Xenon retrofit flicker when driving - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-06-2007, 01:51 AM   #1
force
My Ride: 325i 2005
I have retrofitted my bi-xenons and they worked for like a month, but now when I am driving the passenger one flickers on and off like every 5-10 seconds, the driver one also every once in a while. I never had my LCM flashed or anything because I never got any lights going on in the dash. When the car is parked and I leave the lights on, I don't have this problem at all. Any idea what could be causing this? Perhaps a battery or alternator problem?
force is offline   Reply With Quote
Old 03-07-2007, 02:06 PM   #2
force
My Ride: 325i 2005
What does it mean when the xenon's first turn on and the red light with a picture of a car and a light goes on for a second? Is something broken? Is that just saying I turned my xenons on?
Old 03-10-2007, 09:37 PM   #3
e.barr
My Ride: 320ci
I think you will have to get the lcm flashed to stop the flicker, When the car is running a pulse of voltage is sent to each light so that the lcm can determine wheather the bulb is ok or not.
Because the xenon lights have a 35 watt bulb instead of the usual 55 watt halogen the lcm thinks that there is a problem and indicates this with the red car and light symbol on the dash.
Your lights flash because the xenon light is more sensitive to the pulse voltage than the halogens.
So get your lcm flashed and your problems should be sorted
e.barr is offline   Reply With Quote
Old 03-12-2007, 02:40 PM   #4
Scott
My Ride: 03 330 ZHP 01 X5 3.0
Um, no.
The halogen bulb has a FILAMENT and offers resistance, which is what the LCM is looking for. The HID bulb has no filament and no measurable resistance. The LCM interprets the lack of resistance as a burned out bulb and throws a dash error/reduced voltage.
Has nothing to do with a "pulse" or the wattage of the bulbs.
03 330i ZHP
01 X5 3.0i
73 MGB Roadster
79 Triumph Spitfire 1500
Scott is offline   Reply With Quote
Old 03-12-2007, 02:44 PM   #5
neejkoob
My Ride: M3
Not sure if it is resistance...
I installed resistor packs on my P46 and it didn't do anything for the flickering...
BTW those resistor packs get really hot (burned my fingers)
neejkoob is offline   Reply With Quote
Old 03-12-2007, 03:07 PM   #6
Scott
Well, a resistor pack is effectively just a dummy load. The current needs to go somewhere. It ends up as heat.
Do it the OEM way and get the LCM coded for xenons.
03 330i ZHP
01 X5 3.0i
73 MGB Roadster
Old 03-13-2007, 02:05 PM   #7
e.barr
My Ride: 320ci
Ok Scott let me put it this way the LCM does send a small voltage measured in milliamps to the headlights/taillights etc every 30 sec or so (pulse) it then measures return voltage and resistance.
If you fit either xenons or LED's without reprogramming the LCM It will look for the correct return voltage and resistance if it does not receive the correct readings it will assume that there is a fault with the light/s
Red warning symbol on dash
Its this "pulse" of voltage that gives you a flikering effect with the xenons and the LED taillights.
If you have ever seen a car fitted with OEM LED tails and with an unprogrammed LCM you will see once the Ignition is switched on that the tails fliker like a christmas tree and then stop for 30 sec then start to fliker again, the LCM test pulse voltage is enough to operate the LED lights.
The same thing happens to the xenons thats all Iam saying
Old 03-14-2007, 06:06 AM   #8
Titansilber330D
My Ride: 330D Sport
I added a 4700uf 25v capacitor as detailed in this thread http://forum.e46fanatics.com/showthread.php?t=366215
Solved the bulb out warning and flickering I had before.
Titansilber330D is offline   Reply With Quote
Old 03-14-2007, 11:49 AM   #9
neejkoob
My Ride: M3
I second...
I picked up two 4700uf 35v capacitors at radio shack and it did the job...flickering and dead bulb warning...GONE
