Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Mid Atlantic
Mid Atlantic
DC DE MD PA VA WV
Thread Tools Search this Thread Rating: Thread Rating: 120 votes, 4.96 average.
Old 01-06-2008, 06:55 PM   #1281
thinkdammit
My Ride: M...(DX)
Send a message via Yahoo to thinkdammit
Thanks, Snik!
From what I read, many have done it themselves with a paperclip and grounding and the data link connector...sounds more like kaboom to me.
Yeah, I thought about you and that extractor...but there was something exciting about actually getting under my car. I saw all kinds of neat things! Except for what appears to be a gasket that's leaking and needs to be replaced...valve cover, I believe.
thinkdammit is offline   Reply With Quote
Old 01-06-2008, 07:00 PM   #1282
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Bwwahahahha, neat things, hahha. Lol.
Yeah its fun under there. Mine has a leak also, but it doesn't seem to be from around the head, them boys at AAW think it may just be the filter gasket on mine.
Did the drain bolt require any fancy tools or just regulat sockets?
Do you ride a sportbike?
Old 01-06-2008, 07:21 PM   #1283
thinkdammit
My Ride: M...(DX)
Nope. Just 6mm hex.
...think I broke a nail...just kidding!
Old 01-06-2008, 07:25 PM   #1284
Snik
Snik's Avatar
I wonder what these stealerships charge to reset a light.
Old 01-06-2008, 07:30 PM   #1285
smoker9
My Ride: 02 330ci
Send a message via Yahoo to smoker9
RESETTING OIL SERVICE INDICATOR:
If your OBC needs to be reset after completing your oil change, there are two ways. NOTE: If you miss a step, just turn the key back off and try again:
A. Model Year 1999 to Mid-2000: You should have the older round 20-pin DLC connector under your hood behind the battery terminal, you need to use a small length of wire to connect (short) pins 7 and 19 for 3-5 seconds with the ignition key in position 1 (Accessory).
B. After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done.
i've done mine (several times) with no problems...
sold...
smoker9 is offline   Reply With Quote
Old 01-06-2008, 07:45 PM   #1286
thinkdammit
My Ride: M...(DX)
Smoker...
Just did it--worked like a charm!
Gracias!
You are chock-full of good stuff!
Old 01-06-2008, 07:48 PM   #1287
smoker9
My Ride: 02 330ci
Originally Posted by thinkdammit View Post
Smoker...
Gracias!
de nada...just passing along info to my fellow fanatics
sold...
Old 01-06-2008, 07:49 PM   #1288
Snik
Snik's Avatar
Hells yeah smoker, blazing again, hahha. I'm gonna do mine after my oil change this weekend.
Real quick, when I crank up it says somehting like -4950 insp on the dash.
I didn't get a manual with the whip, but I'm assuming this is telling me how long before I'm sue for a service, yes?
Old 01-06-2008, 07:56 PM   #1289
smoker9
My Ride: 02 330ci
yup...the indicator light alternates (counts down) from oil service to inspection service...
sold...
Old 01-06-2008, 08:09 PM   #1290
thinkdammit
My Ride: M...(DX)
Yeah, my BF called me that today while he was "supervising" the oil change...he said it like it was a bad thing!
So I told him to go away.
Old 01-06-2008, 08:21 PM   #1291
smoker9
My Ride: 02 330ci
...although it can be a bad thing once the mod bug gets ya...
sold...
Old 01-06-2008, 09:02 PM   #1292
Snik
Snik's Avatar
Hmm, I always thought it was a bunch of little blocks that disappeared as u got closer.
Man I need a damn manual, I may end up having to read it in pdf format.
On the brighter side. I now have my website sticker, yesn it is vedy nice, yes, zis is vedy nice ah sticker on zi car. It is very godd yes.
Old 01-07-2008, 10:47 AM   #1293
CShell
My Ride: Cait
Send a message via AIM to CShell
Just called my indy shop to get a price on installing sport springs and alignment after.
$400.00
I then called Meineke for a quote.
$600.00
WOW!!!!!!!!!!!
CShell is offline   Reply With Quote
Old 01-07-2008, 10:59 AM   #1294
Snik
Snik's Avatar
I guess you'll be driving to Va beach then huh? Lol.
Old 01-07-2008, 11:03 AM   #1295
CShell
My Ride: Cait
Quite possibly!!!
that's insane. $600 to install $200 worth of springs.
Can your man do an alignment, too?
Old 01-07-2008, 11:14 AM   #1296
Snik
Snik's Avatar
Nope, but he knows a place that specializes in lowered car and won't just set it to factory specs like most places will, under $100 to align too.
Old 01-07-2008, 11:22 AM   #1297
CShell
My Ride: Cait
Sounds good!
Old 01-07-2008, 02:14 PM   #1298
cozilla
My Ride: 2002 M3
yea i told you it was easy to change the oil. whenever i have to jack up my car i have to ride the front or rear wheels on bricks to get the jack under there haha.
where is this shop that specializes in lowered cars?
colin
cozilla is offline   Reply With Quote
Old 01-07-2008, 02:18 PM   #1299
cozilla
My Ride: 2002 M3
Originally Posted by CShell View Post
Quite possibly!!!
You should just install them yourself it is not that hard really the rears will take you all of 30-45 minutes. The fronts you will need to rent a spring compressor from like autozone or advanced. Then you will be set there are write ups online about it. Also if you get lowering springs make sure you get new shocks and struts cuz the stock ones wont last long because of the the spring rates.
But if you dont have the tools like a socket set or whatever i guess you would be better getting them put in.
colin
Old 01-07-2008, 02:42 PM   #1300
Snik
Snik's Avatar
colin
i dont remember if he said on va beach blvd or in chesapeake. but he says they do everything from raised up trucks to slammed cars, and they know how to adjust em properly and not just to factory specs like most places do.
indeed, but not having the proper tools makes or breaks a job man.
thats what always kills it, lack of tools.
Rate This Thread
