Old 03-12-2007, 10:03 AM   #1
sandman512
My Ride: 2005 325I
I have the P46S and for some reason on the
pass. side, I get a light out warning. It is the High Beam light. It seems to come loose from the housing. I take it out, re-seat the bulb and then re insert it. The problem is that when I re insert it, it does NOT seem snug, there seems to be some play. Any advice? THANKS!!
sandman512 is offline   Reply With Quote
Old 03-12-2007, 10:42 AM   #2
Aerick
My Ride: 2003 M3
I have the same problem w/ the highbeam bulb mounting improperly on my P46s, albeit they stay in place.
You should only get a bulb error if they're not plugged in though, not if you're loosely mounted.
I just have mine twisted in as they fit
Aerick is offline   Reply With Quote
Old 03-12-2007, 10:47 AM   #3
sandman512
My Ride: 2005 325I
What happens, at least I think, is that it does not fit snug into the housing. Since that happens, it shakes and makes the bulb itself loosen up from the socket.
Old 03-12-2007, 10:54 AM   #4
BMW Loe
My Ride: is dirty
Had the same issue when I had the P46's. The trick I learned was that the bulb holder can not sit quite flush with the the back side of the headlight (maybe 3-4mm gap) so that it can run on its "track" to hold the bulb in place.
E92 335i 6spd
BMS JB4 stg 3, BMS DCI, CM methanol injection
04 M3 sold
03 330Ci sold
BMW Loe is offline   Reply With Quote
Old 03-12-2007, 02:25 PM   #5
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
My Ride: Vorsteiner 335i
Send a message via AIM to Jlevi SW
Yep - there is a "track" - keep at it
JL
Jlevi SW is offline   Reply With Quote
Old 03-12-2007, 03:36 PM   #6
sandman512
My Ride: 2005 325I
THANKS for the tip! I think I got it.
