Old 05-11-2007, 11:01 AM   #21
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Originally Posted by Lemonsqr View Post
They use commercially available smoke machines.
Correct we use comercial grade one that cost 2-3000. Thi was just a way for you guiys aas DIY to save some money and still be able to do things correctly
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 12-18-2007, 01:12 AM   #22
Speeder
My Ride: '04 325i - '08 C300
.... yeah, but why can't you just use Carb Cleaner? That's cheaper than ... Ooops, never mind!
Speeder is offline   Reply With Quote
Old 12-18-2007, 11:10 AM   #23
jbeurotech
Regional Sponsor
Most of the newer car react to fast on small vacuum leaks and the carb clean method doesn't help to find the leak. really small leaks will not show up with carb clean hence the machine. If i could find every leak with carb clean Why would I spend all the money of a Professional smoke machine?
Seth Thorson
Old 12-18-2007, 12:43 PM   #24
Speeder
I was just joking... In fact, I'm still dealing with a possible vacuum leak and haven't even tried carb cleaner because I read your posts wherein you said it doesnt work.
Old 12-19-2007, 10:48 AM   #25
CrashTest
My Ride: 850 T5 / 79 RX7
jeez i wish I would have built one of these when I was hunting for vacuum leaks on my volvo. so many tiny leaks, the propane did nothing...
good job on the easy to follow plan!
CrashTest is offline   Reply With Quote
Old 12-19-2007, 03:10 PM   #26
Speeder
Yeah, Volvos & Fords are known for their vacuum leaks... Google P0171 P0174 (Lean Bank 1 & 2... which most probably is a vacuum leak) and see how many Ford & Volvo search results you'll come up with.
Old 12-20-2007, 08:39 AM   #27
initialandrew
My Ride: BMW 330i ZHP w/ Navi
I just threw P0171 & P0174 on my ZHP. THis sounds like a great way to check for vacuum leaks yourself, but I'm tired of dealing with my car and am letting a shop do it this time. On a side note/rant: They wanted $90 to read the code and diagnose it...I told them screw that...I have the codes here...find my vacuum leak
initialandrew is offline   Reply With Quote
Old 12-20-2007, 09:06 AM   #28
Speeder
Would you be so kind as to come back and post where that leak, if any, was located? I would really appreciate it.
It sounds to me like your car is already at the dealer, if not... check out this thread: http://forum.e46fanatics.com/showthread.php?t=360230 to see if the boot/elbow is the culprit.
Or if you're not in the mood to read 13 pages then just go to this DIY...
http://www.bmw330ci.net/maintenance/tubeelbow.php
Pretty simple, $15 to $20 for that part, a couple of scraped knuckles and its done.
Thanks in advance for the update.
Old 01-22-2008, 07:18 PM   #29
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
has anyone made one of these yet?
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 01-23-2008, 10:31 AM   #30
BarryR
My Ride: 318ci
Could this be used for a fuel tank leak as well as an engine leak ?
BarryR is offline   Reply With Quote
Old 04-06-2008, 06:38 PM   #31
abefroman
My Ride: 2000 323i
I have a hissing noise coming from the fuel rail/intake manifold area an am considering building one of these. How much current does the 12 volt source need for the glow plug to work? Has anyone else tried this?
abefroman is offline   Reply With Quote
Old 04-10-2008, 01:12 AM   #32
Deejay77
My Ride: 325cic, Wrangler, R1
Send a message via AIM to Deejay77
can you let us know what you find with the hissing sound near rail. I have the same. I see no tubes there to check for leaks.
Deejay77 is offline   Reply With Quote
Old 05-16-2008, 06:14 PM   #33
mell1n
hi
My Ride: 2000 328Ci
what if you disconnect the power to your idle speed control valve? the car won't correct for the propane, and you should hear changes in idle.
mell1n is offline   Reply With Quote
Old 09-18-2008, 11:36 AM   #34
jbeurotech
Regional Sponsor
Top as this keeps coming up TEST DON"T REPALCE!!!!!!!!!!!!
Seth Thorson
Old 10-19-2008, 01:31 PM   #35
Arsevader
My Ride: '90 325i, '02 325it
I never 'Repalce' if I can help it.
- James
'85 E30 325e
'90 E30 325i
'02 E46 325it
'03 E46 320i
'96 Volvo 850R
Arsevader is offline   Reply With Quote
Old 10-19-2008, 01:59 PM   #36
jbeurotech
Regional Sponsor
Yes it can
Seth Thorson
Old 10-20-2008, 03:32 PM   #37
nathancarter
My Ride: 02 330i
Guess I'm building one of these over the next couple of weeks... my '02 330i has been lighting up my SES light occasionally but it usually turns off (and doesn't store the code?) by the time I have my scanner handy. Yesterday I finally caught it (while I was driving down the interstate!) and it was P0174. I'm certain it's not the intake boots; I replaced those very recently as preventive maintenance.
Thankfully I have some glow plugs left over from my old Mercedes diesel. I think I have a 12V tire pump too, worst case scenario I'll rig it up to my little air compressor... I'll take some photos once it's working.
Following Seth's previously posted advice on lean-condition codes: Can the O2 sensor additive/multiplicative values be read by most OBDII scanners? I've misplaced the manual for my Innova brand scanner but can probably figure it out, IF that's something it can read. What should I be looking for?
[edit] Just read this in another thread:
Additive and multiplicative can only be read with better BMW equipment, however you can read short term and long term fuel trim which is close and can be used similarly
Any further details on how to do this, or what to look for? Most of my knowledge is in obsolete diesel engines with mechanical injection pumps.
nathancarter is offline   Reply With Quote
Old 12-17-2008, 03:08 PM   #38
plinknatord
My Ride: 2002 325i
Seth,
I too am getting P0171 & P0174. Have already inspected and re tightened all the intake hoses but no joy yet. I love the smoke machine idea (THANK YOU!). Since I already own an air compressor and an output regulator I'd rather not buy the tire pump. Can you suggest what PSI I should set the regulator for? Also, I'm guessing the right feed point for the pressurized smoke would be sealed into the intake hose just after the MAF. Is that right?
Thanks!
plinknatord is offline   Reply With Quote
Old 12-17-2008, 06:03 PM   #39
GermnBlt
My Ride: 323Ci
Send a message via AIM to GermnBlt
whats being used to hold these items together? Soft flex black pipe/drain, pvc, clear hose?
I got to make one of these, no shop around here has a smoke machine to use on my car...
So, how many pounds you push
Photobucket
GermnBlt is offline   Reply With Quote
Old 12-17-2008, 06:15 PM   #40
Custom3
My Ride: HellRot 330CI
this would have been great if it was a actual step by step DIY...that MS paint sketch doesn't help a retart like me
