Old 05-06-2002, 11:56 AM   #1
hbmike
My Ride: 03 530, 00 328i dead
Question Turning brake rotors?
I had BMW replace my rear pads, but they didn't replace the rotors, as they said it was still .5 above the minimum. They also did not turn the rotors as well. My service tech said that BMW does not turn their rotors.
My question, isn't this bad? Shouldn't you turn the rotors with new brake pads? Plus the old stock pads were pretty abrasive, and left the rotors with a nice lip, so the rotor is definitely not smooth.
Need some advice, as I plan on changing the rear pads to a dustless pad.
hbmike is offline   Reply With Quote
Old 05-06-2002, 12:02 PM   #2
Clem
Alpha Male
Clem's Avatar
My Ride: Twin Turbo'd Beast
Good practice is to have rotors turned when changing brake pads.
BMW does not do this because the tolerances are so close that there is not enough "meat" on the rotors to turn them.
Clem is offline   Reply With Quote
Old 05-06-2002, 12:07 PM   #3
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
Clem is right...
The lip on your rotor shouldn't be a big issue but you need to keep an eye on them to make sure your rotors are not warped.
I hate it when my dealer gives me the line, "Well, it's still within BMW spec..." Grrrr....
vinnymac is offline   Reply With Quote
Old 05-06-2002, 12:24 PM   #4
teamdfl
Slow in, slower out
My Ride: 325it
Turning rotors
In theory, you should not have to turn the rotors when just changing pads as long as the rotors are not warped. The new pads will quickly conform to any lip at the outer edge of the rotor.
In reality, factory BMW rotors are so cheap, I usually pitch them if they are more than half worn or are warped. Of course, at dealer parts prices, turning is probably an economical alternative. Once my car is outside the free maintenance period, I will do all brake work myself. At $32 each for rear rotors, I'll gladly pitch them in the trash if there is any question about wear limits or straightness.
Ed
Mod the driver first. Participate in your local BMWCCA driving school. Have you joined BMWCCA yet?
My Track Schedule
The solution to the lack of headroom in the X6
teamdfl is offline   Reply With Quote
