Old 03-24-2007, 04:21 PM   #1
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
M54 Oil pump nut warning.
All,
I've been tearing down my engine for a complete rebuild this past week. Today when I went to remove the oil pump, I found the oil pump nut loose. I touched it with my finger and it spun!
I don't know how long it has been like this, but it sent a shiver down my neck. If I hadn't decided to rebuild my engine, I may not have checked the oil pump nut, and I'm fairly certain the sprocket would have come off. This would result in a total loss of oil pressure, and as a result, my engine would get toasted.
For those of you that race your car, and use an increased engine RPM limit like the Shark Injector provides, beware. My engine at the time of tear down had about 70k miles.
Old 03-24-2007, 04:37 PM   #2
teamdfl
Slow in, slower out
My Ride: 325it
Sadly, this has been an issue with all M5x/S5x motors since the mid 90s.
Mod the driver. Participate in your local BMWCCA autocross or driving school. Have you joined BMWCCA yet?
teamdfl is offline   Reply With Quote
Old 03-25-2007, 02:51 AM   #3
Greg@UniqueDesign
Past Site Sponsor
My Ride: 330Ci
I'm waiting for TC Kline to call me when my oil pump gets in .
Greg@UniqueDesign is offline   Reply With Quote
Old 03-25-2007, 03:43 AM   #4
UniqueEDesign
TRACK EXPERTS
My Ride: Worlds Fastest Non-M
Send a message via AIM to UniqueEDesign
+1 on the importance of this topic- far too often overlooked and seems to be across the board on the E46 platform.
Copy cat
UniqueEDesign is offline   Reply With Quote
Old 03-25-2007, 08:22 AM   #5
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Originally Posted by pei330ci View Post
All,
I think it's a common problem for tricked out e46's... I know that on high revving e36's there's been cases where the pump just completely flew off....
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 03-27-2007, 02:27 PM   #6
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
My first motor was junked (under warranty) because my nut came off and I lost all oil pressure!
Tim
tim330i is online now   Reply With Quote
Old 04-02-2007, 12:44 AM   #7
gnathologist
My Ride: BMW & Lex
Is it simple to do a preventive maintenance on this nut or does the engine have to be overhauled?
gnathologist is offline   Reply With Quote
Old 04-02-2007, 02:09 AM   #8
Limited_Slip
Banned
My Ride: e30
the precedure is simple. it is like a 15 min job. the hardest part is trying to gain access/clearence for the removal of the engine oil pan. this will take you all day.
bmw just use loctite (chemical compund)on the nut whereas the m3 is secured with a physical locking mechancism
Limited_Slip is offline   Reply With Quote
Old 04-02-2007, 12:27 PM   #9
dambro24
My Ride: 330ci
this is another case of the high quailty products bmw puts out. lol
i think they might use superglue on most parts and not a torque wrench
dambro24 is offline   Reply With Quote
Old 04-02-2007, 12:32 PM   #10
sakman74
Banned
My Ride: M3 Coupe
so on the e46 M3 this is not an issue ?
sakman74 is offline   Reply With Quote
Old 04-02-2007, 01:29 PM   #11
Greg@UniqueDesign
Past Site Sponsor
My Ride: 330Ci
There are actually 2 big problems with the oil pump. First, the nut can back off. Second, the shaft that holds the sprocket on can shear too.
Old 04-02-2007, 01:43 PM   #12
UKtRAINE3
UKtRAINE3's Avatar
My Ride: ///M3
Send a message via AIM to UKtRAINE3
Wouldn't you get an oil light or SES light as soon as you lost oil pressure? Your car would begin to overheat too so you'd notice by the temp gauge and therefore stop driving the car so not to cause more damage??
UKtRAINE3 is offline   Reply With Quote
Old 04-02-2007, 04:43 PM   #13
tim330i
E46Fanatics Owner
tim330i's Avatar
You have all of about 10 seconds to notice your oil light. There is no check engine light or time for the temp gauge to move (remember the stock temp gauge isn't really a gauge, it is either cold, warming up, normal or hot).
Tim
Old 04-02-2007, 07:45 PM   #14
teamdfl
Slow in, slower out
My Ride: 325it
Tim
What he said. The oil pressure idiot light is also known as the "rebuild engine" light. By the time you see it, it is too late to do anything.
Old 04-04-2007, 02:50 PM   #15
Greg@UniqueDesign
Past Site Sponsor
My Ride: 330Ci
I talked with TC Kline the other day and the machine shop who was modifying the M54 oil pump has gone under so currently they're not making/selling them .
Old 06-03-2007, 02:40 AM   #16
Greg@UniqueDesign
Past Site Sponsor
My Ride: 330Ci
So here's my new modified Oil Pump:
Old 06-03-2007, 04:22 PM   #17
mrshelley
My Ride: 2004 330i
That'll work.
I find it interesting that the BMW Motorsport shaft is actually a simpler design than the factory unit. Instead of splines, it's just a tapered shaft. The nut is not even left hand thread. Why BMW didn't do this in the first place, is beyond me. Making a taper is much easier than broaching out the splines on a shaft and sprocket.
Old 06-03-2007, 10:37 PM   #18
teamdfl
Slow in, slower out
My Ride: 325it
M54 oil pump shafts are starting to fail regularly, especially when they see track use.
Good times.
Old 06-04-2007, 01:19 AM   #19
Greg@UniqueDesign
Past Site Sponsor
My Ride: 330Ci
Originally Posted by teamdfl View Post
M54 oil pump shafts are starting to fail regularly, especially when they see track use.Good times.
For what it's worth mine saw 39 track days, most of those were shifting at 6k. It never failed, but I always had an eagle eye on that red oil light.
Old 06-04-2007, 10:31 AM   #20
mrshelley
My Ride: 2004 330i
I learned this back in 2002. At first we tried everything but soon learned that the shaft is just a bad design and no amount of welding, red Loctite and safety wire will fix the problem. I figured that in a few years, everyone would start seeing this same problem as the cars got older and more people started to track their cars.
I expect that people will soon start kicking out the bottom ends when they miss downshifts (i.e. 5th to 2nd). I can tell you that zinging the motor to around 10500 rpm will blow out three rods.
