Old 02-12-2007, 02:02 PM   #1
scudmiss
My Ride: '01 325i
Transmission Flush at 100,000 miles?
Hi there,
I have been debating for some time whether I should do an automatic transmission fluid change (including filter change, obviously). I have a hair over 100,000 miles on my 2001 325i and am planning on keeping the vehicle for as long as possible (would love to hit 250,000 on it).
I currently do not have any issues with the transmission, except in third gear the RPM's will dip about 300 upon acceleration then continue to rise. (Much like a gear shift, but without actually shifting gears). The dealership told me this was normal about 40,000 miles ago.
Should I change my tranny fluid?
Thanks,
Mike
scudmiss is offline   Reply With Quote
Old 02-12-2007, 06:07 PM   #2
platanito
My Ride: 06 ZCP M3,91 E30vert
There is no such thing as lifetime fluids. Do search and you will see a bunch threads on this topic. Read some of the links below, but I am sure there are more. I flushed mine at 95k and I will be doing it every 30k-60k depending on when I can perform them. GL
http://forum.e46fanatics.com/showthr...transmission00
http://forum.e46fanatics.com/showthread.php?t=366147
http://forum.e46fanatics.com/showthread.php?t=126486
http://forum.e46fanatics.com/showthread.php?t=438667 DIY GOOD INFO.
Hope this helps.
platanito is offline   Reply With Quote
Old 02-12-2007, 11:13 PM   #3
Bimmer44
My Ride: 2001 325i
Originally Posted by scudmiss View Post
Hi there,
Thanks,
Mike
BTW What does 100,000 Miles equal out to in KM's???????????????
Bimmer44 is offline   Reply With Quote
Old 02-13-2007, 12:15 AM   #4
leej323
leej323's Avatar
My Ride: '00 323i
1 km = .62 mile
leej323 is offline   Reply With Quote
Old 02-13-2007, 02:16 AM   #5
importhunnie
My Ride: 01 330xi TiAg
Send a message via MSN to importhunnie
1.7km=1mi
2001 330xi TiAg
koni sport/H&R sport/OE M strut bar/PF bushings
RE underdrive pullies/RSM
BMW Performance front calipers/TMS spacers/H&R studs
BBS CH/thule 753
importhunnie is offline   Reply With Quote
Old 02-13-2007, 01:38 PM   #6
scudmiss
My Ride: '01 325i
Thank you for the info. It appears a transmission flush is in order!
Old 02-13-2007, 05:10 PM   #7
enzo_the_baker
My Ride: 328Ci, 328iC, X3
Interesting. I took mine (with 130K miles) in to the dealer for an oil change/brake flush last week and asked them to do a tranny flush as well. They outright refused to do it, saying that the transmission fluid is lifetime and that flushing the old fluid could actually cause more problems than not changing it. I've never heard of a dealer's service department actually turning down requested work-- they usually recommend everything under the sun, necessary or not!
enzo_the_baker is offline   Reply With Quote
Old 02-13-2007, 10:49 PM   #8
Bimmer44
My Ride: 2001 325i
How come my car doesnt have Miles on the speedometre i live in Canada?????????????
Old 02-14-2007, 12:48 AM   #9
nosoule46
My Ride: 01 E46 & 05 E83 (X3)
Go to an independant then.
nosoule46 is offline   Reply With Quote
Old 02-14-2007, 01:55 PM   #10
Red_wagen
My Ride: ZHP
Send a message via AIM to Red_wagen
I asked a well known indy shop in my area and he said that if you don't change it before 50k you're better off leaving the fluid in there. He said he didn't find a correlation between changing tranny fluid every 50k and tranny longetivity. In other words, he saw trannies that had the fluid change break down before 100k miles and trannies that are running strong w/o a fluid change. Go figure. Basically he said, it's a crap shoot.
2005 Imola Red 330i 6MT, ZHP, ZCW, Xenons
Previous:
2007 Mystic Blue 530i
2003 Gray Green 330i
2003 Electric Red 325iTa
Nice guys finish last.
And I'm a very nice guy...
-Jay
[IMG]Under construction[/IMG]
Red_wagen is offline   Reply With Quote
Old 02-15-2007, 10:27 AM   #11
scudmiss
My Ride: '01 325i
Hmm...Interesting comments. It appears there is no 'right' answer for this? I am skeptical to change my fluid since my tranny is operating just fine, but I do want to keep my car for as long as possible.
Old 02-15-2007, 11:12 AM   #12
milobloom242
My Ride: 2002 325i
I got the same story from 2 indy shops in my area. But I just don't believe that fluids in between high velocity metal pieces can last the lifetime of most of the rest of the car's parts. So I picked one of those shops to change the fluid @ 70k (mostly highway), and they updated the step software too. 2 dealers in the area refused to change the fluid.
milobloom242 is offline   Reply With Quote
Old 02-15-2007, 05:18 PM   #13
scudmiss
My Ride: '01 325i
Anyone with a similar situation as mine? Has anyone done a first time flush at around 100,000 and been successful long-term?
Old 02-16-2007, 01:24 PM   #14
K:^P
My Ride: 00 323//65 Fastback
changed at 100,000 mile a couple of years ago. I don't do a flush, just filter and drain(5 qts). This is the information I understand:
A long time ago when dextron III came out. GM said that the new formula will last 100k and that oxidation is the reason for it to break down( I'm guessing the GM also assumes that the tranny will not overheat and stuff). So, if it sealed then it should last forever(lifetime). Do you trust it? I don't.
Your point on changing the fluid.
Change the fluid now and risk f-ing it up. The tranny may last 200k w/o it. My thinking is that if you don't change the fluid, for sure it's going to f up. It's also a peace of mind too for me.
I'm consider draining it again soon. With no filter change, bc the first time things look Ok.
K:^P is offline   Reply With Quote
Old 02-17-2007, 01:14 AM   #15
Bimmer44
My Ride: 2001 325i
Anyone know im a NOOB!!
Old 02-17-2007, 01:45 AM   #16
Polish_328Ci
My Ride: M3
Yes you are a noob, It doesn't have miles because Canada uses KM/H instead of MPH.
You should still have MPH in little letters under the KM.
Polish_328Ci is offline   Reply With Quote
Old 02-17-2007, 02:13 AM   #17
palomino
My Ride: e36 328, e46 330ci
there's really no right or wrong at this point.
either way is risky. people have already posted that they've changed the fluid after 100k+ miles with no problems. other people have done it and regretted it.
perhaps you could drain & refill it little by little over a few months? sort of like a fishtank, i guess. you cant change all the water all at once, or it could shock the fish & kill them or whatever.
palomino is offline   Reply With Quote
Old 02-17-2007, 03:14 AM   #18
Polish_328Ci
My Ride: M3
Hhaha no worries, I know exactly what you mean, and that might not be a bad idea. Anyone else think thats smart?
Old 02-17-2007, 11:13 AM   #19
2fast2
My Ride: 99 323
If your transmission is working fine, now is the time to change the fluid and filter. Draining the transmission, dropping the pan, changing the filter, and refilling to the fill port with the transmission up to proper temperature (around 100 F) will not change ALL the fluid anyway.
Use the right fluid. I have researched and researched this trying to rationalize how I could use Dextron 3h instead of Texaco expensive stuff. Yesterday when picking up my 99 323 from the transmission shop (remanufactured this week) I spoke with the German owner / master technician who insisted I only use texaco because of the specific additives that are necessary for our transmissions (in my case 5L40E GM) as used in the BMW. Other people will share anecdotes about successful use of something else, but having just trusted my transmission to this guy to rebuild it, and this is what he does for a living, exclusively, I will respect his opinion. He also said change the fluid, maybe every other year or even third year if you don't drive much, but lifetime is the demise of these transmissions.
2fast2 is offline   Reply With Quote
Old 02-22-2007, 11:33 AM   #20
Bimmer44
My Ride: 2001 325i
^^^^^^^^^^^^^^No i don't!!!!!!!!!!!! thats why i'm confusedddddddddd?????????^^^^^^^^^^^^^^ LOL!
