Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 30 votes, 5.00 average. Display Modes
Old 08-15-2012, 11:54 AM   #121
xavi330i
My Ride: 2004 330i smg
Originally Posted by ac_2007 View Post
Absolutley no point to cross drilled/slotted rotors on the E46, aside from looks.
You will actually brake worse, and have less pad to disc contact.
When you experience stock brake fade, you will change your mind.
xavi330i is offline   Reply With Quote
Old 08-15-2012, 11:57 AM   #122
Wickedly
My Ride: 2016 BSM ///M2
So you recommend the OEM plain look?
Wickedly is offline   Reply With Quote
Old 08-15-2012, 12:03 PM   #123
Guest021715
Account closed.
I have never experienced such a thing, and I drive my car hard enough. Then again it is a 325 with smaller brakes, so how hard can I really drive it? Maybe on a dedicated track car, yes. But at that point you should be looking at big brake kits.
Yes. Brembo/Zimmerman discs, and textar/pagid/jurid pads.
Read more here: http://forum.e46fanatics.com/showthread.php?t=937983
Old 08-15-2012, 12:08 PM   #124
Wickedly
Thanks, Will look it up
Old 08-15-2012, 01:20 PM   #125
jdstrickland
My Ride: '94 325iC & '00 323i
Originally Posted by 01drop3naquarter View Post
Well Said .. Thanks for your post ... I was Up in the Air about what to get with my E46 ..In the Past with my E39 i Always went with Blank ATE Or Zimmerman Rotors -- and Wagner Thermoquiet Pads and Never Ever had Problems ... So With My e46 I was Thinking of getting The Pretty Cross drilled rotors ...Since I Drive The Car Like a old man most of the time I rarely heat up the brakes .. i always thought the OEM setup was great to begin with ... Thanks again For your insight.
Willie
One, you said, "good point," to a post that has been sleeping for almost three years.
Two, I think the general concensus is that for a daily driver that trudges up and down the freeway taking you to the office, there is not much point in slotted and drilled rotors.
I put slotted and drilled rotors, four of them, on my E36. I never approach the limits of braking performance, so I did it for looks. The looks are good, and that part of the decision works out pretty well. I will not be doing this again, and when the pads finally wear out I will be going back to the standard rotors. I find the slots and holes -- I'm pretty sure the slots are the primary problem -- are very noisey. There is a clicking noise, like putting a playing card in the spokes of your bike as a kid.
So, get slotted and drilled rotors if you want a cool look, but you will probably never use them for any sort of performance upgrade, and you won't be aware of any difference in braking performance -- either improved or degraded. If you get drilled rotors, you really want the holes to be cast, not drilled. There are lots of brake improvements that you can make for improved performance and still have smooth-surfaced rotors.
If you are looking to slotted and cross drilled rotors specifically to enhance braking performance to meet the demands of the track, you need to do considerable homework. If you are driving to work everyday, then you can have a better look with slotted and crossdrilled rotors. I have mine purely for the look, and it's not worth it. The cost was no different, so I'm not out any money, but the comfort (noise) is degraded, and that makes them a bad choice. Perhaps I am my own worst enemy, and I put them on the wrong side of the car, and this causes the noise, but I looked at several Porsches and Mercedes AMGs to see how the hole pattern goes, and matched. Actually, I discovered that the holes/slots can be orientated slanted toward the front or the rear, and I decided that I would install mine with the slant to the front. I suspect now that a consideration for the orientation has something to do with the angle that the slots meet with the pads because if the slots and pads are parallel lines, then the pads will bounce over the edge of the slots and this can produce the clicking noises.
If you are racing the car, do more homework. If you are like the other 99.999% of the human race, then go for style if you want -- the performance difference is negligible, either for improvements or degradations.
Old 08-15-2012, 01:22 PM   #126
jdstrickland
Assuming the slots are what makes the noise on my car, get cross drilled rotors and forget about having them slotted.
Old 08-15-2012, 03:51 PM   #127
IrunBimmer
My Ride: 323i
Slotted are made to cool off your rotors. With many of the 3-series like most people said here its more for show. Your breaks will heat up but not that much
IrunBimmer is offline   Reply With Quote
Old 08-15-2012, 03:51 PM   #128
IrunBimmer
My Ride: 323i
Brakes*
Old 08-15-2012, 03:56 PM   #129
Wickedly
How about just Cross Drilled Rotors?
this are slotted rotors right?
And of course, this are both
But OEM will look like this
Old 08-15-2012, 04:17 PM   #130
lsteg
My Ride: 2001 330ci
^ this
\thread
lsteg is offline   Reply With Quote
Old 08-15-2012, 04:56 PM   #131
IrunBimmer
My Ride: 323i
Buy whatever is cheapest. Their all good. Do it yourself too shops will charge to much
Old 08-15-2012, 04:59 PM   #132
Patton323I
My Ride: R1100GS E46 E53
I have a set of used oem rotors ill sell you for dirt cheep. there fine, I just swapped them for drilled slotted
Patton323I is offline   Reply With Quote
Old 08-15-2012, 06:02 PM   #133
InZain08
My Ride: 330ci
I just bought a set of Cross Drilled rotors from r1concepts' premium line along with some new posiquiet pads and SS lines from stoptech. Haven't installed them yet but I don't expect any type of failure from them as I don't drive my car around town like I might on the track. Just hope for the best I suppose!
InZain08 is offline   Reply With Quote
Old 08-15-2012, 06:25 PM   #134
My Ride: 2016 Lexus
So you're only 50% sure they won't fail? Not bad odds I guess. They're just brakes, afterall!
Old 08-15-2012, 06:40 PM   #135
InZain08
My Ride: 330ci
Nothing is ever set in stone. I have full confidence in my abilities to properly install these parts on my car. I'm sure many manufacturers have had quality control issues in the past and I'm not entirely ruling out that possibility.
Old 08-15-2012, 06:44 PM   #136
My Ride: 2016 Lexus
Cornbread Racing Kamikaze F1 R1 RS-R Type-R Concept Racing Illusion MAXSPEED V1 brake rotors
vs.
Brembo/ATE/Zimmerman/BMW
You decide.
Old 08-15-2012, 06:46 PM   #137
InZain08
My Ride: 330ci
Already did. I'll let everyone know how the fitment and installation goes along with a test drive
Old 08-15-2012, 06:56 PM   #138
My Ride: 2016 Lexus
Of course they'll fit and stop your car. That won't qualify as a review, and really says nothing about the quality of the parts. Believe me, we've been down this road before.
Don't ever skimp on brakes.
Old 08-15-2012, 10:55 PM   #139
Patton323I
Mine are stop-tech Cross drilled and slotted. Got them from Turner Motorsport for like $180 for just the front set. But they have a warranty and are a known brand. I am pleased.
Old 08-23-2012, 03:52 PM   #140
Mr_325
My Ride: 2007 X5 3.0Si
glad to see this thread bumped
i think before summer of next year i'll be going cross drilled/slotted (for looks of course)
would you guys suggest brembo or stoptech? i'll be using Akebono pads, have had them since i bought the car a few years ago and love them.
Mr_325 is offline   Reply With Quote
