Old 03-15-2007, 02:36 AM   #1
328Ci_BMW
My Ride: 00 328Ci
Fog light issue!!!HELP NEEDED
Well I got a 00 328ci and I bought some cheap fog light bulbs from ebay. Supposelly the bulbs are a lot brighter than the stock ones. Well after installing the new bulbs my fuse keep getting burned out for some reason. I did it like three times. Any suggestions to what it might be? Thanks in advanced.
BTW the bulbs from ebay are also 9006.
328Ci_BMW is offline   Reply With Quote
Old 03-15-2007, 02:41 AM   #2
330rideR
My Ride: 330ci
How many watts are the bulbs?
330rideR is offline   Reply With Quote
Old 03-15-2007, 03:44 AM   #3
summit425
My Ride: E46 AW 323Ci
If you put HID fog light you need HID conversion kit to do that.
It is same work as you change halogen to HID. (you need a conversion to do that) That will cost $150-200 for that kit.
summit425 is offline   Reply With Quote
Old 03-15-2007, 03:45 AM   #4
summit425
If the bulb is look like HID, I don't know what is the problem...
should be fine.. but I am sure you bought HID fog bulb.. that is why i guess
Old 03-15-2007, 04:48 AM   #5
328Ci_BMW
My Ride: 00 328Ci
Info on the bulbs are the following: 9006 12V 55W Xenon-Krypton by Euro Effects(***).
Old 03-15-2007, 04:52 AM   #6
sillieidiot
My Ride: '06 AW 330ci
so it's fine when you put in the original bulb?
Old 03-15-2007, 07:31 PM   #7
328Ci_BMW
My Ride: 00 328Ci
I would have to replace a new fuse but yes it works fine with the stock blubs.
Old 03-16-2007, 03:25 AM   #8
328Ci_BMW
My Ride: 00 328Ci
It is true that if you use D2S bulbs rather it is 6000k or 8000k, you can use your OEM ballaster an igniter for the Fogs?
Old 03-16-2007, 03:41 AM   #9
sillieidiot
you can use the d2s (6000k or 8000k) with your OEM ballasts and igniters, but you won't be able to put them in the fogs unless you modify your fogs
