Sponsored by The Tire Rack
Old 03-08-2007, 07:12 PM   #1
greydart
My Ride: E90 330i
Alignment question for the techies
I just got a $600 quote to install my suspension kit. (too high, I know)
The mechanic said it's a lot more than other places quote because the BMW needs to be "sandbagged" for the alignment. I'm sure he means weight needs to be added to certain points to acheive the correct results.
Is this true? Are shops who don't do this doing it wrong? I've had prev. alignments done for right around $60 on this car with no issues. My tires wear fine, steering is arrow straight, negative camber looks right for a BMW.
Just looking for someone to fill in the blanks. This guy is not doing the install but he got me curious about the alignment terms.
greydart is offline   Reply With Quote
Old 03-08-2007, 07:24 PM   #2
jpr
My Ride: '99 323i
You need to have the correct weight in the car in order if you are trying to match the official BMW specs, which are given in that condition.
There's a thread or ten about that and other alignment questions, here's a couple to get you started.
http://forum.e46fanatics.com/showthread.php?t=416660
http://forum.e46fanatics.com/showthread.php?t=439450
jpr is offline   Reply With Quote
Old 03-08-2007, 07:45 PM   #3
greydart
My Ride: E90 330i
Thanks JPR. Very informative.
Old 03-11-2007, 03:09 PM   #4
gtrskyline34
My Ride: 2001 BMW 330ci White
The weights are what preventing me to do my own alignment in our shop, we do not have the correct weights...
gtrskyline34 is offline   Reply With Quote
Old 03-11-2007, 03:24 PM   #5
jpr
My Ride: '99 323i
Bear in mind you need the weights to do an alignment - you only need them to match the alignment readings as given by the BMW specs.
More reading here -
http://forum.e46fanatics.com/showthread.php?t=436527
http://forum.e46fanatics.com/showthread.php?t=296171
Old 03-15-2007, 10:16 PM   #6
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
I just want to thank jpr and all the other techs that have provided good info. I just got an alignment today after my mechanic changed out tie-rods trying to get to a front end rattle that I have over bumps. so anyway,
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 03-16-2007, 09:09 AM   #7
jpr
My Ride: '99 323i
Originally Posted by jpr View Post
Bear in mind you don't need the weights to do an alignment - you only need them to match the alignment readings as given by the BMW specs.
More reading here -
Just noticed I left an important word out of the prior post, corrected in bold above. Hopefully people were able to read between the lines, but my apologies for any confusion I may have sown.
You're certainly welcome. It was a bad alignment experience that first led me to this forum and I've since become a bit obsessive on the issue. But the nice doctor has a pill he says can help me...
Old 12-28-2009, 04:42 AM   #8
02gtstang
My Ride: 2005 zhp coupe
ive never aligned my car with the weigths and it seems to do pretty good and go straight.
2001 325i sport 5spd topaz blue R.I.P.
2005 330ci zhp 6spd black on black
02gtstang is offline   Reply With Quote
