Old 02-24-2007, 01:36 PM   #1
4rwheeler
My Ride: 2000 323i
LCM/LKM location?
I have been trying to figure out where it is. Is it part of the light switch? Or is it with some relays somewhere else like above the glove box? I am having the mysterious flashing (factory)Xenon problem. The dealer was useless. I have been trying to figure out if there is a seperate relay or only a lcm/lkm. Seems to happen more in the cold. Several times in the past few months I think I have it fixed, then after 2 weeks, it happens again. Driving me nuts.
4rwheeler is offline   Reply With Quote
Old 02-26-2007, 02:29 PM   #2
kneb
My Ride: 1987 325e
Send a message via AIM to kneb
It is to the left of the steering wheel on the dashboard, every time you turn on your lights you touch it. LCM (light control module) is English and LKM (licht kontroll modul) is German. It has a faceplate with different switches and buttons depending on the region which can be changed around at will. It connects with a thin ribbon cable. The actual LCM is behind the faceplate and can't be changed. It holds your VIN and mileage information as a backup to the instrument cluster. Check out this page for a diagram.
kneb is offline   Reply With Quote
Old 02-27-2007, 10:47 AM   #3
4rwheeler
My Ride: 2000 323i
Thanks for the info. It was sounding like it was part of the switch, but I couldn't find anything definitive. Can't find much info out there anymore. All the companies are keeping things to them selves. Thanks again. Jason
