont know what they look like since I didnt remember to upload them this weekend. I'll try to get to it tonight.
Things still on the to-do list:
215/45 rear tires
8k/10k spring rate swap out
'92 front bumper
Paint BBS lip and bumper to mount up.
Might see about a fresh nose panel too since I'm painting the other things and freshen up the front end, but thats cost dependant more than anything. Also, on the horizen I see some nice OT coming so that's awesome. Nothing like I was seeing earlier this year, but more than I've seen in the past few months.
robb1887 is offline   Reply With Quote
Old 10-09-2012, 08:01 PM   #34818
Snik
Snik's Avatar
Good news. Contacted the original owner of the M.
Dude sent me the full mod list.
No CSL headers. But instead AP headers, and DA software and pulleys.
Ssk is OEM.
Front bumper is a OE euro item.
Euro section 1 with cats.
Suspension is actually Dinan stg 2.
Splitters are Vorstiener
Hawk pads
Euro floating rotors
Stoptech SS lines.
Lots and lots of ****. He dropped $17k on the thing. :o
Old 10-09-2012, 08:40 PM   #34819
robb1887
My Ride: 00 Mshoe
Noice. So whatcha doing with the hooptie now?
Old 10-09-2012, 08:41 PM   #34820
Snik
Snik's Avatar
K, pretty much copy and paste from the PM he sent me.
Guy i got ot from ditched the CSL wheels and added OEM Xenons, they look like they had a few broken tabs, and he made it happen. He also added all LED interior lights, swapped the Dinan springs for Tein, and 20k or so miles?
Here you go. Everything I did to the car while I owned it, along with the price I paid for the mod, and mileage when the change occured (at least for performance mods). All the performance mods were installed by the M Shop in LA.
Enjoy.
Modifications
Interior
ZCP shift knob $50
Alacantra shift boot $110
Alacantra e-brake boot $130
EAS Carbon Fibre ebrake handle $75
EAS Carbon Fibre steering column cover $349
EAS Carbon Fibre interior trim $769
EAS Sports Steering wheel $1,100
EAS Carbon Fibre steering wheel trim $155
OEM SSK $125
Exterior
Rear Spoiler (Painted) $424
Headlight trim $99
License plate surround $65
Wind Deflector $300
CSL wheels (Hyper Black) $759
Blacked out grill $75
Blacked out side gills $75
Short ariel $35
Smoked turn indicators (Depo's) $59
Smoked side markers $59
Window tint - Madico 38% $150
Vorsteiner CSL-Splitters $400
Delsa CSL Diffuser $200
OEM Euro bumper $587
Paint and installation for bumper, rocker panels and rear bumper $1,800
Performance
Replacement OEM calipers (off an 06) $435 Installed at 39,600 miles
Euro rotors $1,000
Hawk HPS brake pads $350
Stop-tech SS brake lines $130
Dinan Stage II suspension $2,700 Installed at 41,800 miles (September 07)
Dinan Strut Tower Brace $499
Rogue Engineering RSM shims $149
New RTAB's $400
AP Headers, Discovery Automation software, Streamline filter and under drive pulleys $2,090 Installed at 45,000 miles (February 08). Streamline filter installed Jan 26 at 44,775 miles.
OEM Euro Cats $820
Installation $959
Total $17,481
Rate This Thread
