Old 03-13-2007, 07:23 AM   #1
bimmerMe
My Ride: 06 330i
Swapping stock light housing with Projector lenses
Alright this one might be a tricky one, donnu if anybody did it before or not? but won't hurt to ask....
There is an auction for projector lenses from a Xenon OEM headlight, can I get these and replace them with the low beam headlights in my stock '99 323i ?
cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=320091236039&sspagename=ADME:L:RTQ:CA:1
here are some measurements as well:
bimmerMe is offline   Reply With Quote
Old 03-13-2007, 08:33 AM   #2
BlkE4600
My Ride: 99' 323i
I was also curious as to whether this can be done or not.....same car...323i ('99). Or would it be a better idea to just save up for the P46 headlamps that come with angel eyes?
-Bill
BlkE4600 is offline   Reply With Quote
Old 03-13-2007, 10:53 AM   #3
Canuck328i
My Ride: 09 Altima Cpe
There are two other important items missing for each side: the ballast/ignitor combo and the reflector assembly. The ballast/ignitor is needed to fire the xenon bulbs, and the reflector housing holds the projector in place.
Technically it is "possible" to assemble these into the halogen housings using your existing halogen bulbs. But without the above items you would need to modify either the projector or halogen bulb (or both) to fit the halogen into the projector AND you would need to do some fairly major modification to the halogen reflector assembly to attach the projector. It would be a lot of work.
You could also pick up a HID conversion kit to get the HID effect, but after all is said and done you'd be better off getting a set of used OEM assemblies complete (or P46s). Probably would be cheaper too.
Mark
Canuck328i is offline   Reply With Quote
Old 03-13-2007, 03:07 PM   #4
BMW Loe
My Ride: is dirty
Mounting the projector using a halogen assembly is easy, it's the aiming (making sure your right/left and up/down on both side is aligned with the highbeams on both sides) thats difficult.
Like stated above, its easier to just use a Xenon headlight frame.
E92 335i 6spd
BMS JB4 stg 3, BMS DCI, CM methanol injection
04 M3 sold
03 330Ci sold
BMW Loe is offline   Reply With Quote
Old 03-14-2007, 02:25 AM   #5
bimmerMe
My Ride: 06 330i
Thanks everyone for the input, I guess I will keep an eye for any forum member selling a pair of projector headlights better
