Old 02-21-2007, 03:09 PM   #1
SammyV
My Ride: CB M3
Send a message via AIM to SammyV
Bulb Out after Halogen > Xenon conversion
I read this thread
http://forum.e46fanatics.com/showthread.php?t=367566
and created what it stated, however i still have the bulb out warning on dash, any help?
I had halogen lights, and bought an HID kit from visionbulbs. Anyone have any insight as to how to trick the car into thinking there is still halogen bulbs attached?
TIA
SammyV is offline   Reply With Quote
Old 02-21-2007, 03:20 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
You can do one of 3 things: get the ecu flashed by the dealer, install a set of resistors or pull fuse 32 to disable the bulb out warning.
Old 02-21-2007, 06:39 PM   #3
SammyV
My Ride: CB M3
Nick thanks for the reply, what resistors for the headlights are you referring too? I wouldnt have a problem mounting a couple resistors to fix this error
Old 02-22-2007, 12:08 PM   #4
SammyV
My Ride: CB M3
bump
Old 02-22-2007, 01:14 PM   #5
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
My Ride: Vorsteiner 335i
Send a message via AIM to Jlevi SW
http://jlevistreetwerks.com/store/p2...duct_info.html
That ought to do the trick.
JL
Jlevi SW is offline   Reply With Quote
Old 02-28-2007, 10:16 AM   #6
SammyV
My Ride: CB M3
Originally Posted by Jlevi SW View Post
That will cure my headlight bulb out after swapping to xenons?
Same resistors i have for my LED signals?
Old 02-28-2007, 12:55 PM   #7
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
Either that, or pull fuse 32, or take it to the dealership for a reflash.
JL
