Old 05-06-2002, 05:00 PM   #1
kidzero
My Ride: 02' M3
Send a message via AIM to kidzero
dome lights...
hey can someone tell me how i would replace the dome bulbs in the bmw interior? i dont' want to jack it open and break it...
kidzero is offline   Reply With Quote
Old 05-06-2002, 05:25 PM   #2
BMWintoxication
Taiwan/Vancouver/Shanghai
My Ride: Jet Black02' 325ci
Send a message via AIM to BMWintoxication Send a message via MSN to BMWintoxication
I think you have to jack them out..... it's the only way..
Orz
BMWintoxication is offline   Reply With Quote
Old 05-06-2002, 06:41 PM   #3
kidzero
My Ride: 02' M3
i dunno are yuo sure abuot jacking it out???? i need to know from someone who has done it....
Old 05-06-2002, 08:14 PM   #4
mcabr
Just Marinatin'
mcabr's Avatar
My Ride: Chikatetsu
Just get a flathead screwdriver
and stick it in the edge closest to you not the window and gently pry down. Then disconnect the wire attached to it and then you need a small phillips to undo the screws holding the buttons on. Then you should have access to your lights for changing. Hope that helps.
mcabr is offline   Reply With Quote
Old 05-06-2002, 08:21 PM   #5
amitv85
ROI-ndian
My Ride: is oOoOoUT
Send a message via AIM to amitv85
changed mine, yea u use a screw driver.....look in owners manuel says it right there wit a diagram even i think
Dave Moss: What's your name?
Blake: F**k you. That's my name.
Blake: You know why, mister? 'Cause you drove a Hyundai to get here tonight, I drove an eighty thousand dollar BMW. *That's* my name
amitv85 is offline   Reply With Quote
Old 05-07-2002, 04:29 PM   #6
kidzero
My Ride: 02' M3
so gently stick flat bed in and pry it out will work for both the front dome lights and back??
Old 05-07-2002, 04:52 PM   #7
mcabr
Just Marinatin'
mcabr's Avatar
My Ride: Chikatetsu
Definitely
it will work for the front just pry from the middle and it pops right out. For the back I am not that sure you might just want to check the owners manual.
Old 05-07-2002, 06:32 PM   #8
kidzero
My Ride: 02' M3
heh there are nothing about dome lights in the manual... went through it many times.. i'll try the front ones.. thanks a lot.
