Old 03-19-2007, 06:51 PM   #1
Limited_Slip
Banned
My Ride: e30
xenon ocassionally flickers when light is OFF
I saw the weirdiest thing today. I started my car. The light is off (in off position) because it was daylight of course. I got out of my car to run to the house. I ran back to my car and noticed that the xenon/projector was flickering. It was flickering at full power (ie...ON, OFF, ON, OFF at 4300K). The flickering was more like low power (ie...same brightness as daytime running light).
It was odd so I went and turn on my lights. Light turn on pefectly. No flicker. Nothing.
Turn off lights again and the bulb is flickering at a low amperage/wattage.
Both side is doing this. Weird
Limited_Slip is offline   Reply With Quote
Old 03-21-2007, 03:35 PM   #2
Titansilber330D
My Ride: 330D Sport
Your battery might be running low. I know that sounds weird, but that was the case with a friend's car.
If the battery is fine, then I would point the finger at the LCM next.
Titansilber330D is offline   Reply With Quote
Old 03-21-2007, 04:19 PM   #3
e.barr
My Ride: 320ci
Hi if your car was retrofitted with xenons you may need to have the LCM reprogrammed/reflashed.
The flickering is usually the LCM sending out a signal to the lights to see if they are all working ok, your xenons are sensitive to this signal and briefly light up.
e.barr is offline   Reply With Quote
Old 04-03-2007, 10:39 PM   #4
Limited_Slip
Banned
My Ride: e30
Update.
This problem is still bugging me. it did not go away. My car has OEM xenon from the factory.
Here is the observation.
When everything is working correctly, my ballast is getting a 0.3 volt reading which is normal. When the strobbing effect occurs, I remeasure the voltage and I find out that it is around 11 volts.
Therefore, I now conclude that the LCM is powering my headlights even though the switch is on the "off" position.
Additionally, my tail lights is on which is also very weird. The tail light is only on when you turn on your headlights. However, when the strobbing effects occur my tail light gets activated too. This is proof that my LCM is pushing out juice even though the switch is in the "off" postition.
Old 04-04-2007, 12:57 PM   #5
4g63GSX
My Ride: 07 RRS 03 325 94 GSX
Do you have any other lighting mods? Clear corners/tails/LEDs?
I was also thinking bad ballast, but both of them are doing it...
4g63GSX is offline   Reply With Quote
Old 04-04-2007, 05:32 PM   #6
Limited_Slip
Banned
My Ride: e30
No I don't. This problem just occur recently. it comes and it goes. it is really weird.
Old 04-04-2007, 05:55 PM   #7
BoxCarRacer
My Ride: E46 & E70
i notice my passenger side light do that sometimes but my flickers whie the car is running and with xenons on, i just took the bulb out to inspect it and reinstalled and it worked fine ever since.
BoxCarRacer is offline   Reply With Quote
Old 05-17-2007, 12:20 PM   #8
Limited_Slip
Banned
My Ride: e30
UPDATE:
The xenon flickering / strobbing occurs 24/7.
This only happens if the headlights is OFF.
If I turn the headlights ON there is no flickering or strobbing.
I measured the voltage to the xenon headlights when it is strobbing. my volt meters read 11 volts.
Something is causing the headlight and tail light to TURN ON even though the LCM is on the OFF position.
