Old 02-27-2007, 08:14 PM   #1
summit425
My Ride: E46 AW 323Ci
Is it easy to install fog lights?
anyone have a website for DIY?
don't know how to install the fog lights.
summit425 is offline   Reply With Quote
Old 02-27-2007, 09:44 PM   #2
BimmerZealot
My Ride: N/A
If it's the car pictured in your sig it's very easy. Looks like you have the m3 front bumper so you'll have M3/MTech fogs. If you look at your fogs from the front (we'll focus on the "RIGHT" side for now) you should see a plastic ring around the fog light itself (trim), grab the left side of the ring (right fog once again) and pull towards you, the ring should pop off. This will expose the philips screw which mounts the fogs, unscrew it and the fog should be removable at that point, be aware that there is a nut style piece on the back of the mounting bracket which you need for the screw to lock onto. On the other side same idea but pull ring off from right side instead of left. Install the same way it came off lining up the tabs on the fog with tabs on bumper.
BimmerZealot is offline   Reply With Quote
