Old 02-14-2007, 11:37 PM   #21
win-by-miles
It really was a Rocky story
My Ride: Refer to sig
no no no.... i wasnt thinking about cutting anything
i just wanted to put the resistor there to trick the computer into thinking that the bulb is there and on.... thats all i want to do...
win-by-miles is offline   Reply With Quote
Old 02-14-2007, 11:42 PM   #22
james2538
My Ride: Sold
Alright, I can understand not wanting to cut anything. Still I strongly advise you to just get the LCM flashed so you don't lose highbeams/flash.
Just pick up the 3 ohm resistor and two wire taps. You'll be set. Be sure to mount the resistor in a safe place (It gets HOT, don't put it near plastic)
james2538 is offline   Reply With Quote
Old 02-15-2007, 12:23 AM   #23
KaOsTiK
My Ride: 2003.5 M3
lol..i love some of the diy replies...but try this...
try going to the dealership and actually talking to the shop foreman and working something out for you having your car in for a "headlight bulb flickering" service ...and magically, when u get your car back...your DRL's are disabled
i'm not confirming or denying that it worked for me..but it's just a though...
if that doesnt work, you can always haggle the price cuz all it is ..is a software re-flash that takes no longer than 1 hour.
2003.5 M3 (current project)
2000 Acura 1.6 EL (best EL...period)
KaOsTiK is offline   Reply With Quote
Old 02-15-2007, 09:50 AM   #24
win-by-miles
well they're trying to scam me into doing it
Old 02-15-2007, 09:51 AM   #25
win-by-miles
i dont wanna tap anything. i just want to unplug cable from the bulb holder and put the resistor into the contacts... then tape it up.... i dont want a permentent solution
Old 02-15-2007, 03:38 PM   #26
ca1242
My Ride: 2003 330i
You would probably spend more than $50 on resistors, I would just take the car to another dealer.
Something to keep in mind is that the resistor will get REALLY hot, so mount it in a place where it won't melt anything. Make sure the reistor you buy has the appropriate power rating (a 100W aluminum resistor would probably be better).
If you want to experiment a bit, you could try different resistance values (you might get away with 6, 10 or maybe even a higher ohm resistor). The higher the resistance, less heat wasted and cheaper resistors.
Old 02-15-2007, 06:57 PM   #27
ChrisBrEeZy
My Ride: 00' 3 Series coupe
i got my DRL turned off today and got the clown nose along with the parking lights to flash when i lock and unlock the car, cost me $30 for 15mins of labor. Most definitely go to another dealer and get it done, $220 is ridiculous....
ChrisBrEeZy is offline   Reply With Quote
Old 02-15-2007, 07:22 PM   #28
DarXide
DarXide's Avatar
My Ride: Slammed on F2's
Send a message via AIM to DarXide Send a message via MSN to DarXide
Tell them FVCKK YOUUUU...
FS 20'' Avus 3 piece wheels with tires 80% thread $2,000 + shipping
FS Brembo BBK 4 Piston 380mm front 345mm rear (silver) $3,800 + shipping
DarXide is offline   Reply With Quote
Old 02-15-2007, 07:57 PM   #29
james2538
My Ride: Sold
BAD IDEA,
If you aren't willing to do this right, please for the love of god, don't do it at all. I don't wanna see another my car caught on fire because I can't wire worth **** thread.
You are not gonna be able to just wire up a resistor by taping it in. Resistors get rather hot and will melt any plastic around them, including the bulb holder cable.
Tapping the wires is not a permanent solution. You can remove the taps and go back to stock quite easily.
Or better yet... Go to the dealer!
