Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Thread Tools Search this Thread Rating: Thread Rating: 120 votes, 4.96 average.
Old 10-16-2012, 08:21 PM   #34841
robb1887
My Ride: 00 Mshoe
^+1 weird noises or just a steering vibration?
robb1887 is offline   Reply With Quote
Old 10-16-2012, 08:23 PM   #34842
dcw242
My Ride: a dinosaur
Ive got a set of black kidney grills, not sure what brand, but they arent ****. They dont fit e46 sedans, pre or post facelift. Theyre sitting in my room taking up space if anyone wants them. Ive also got a set of clear side markers for e46 coupes im also giving away.
Finally, need some help fixing my fogs, wiring/electrical isnt really my thing, but they dont work at all.
dcw242 is offline   Reply With Quote
Old 10-16-2012, 11:57 PM   #34843
JBMW3
My Ride: bmw
A little of both
JBMW3 is offline   Reply With Quote
Old 10-17-2012, 07:36 AM   #34844
howesE46
My Ride: 2003 330ci
So kidneys are for coupe?
howesE46 is offline   Reply With Quote
Old 10-17-2012, 11:43 AM   #34845
dcw242
My Ride: a dinosaur
I would assume so via process of elimination, but im not going to guarantee
Old 10-17-2012, 12:16 PM   #34846
howesE46
My Ride: 2003 330ci
Well could be for e90 or are they smaller. Well if they fit e46 ill take them off your hands. Today if possible. Mine are about to fall out lol.
Old 10-17-2012, 01:45 PM   #34847
JBMW3
My Ride: bmw
Its a bad vibration in the rear. I thought it might have been a tire or something but the ride is smooth till I get to 70mph.
Old 10-17-2012, 07:02 PM   #34848
dcw242
My Ride: a dinosaur
Sent you a PM. Theyre definitely for e46's
Old 10-17-2012, 07:12 PM   #34849
Snik
Snik's Avatar
My Ride: IR M3 Vert.
In my experience. With my hooptie sedan.
Vibrations u describe can be caused by several things.
Broken subframe.
Shot diff bushings
Shot RTAB bushing
Bad center support bearing
Bad wheel bearing.
The last 2 I believe are most likely and cause the most rogue type on and off vibrations.
If its a bushing. In my experience, the vibration is worse the colder it is, as cold rubber is less compliant.
You need to better describe the vibration and all the types, times and various loads that changes it for us to diagnose it via Interwebz.
Do you ride a sportbike?
Old 10-18-2012, 09:03 AM   #34850
JBMW3
My Ride: bmw
Broken subframe.
Shot diff bushings
Shot RTAB bushing
Bad wheel bearing.
Well I had to change the center bearing a few years ago. I will try to see if its the wheel bearings. Its just a really bad vibration that happens when Im around 70-80mph from the rear it is causing the car to shake. I really dont know how to describe it someone just needs to drive it an see for themselves.
Old 10-18-2012, 07:36 PM   #34851
Snik
Snik's Avatar
And u sure its not just the tire?
Old 10-18-2012, 09:28 PM   #34852
JBMW3
My Ride: bmw
I
I have runflats but I guess I could have someone look at them. I will ask.
Old 10-18-2012, 09:55 PM   #34853
Snik
Snik's Avatar
Run flats or not makes no difference. If the tire is worn out if round because of a bad alignment or excess camber or crappy damper. It may cause vibrations. Being a BMW, if that's the case, you WILL feel it.
Old 10-19-2012, 08:33 AM   #34854
howesE46
My Ride: 2003 330ci
Anybody have any spacers they are trying to get rid of??? Just really need two 5mm spacers
Old 10-19-2012, 10:15 AM   #34855
robb1887
My Ride: 00 Mshoe
^ you figure out about them couches?
Old 10-19-2012, 10:54 AM   #34856
howesE46
My Ride: 2003 330ci
Waiting to hear. I have a buddy looking for couches, I sent him the link he said he'd get back to me. He's out of town till Sunday
Old 10-19-2012, 05:34 PM   #34857
robb1887
My Ride: 00 Mshoe
Check
Old 10-20-2012, 07:24 AM   #34858
howesE46
My Ride: 2003 330ci
So spacers anyone?
Old 10-20-2012, 07:06 PM   #34859
robb1887
My Ride: 00 Mshoe
I think I was the last local person to have any and I sold all of my sets. Sorry.
Old 10-20-2012, 09:57 PM   #34860
Snik
Snik's Avatar
Hey Robb. Check this out.
Front barrels 7" wide w/ 2" lips for 8.5" wide.
Rears are 6.5" w/ 4" lip for 10" wide total.
Good news is. I've had 19x8.5" fronts this whole time. The R05s are 19x8".
Great news. Once I swap those 2" lips for the 5" lips I have they will become 19x11.5" and redo the front, same pieces, for 19x10" up front.
Current 10s are estimated to be ET27.
If my math is right. Adding 3" of lip should shift my offset 37.5mm.
In gonna be running close to 0 offset. Iirc current front offset is ET40
I are so excite.
Rate This Thread
