Naturally Aspirated M54B30 Engine Build - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 42 votes, 5.00 average. Display Modes
Old 03-25-2007, 05:48 PM   #21
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
Old 03-25-2007, 05:51 PM   #22
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Old 03-25-2007, 05:53 PM   #23
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Old 03-25-2007, 05:55 PM   #24
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Clicky for more info on the oil pump nut issue:
Old 03-25-2007, 08:41 PM   #25
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Nice! What exactly are the plans?
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 03-25-2007, 10:22 PM   #26
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
No clue...
Old 03-26-2007, 09:44 AM   #27
325seeeye
Core Fanatic
My Ride: 325Ci, e36 325is
Yep. That is kinda scary. This is a good thread. This and the Crevier BMW Race Car thread are pretty-much the only intereting things on this forum. Good luck with whatever the hell you are going to do.
325seeeye is offline   Reply With Quote
Old 03-26-2007, 11:35 PM   #28
icosaca
My Ride: BMW AA blown 325 ci
No clue...
what exactly is that nut?????
what would have happened if it came off???
jorge saca
icosaca is offline   Reply With Quote
Old 03-26-2007, 11:40 PM   #29
Greg@UniqueDesign
Past Site Sponsor
My Ride: 330Ci
jorge saca
It holds the sprocket on that runs the oil pump. If the oil pump fails you lose oil pressure, and if you let the engine run for more than a few seconds after it comes off you'll seize your motor.
Greg@UniqueDesign is offline   Reply With Quote
Old 03-27-2007, 02:54 AM   #30
xS3x
mi casa @ technik
My Ride: 2002 330Ci
Send a message via MSN to xS3x
good luck on your project!!
xS3x is offline   Reply With Quote
Old 03-27-2007, 12:25 PM   #31
BMWintoxication
Taiwan/Vancouver/Shanghai
My Ride: Jet Black02' 325ci
Send a message via AIM to BMWintoxication Send a message via MSN to BMWintoxication
thanks for the pix!!
btw, everyone should dissect your engine to check that nuts!
Orz
BMWintoxication is offline   Reply With Quote
Old 03-27-2007, 01:50 PM   #32
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Thanks!
jorge saca
Just to expand on Greg's response:
The E46 has a lot of engine sensors, but NONE of them tell you exactly what is going on in real time. Yes the engine temperature has a gauge on the dash, but it is buffered for example. It has literally 3 positions; cold, normal, and hot. It doesn't move in real time when engine temperature changes.
Oil pressure is NOT monitored by the Engine Management System, however the oil level inside of the oil pan is monitored, as well as oil temperature. Neither of these sensors will trigger a fault code if the oil pump stops functioning. The only way to monitor oil pressure is to install an additional sensor and gauge.
The reality of the situation is that most people are too focused on driving the car when going fast, and completely ignore gauges even when they are installed within a person's field of view. Some people install huge red lights preset to go off when oil pressure drops. The sad thing is that most drivers then try to "limp" the car to the pits or their nearest shop, when the engine needs to be shut off imediately to save it.
So in this case, it's a matter of having a warning device and using it to take immediate action. Even with an upgraded oil pump, using an oil pressure gauge and emergency warning light is recomended.
Thanks, I'm having a lot of fun with it.
Old 03-27-2007, 02:40 PM   #33
325seeeye
Core Fanatic
I think the engine does monitor oil pressure, but I think only if it drops below a certain value. The oil light on the dashboard can be either yellow or red. The owners manual states that a red oil light means low oil pressure. This is only what I think based on what the owners manual states.
However, I don't have first hand knowledge where a pressure sensor is.
Old 03-27-2007, 04:23 PM   #34
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
You are correct, there is an oil pressure sensor/switch mounted by the oil filter housing. If you follow the oil feed hose that is connected to the Vanos assembly on the head down to the back of the oil filter housing, you will see this sensor/switch mounted there. The way this device appears to work is that it triggers below a certain pressure threshold.
The sensors that I mentioned previously monitor the oil in real time (varying voltage output from the sensor) where the pressure switch appears to have an open or closed value.
Old 03-27-2007, 07:53 PM   #35
Greg@UniqueDesign
Past Site Sponsor
My Ride: 330Ci
There's an a lot more expensive solution I'm working on .
Old 03-27-2007, 08:09 PM   #36
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
Are we doing something similar?
Old 03-28-2007, 11:49 AM   #37
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
jorge saca
If the nut comes off your head gets oil starved, you drive train kills itself and your motor seizes -
http://forum.e46fanatics.com/showpos...9&postcount=79
http://forum.e46fanatics.com/showthr...=179608&page=5
Tim
tim330i is offline   Reply With Quote
Old 03-28-2007, 06:34 PM   #38
Greg@UniqueDesign
Past Site Sponsor
My Ride: 330Ci
I dont know, are we?
Yeah, we kinda sorta are.
Old 03-28-2007, 09:42 PM   #39
icosaca
thanks for the info adam/ greg.....
i gotta install my oil press gauge soon...
keep up the good work
jorge saca
Old 03-30-2007, 02:49 PM   #40
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Good to see that another E46 owner has the balls to work on his own car. I just can't understand why people would take their car to a shop and let all the mechanics have the fun. Keep us updated.
