Old 02-08-2007, 11:31 AM   #1
win-by-miles
It really was a Rocky story
My Ride: Refer to sig
$220 for DRL turn off !?!?!
stealership said it will cost 220$ and 2 hours of my time to turn off the day time running lights.... thats bullshit since i know it only takes like 5 min...
is there any other way to turn them off?
i might just unplug them and use a resonator to disable the warning light..... anyone know what resonator to use?
win-by-miles is offline   Reply With Quote
Old 02-08-2007, 12:07 PM   #2
BoxCarRacer
My Ride: E46 & E70
What a rip off; i encountered this same problem last year, call around for a shop with a Modic station im sure they'll do it for about 100 bucks. Also i thought it was illegal to disable your DRLs in Calgary??
BoxCarRacer is offline   Reply With Quote
Old 02-08-2007, 12:29 PM   #3
Solatso
My Ride: 2001 330i
my dealership quoted me $40. I just took it to my indy guy though because he told he'd do it for free since it only takes like 5 minutes and I've spent some $$$$$ with them
UNDER CONSTRUCTION
Solatso is offline   Reply With Quote
Old 02-08-2007, 04:06 PM   #4
ikeupinya
Stay modded my friends!!!
ikeupinya's Avatar
My Ride: 05 ZHP
$220 is wayyyy too much, it should be around $40-$50...
Da Lil' Paratrooper!
ikeupinya is offline   Reply With Quote
Old 02-08-2007, 04:25 PM   #5
THATS FRESH
My Ride: SSHNIPER
Send a message via AIM to THATS FRESH
it should be free. next time you take your car, just tell them to turn it off.
THATS FRESH is offline   Reply With Quote
Old 02-08-2007, 05:01 PM   #6
win-by-miles
i have no more warrenty.... im never taking my car there again...
Old 02-08-2007, 05:04 PM   #7
win-by-miles
what resonator can i use to disable the warning light?
im probably just gonna unplug them..... i hardly ever use high beams
Old 02-10-2007, 01:30 PM   #8
BartenderPlease
My Ride: '03 540i/6 M-Sport
You mean resistor, and I think you will need two 6 ohm resistors?
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 02-10-2007, 07:40 PM   #9
win-by-miles
yeah resistor.... so 6ohm for each light or 2 six ohm for each light?
Old 02-11-2007, 02:32 PM   #10
BartenderPlease
one 6 ohm resistor for each light
Old 02-11-2007, 03:40 PM   #11
james2538
My Ride: Sold
I came up with a 2.618 ohm resistor for each light (I assume 3 ohms would be the closest).
Power (P) = 55 watts; Voltage (V) = 12 V; Current (I) = ? A; Resistance (R) = ? Ohms
P=VI 55/12=I 4.583=I
R=V/I R=12/4.583 R=2.618
^ Not 100% sure this is right, just using some of that physics knowledge.
james2538 is offline   Reply With Quote
Old 02-11-2007, 04:37 PM   #12
BartenderPlease
You may be right
Old 02-11-2007, 04:49 PM   #13
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
go to an indy shop. don't remove the bulb, thats ghetto and then you won't have high beams or the ability to flash oncoming traffic... a safety hazard.
-Brendan
Old 02-11-2007, 06:09 PM   #14
D.Hendrickson
My Ride: 2001 325i (sold)
R=V/I R=12/4.583 R=2.618.
resistors have a tolerance rating, usually 5% or 10%.
2.618 + .262 = 2.88 ? 3 ohm resistors. it's all good.
(too much info... )
dave
D.Hendrickson is offline   Reply With Quote
Old 02-11-2007, 06:42 PM   #15
james2538
My Ride: Sold
(too much info... )
haha I thought maybe if anyone else wanted to figure out how to put a resistor anyplace elsee.
The problem with this guy flashing is very few places will be willing to do it in Canada beause it is illegal. This is the equivalent to trying to get your corner (turnsignal) lights turned off in the US.
Old 02-11-2007, 07:45 PM   #16
ksuen21
CEO OF THE ROC
ksuen21's Avatar
My Ride: 01 330ci,05 Yama R1
stealership charged me only $12 to do it, looks like someones in debt from the superbowl......
my sig needs a makeover
8000k Predator Chromiums
Rogue Engineering DMS Exhaust
Rogue Engineering Pulleys
ECIS Intake
Stoptech Stage II Brake Kit
Short Shift Kit
6000k Fog Lights
18" Hyperblack CSLs
Clears All Around
35% Tint
ksuen21 is offline   Reply With Quote
Old 02-11-2007, 07:48 PM   #17
emthree
My Ride: E46 / E60 M5
Send a message via MSN to emthree
I got mine taken off during inspection #1
Otherwise it would of costed me 105$ (1hr labor)
emthree is offline   Reply With Quote
Old 02-14-2007, 05:30 PM   #18
win-by-miles
is that 3ohm or is it 3k ohm?
Old 02-14-2007, 05:49 PM   #19
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
I used a hammer--works great.
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
Old 02-14-2007, 08:40 PM   #20
james2538
My Ride: Sold
3 ohm
I was thinking about this and came up with an even better idea of wiring this that would allow you to keep your high beam/flashing. Using a relay will allow you to switch between the resistor and the high beam.
Here is a brief overview of how relays work:
http://www.howstuffworks.com/framed....lay_basics.htm
I'll draw a schematic of this to make it much easier to understand.
Red Line - Positive Wire
Brown Line - Negative/Ground Wire
Blue Dots - Wire Taps
This is for one side of the car. The numbers in the middle square is the pins of a relay (Pins 85/86 might be switched, one should be positive and one negative, be sure to hook it up right). The left lightbulb is your low beam, right highbeam, and resistor is well, the resistor. Assuming you have read the link above, what you are doing here is having the resistor connected to the circuit when the lowbeam is off, however, when the lowbeam is on, it is connected to the headlight (DRLs are off when lowbeams are on). This will allow you to flash and use high beams.
The only downside is you can't flash when your lowbeams aren't on. The only thing you would need to cut is the high beam positive line, which you would cut anyways if installing a resitor. If you need help understanding/installing I can explain more.
It is fairly simple as all you would need for each headlight:
1 3 ohm Resistor
3 Wire Taps
1 Automotive (12V) Relay
Electrical Tape
Wire
Another better way would be to just pickup a cheap LCM from the US (or anyplace else other than Canada) and put it in your car. You would have to get it flashed to your specific vehicle if you ever wanted to remove the tamper light (or you could just put your old one back in there when you sell the car). See the link in my sig if you are interested in picking up a Euro LCM.
