Thread Tools Search this Thread Rating: Thread Rating: 167 votes, 5.00 average. Display Modes
Old 12-11-2007, 02:33 PM   #61
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
its still not workin!
maybe its cus i shortened the prongs on the battery but it would fit with it.
BreakMyWallet is offline   Reply With Quote
Old 12-11-2007, 02:49 PM   #62
BreakMyWallet
i just realized that is the problem. damnit. lol
Old 12-21-2007, 01:51 PM   #63
colinschick
My Ride: 325ci
i did everything up to the last step, including reprogramming the key.... although i did it only before i glued everything back together, and i just used the key, and the circut board to do it. now my lock and truck will work, but not unlock??? does that have anything to do with the sides of the key not together?? could there be a problem in the sensor/control in the car that is responsible for unlocking the car?? does anyone have any ideas? thanks.
colinschick is offline   Reply With Quote
Old 01-05-2008, 02:18 AM   #64
bmwsmurf
My Ride: 330ci
Anyone got an extra key fob they don't want
Visit the 3 series heritage site: link
bmwsmurf is offline   Reply With Quote
Old 01-24-2008, 11:41 PM   #65
LO187KO
My Ride: BMW 325 E46
Thanks For Saving Me 300 Bucks
it worked great, if it wasnt for your posting i would have spent 300 bucks for nothing. soldering iron from radio shack $7 bucks, battery from mouser $4.73, research on web for recoding key $0, locking and unlocking my car with my remote key $$priceless$$. it feels great to have a working key.....
LO187KO is offline   Reply With Quote
Old 01-25-2008, 05:42 PM   #66
bmwsmurf
My Ride: 330ci
Man how did you guys manage to slice it open with a blade without damaging the circuit board
Old 01-27-2008, 05:22 PM   #67
9doorz
My Ride: 2001 330ci vert
This was awsome DIY...it work great for me I replaced my battery and now both my keys work.... i order my battery from these guys...cheaper shipping to canada
http://search.digikey.com/scripts/Dk...l?name=P081-ND
9doorz is offline   Reply With Quote
Old 01-28-2008, 01:34 PM   #68
9doorz
start at the part where the key can attach to a key chain...there are no circuit there...Once you get through that you can have an idea how much plastic and how deep you need to go around the key
Old 01-28-2008, 01:35 PM   #69
9doorz
i also shortened the prongs on the battery they are to long. Just make sure you solder it correct.
Old 03-14-2008, 11:45 AM   #70
///Rogu3
My Ride: has M-Style
Woohoo!!! Remote works again after almost 1-1/2 years...I couldn't bring myself to pay that much money for a key either! But for $12 and some elbow grease...what the heck!
I ordered the battery from www.mouser.com and it came in the next day...apparently they are based in Texas not too far from Houston. The whole job took me 45 minutes to complete including super glue curing time.
I recommend wearing a pair of fitted Mechanic gloves and a few folded shop towels to protect your hands from the blade. I used a brand new standard blade to ensure that the cuts could be made easily and cleanly.
One thing to keep in mind is that when you start cutting at the far end of the key, you need to cut past the voided space into the next wall of the key...I know this may be obvious to some but it took me a few minutes to realize this
Instead of a chisel, I used a large toe nail clipper to remove old solder to free up the battery. The prongs on the new battery are longer but it didn't really hinder the installation process too much. On the new battery that I received, I couldn't make the negative prong fit without removing it completely from the battery...it didn't seem to affect anything for me since I can clearly see that it still made contact with the battery once I completed the soldering process.
I used Scotch Super Glue Gel since I wanted a little more time to line everything up before the bonding process completed. I've used this product before and it holds up extremely well under daily use.
Once the super glue cured, I followed the programming instructions from an earlier post and it worked on the very first try!
Mad Props to the OP...and everyone else for sharing!
Wifey's car is faster....booooooooo
///Rogu3 is offline   Reply With Quote
Old 03-15-2008, 05:22 AM   #71
bmwsmurf
My Ride: 330ci
Did any of you guys measure the voltage on your old battery? Mine still had 3+ volts.
Old 03-24-2008, 09:59 PM   #72
thfrazer
My Ride: 2000 323i
Hello Everyone!
If anyone is still reading this thread please give me your thoughts on my key and lock issue with my 2000 323i:
1) My remote will lock/unlock the door locks only on an intermittent basis. I have reinitialized them via the instructions elsewhere on this forum and they do what they are supposed to do during the reinitialization, but shortly revert back to their intermittent ways.
2) The trunk unlock function works all the time and from a fair distance away.
3) The central unlock button inside the car works even less often than the key remote.
Because the central unlock button doesn't work very often I believe the remote battery is not the problem. What do you think?
It is my understanding that the electrical relays for the locking system are behind the glove box. Is that true? And if so can I replace the relays? And if that is possible where can I get them?
Thank you in advance for your thoughts and input on this issue.
Tom
thfrazer is offline   Reply With Quote
Old 04-14-2008, 11:04 AM   #73
YMMV
My Ride: '01 330 CI
How is the battery being charged?
I cut open the key and noticed that there is no contact between the key and the rest of the circuit board. How is the battery being charged when inserted in the ignition?
YMMV is offline   Reply With Quote
Old 04-14-2008, 03:01 PM   #74
E46iT
My Ride: 2004 325i Touring
i think the technology used to charge the battery is based on the principle of magnetic inductive power transfer. Also, used in products like rechargeable electric toothbrushes. therfore, if you use your wireless toothbrush docking station you can recharge the battery by just placing on top of the charging prong on the docking station.
E46iT is offline   Reply With Quote
Old 04-15-2008, 02:20 PM   #75
YMMV
My Ride: '01 330 CI
Thanks for pointing that out. i see that this type of contactless system is suited to a multitude of difficult environments including water, dust or through concrete.
Old 05-01-2008, 12:54 AM   #76
phatm3
My Ride: M3 SMGII Convertible
Originally Posted by Geno68 View Post
Jason77,
I am on mouser.com looking for a battery and I get two batteries for VL2020.
1. VL Lithium Coin Cell Batteries 3V 20mAH 2 PIN VERT
2. VL Lithium Coin Cell Batteries 3V 20mAH 2 PIN HORZ
Which one do I need?
I just ordered and received the HORZ, and it's the wrong one!
the prongs are 180 degrees apart like inposts #1 and again in #3.
you need the vert (like attached pic) with prongs closer together.
http://www.suzushoweb.com/s_img/43a2544b26de1.jpg
i will try to use the horz and make it work. which mean unsoldering the tabs of the battery. more to follow...
Doey
phatm3 is offline   Reply With Quote
Old 05-02-2008, 03:41 PM   #77
Snik
Snik's Avatar
My Ride: IR M3 Vert.
is the procedure the same for the older keys?
Do you ride a sportbike?
Old 05-02-2008, 04:32 PM   #78
antzcrashing
My Ride: 2006 330i
thanks i was wondering this
Thanks this will be easier now
antzcrashing is offline   Reply With Quote
Old 05-06-2008, 11:55 PM   #79
ZZdark
My Ride: 01 325i
So regarding the battery on mouser, http://www.mouser.com/Search/Refine....user_Wildcards
do we have a definitive answer on whether to buy the 1st one with the VC or the 2nd one with the HF?
ZZdark is offline   Reply With Quote
Old 05-07-2008, 07:25 AM   #80
antzcrashing
My Ride: 2006 330i
The Vert is the one to buy (VC)
