Sponsored by The Tire Rack
Old 02-22-2007, 06:50 AM   #1
farris
My Ride: 2004 M3 Coupe
Rolling Wheel Arches?
I bought 20 inch Senekas for my M3... I am having the wheel archres rolled/rolling fenders so I can drop the car... The body shop has told me that they will need to repaint all 4 quarter panels after rolling the fenders... Is this true?
Someone please inform me on this because they are going to hit me with one hell of bill.
MAny Th anks
Carbon Black M3
20 Inch Senekas
PSS9 Coilovers
A and E Stage 2 Intake
AC Schnitzer Figure 8 Exhaust
AC Schnitzer Rear DIffuser
Custom Setup with JL 12" W7 and a 1000/1
Nav
HK
Tinted
farris is offline   Reply With Quote
Old 02-22-2007, 07:10 AM   #2
WT330CI
My Ride: 330Ci Convertible
MAny Th anks
That is crazy talk if thats what they said, I would take it some were else
Rolling the fenders should not require repainting anything by any means unless there idiots and screw up th paint
WT330CI is offline   Reply With Quote
Old 02-22-2007, 07:48 AM   #3
farris
Thanks for the input... Has anyone else had this problem?
I spoke to the body shop and they stated that I might only need to repaint 1 or 2 fenders becasue the wheel size and offset require major fender work.
My Wheels are:
20x8.5 (245) front and 20x10 (285) rear. I am rolling on Toyo T1R tires. I went with these tires becasue they have a rounded sidewall.
Help would be much appreciated guys.
Thanks again
Carbon Black M3
20 Inch Senekas
PSS9 Coilovers
Nav
HK
Tinted
Old 02-22-2007, 08:21 AM   #4
325Mark
325Mark's Avatar
My Ride: is riding low!
Send a message via AIM to 325Mark Send a message via MSN to 325Mark
Wow those rears will need some serious work the fronts shouldnt be too much of a problem. Balla!
'06 E90 325i 6MT | Full M3 Kit | H&R Euro Race | VMR V710 | Colour Kidneys
325Mark is offline   Reply With Quote
Old 02-22-2007, 11:37 AM   #5
Youngbinks
My Ride: Bimmer
^^exactly, I don't see the need to have to repaint fenders or anything at all, that seems a bit extreme
Youngbinks is offline   Reply With Quote
Old 02-22-2007, 11:53 AM   #6
colombacho
My Ride: 325i
what the hell? it is just a simple job of using a heat gun and the fender rolling tool. No painting required, unless they are total jerk@$$es and chip or scratch everything off.
Maybe if you are widening the fenders, which require cutting, sanding, welding... but otherwise NO.
colombacho is offline   Reply With Quote
Old 02-22-2007, 12:45 PM   #7
Devonjordan
My Ride: e46 325i
If the job is to be done "perfectly" they will probably heat the paint to the cracking point and then bend the metal, roll your fenders. Thats why they want you to pay for paint, so they dont have to be careful.
Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
Devonjordan is offline   Reply With Quote
