Old 03-02-2007, 06:43 PM   #1
hx288
My Ride: 2001 BMW 325I
Cylinder 4 - missfire
The check engine soonwarning message came on, so I took my car to the shop for a code read. The code said "Cylinder #4 - missfire".
What does that means and how to fix it? Any help would be appreciated!
The mechanic told me that it would cost $200 to fix this, but I just want to see if I could fix it myself.
hx288 is offline   Reply With Quote
Old 03-02-2007, 07:49 PM   #2
325myAZ
My Ride: 2001 325i
Did the mechanic mention what he'd be doing to correct the problem? Replacing the coil etc.
Ultimately it comes down to whether the mechanic really KNOWs what component is causing the issue. Until he tells you what he's going to do to fix the problem, we can't really determine if it's something that you can fix or not.
IF it's the coil, it's a very easy fix. A single coil will run you around $60 and a new spark plug connector boot will add around $10.
325myAZ is offline   Reply With Quote
Old 03-02-2007, 10:23 PM   #3
hx288
You are right on. The mechanic said that the coil need to be replaced. Please provide instruction for this fix. Thanks for your response!
Old 03-03-2007, 11:46 AM   #4
325myAZ
My Ride: 2001 325i
You're in luck if that's all it is!
You can buy a replacement coil and connector boot from www.autohausaz.com for around $57 plus shipping. These guys are very quick to get your order on the way. If you order in the morning, it usually ships that afternoon... they're great!
Here's the DIY. It's for replacing spark plugs, but you have to remove the coils first... so all you need to do is pay attention to the coil removal procedure. It'll probably take you under 30 minutes to do it. And you'll save $150!
http://e46fanatics.com/howto/howtode...hp?howto_id=44
Old 03-03-2007, 12:29 PM   #5
hx288
325myaz,
Which is the #4 coil? I just want to make sure I replace the right one.
Old 03-03-2007, 05:52 PM   #6
325myAZ
My Ride: 2001 325i
Here's how to figure that:
passenger . . . . . driver
. .. ... . .. 6
. .. ... . .. 5
. .. ... . .. 4
. .. ... . .. 3
. .. ... . .. 2
. .. ... . .. 1
- -- -- Front of Car
Old 03-03-2007, 07:21 PM   #7
hx288
325myAZ,
Thank very much for your help. This forum is great! I ordered the parts and will do the repair myself.
Old 03-04-2007, 12:38 PM   #8
330 HRE
Banned
My Ride: 330
How many miles do you have on your coils? There is a recall on these coils and they are good for 80k, the warranty that is. Call up your dealer and see if they will replace it for you under the coil recall. Doesn't matter if you have the Bemi or Bosche ones. This is a common problem. The second thing is, it can be your spark plugs misfired being not being ever changed.
330 HRE is offline   Reply With Quote
Old 03-04-2007, 06:11 PM   #9
BMWF18
My Ride: Truck
The recall only covers bremi coils, and they replace them wether they fail or not.
BMWF18 is offline   Reply With Quote
Old 03-06-2007, 05:24 PM   #10
hx288
I checked with the local dealer and they told me that there was no recall on my car.
Old 03-07-2007, 12:12 AM   #11
325myAZ
My Ride: 2001 325i
In which case, you have Bosch coils, and the number 4 has failed. (Or at least that's what your mechanic has told you.)
Depending upon how many miles you have on the engine, you might want to consider replacing the spark plugs while you've got the cover removed...
Old 03-07-2007, 02:38 AM   #12
330 HRE
Banned
My Ride: 330
Swap the coils to make sure it is a coil problem and not another problem
Old 03-07-2007, 12:56 PM   #13
hx288
Thanks for all the tips guys. I ordered the coil and connector, and they are scheduled to come tomorrow. Will get back and let you know how it goes.
Old 03-09-2007, 06:12 PM   #14
hx288
My parts came today. I changed the coil and that took care of the problem. Thanks for all your help.
My car has close to 74000 miles on it. Is it time for me to replace the spark plugs?
Old 03-09-2007, 06:20 PM   #15
330 HRE
Banned
My Ride: 330
If you never changed them before, then I would change them out. Supposely they are good for 100k, but I usually change them out roughly about every 30k or so.
Old 03-12-2007, 11:14 AM   #16
hx288
330 HRE,
What brand of Spark plugs should I use?
Old 03-12-2007, 09:26 PM   #17
FalconGuy
My Ride: 2003 325Ci
Send a message via AIM to FalconGuy
OEM is a good plug and shockingly cheap, dont fall for hype, there is no gain in any other plug
FalconGuy is offline   Reply With Quote
