Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
Old 03-28-2007, 03:04 PM   #21
deletedpenguin
deletedpenguin's Avatar
My Ride: is gone!
Any idea how long brake pads last under normal driving conditions?
Stefan | American by birth, Swedish by heritage, Australian by choice.
My current photo galleries.
deletedpenguin is offline   Reply With Quote
Old 03-28-2007, 03:24 PM   #22
jpr
My Ride: '99 323i
Who here is normal?
I really have no idea but I'd expect there to be a tremendous amount of variation based on driving habits, typical terrain and traffic patterns, transmission type, normal load, etc. etc. etc. and that's just for the OEM pads. Change pad types and you'll get even more variation.
The cynical answer though, is that OEM pads and rotors are designed to last 1 mile past the expiration of the service plan.
jpr is offline   Reply With Quote
Old 03-28-2007, 04:29 PM   #23
jpr
My Ride: '99 323i
Regarding the machining of the "M" rotors - here's some additional info I found on why machiing the M floating "composite" rotors would be unlikely to result in success -
As the vehicles with composite rotors accumulated mileage and came out of warranty, the aftermarket discovered that composite rotors required some special service procedures. Because the stamped steel center hat is not as thick nor or rigid as that in a one-piece casting, the center hat on a composite rotor must be fully supported with special adapters or oversized bell caps when the rotor is resurfaced on a brake lathe. The other alternative is to bolt the rotor to the hub (with the lug nuts reversed to provide better support and to prevent deforming the center hat) and to then resurface the rotor with an on-car lathe.
If a composite rotor is not supported properly, it can wobble and flex creating runout and surface finish problems. Both sides of the center hat must also be clean and rust-free for the rotor to turn true.
From - http://www.aa1car.com/library/rotors1c.htm
As for the non-floating/non-composite M rotors, I can't think of any design difference from the regular rotors that would make them non-machinable. However, it is possible the the direction not to do it is rooted in practical concerns. For example, it is safer to say "don't machine any M rotors" than to say "machine some M rotors but not others." From a liability standpoint, it would be better only rely on some anomynous tech knowing whether or not he's working on a M car than what specific rotor type he is looking at.
Secondly, it is likely that the M cars use a different brake pad specification with a higher expected rotor wear rate than the other cars. If this wear rate is expected take the rotor beyond the minimum thickiness within one set of pads, then there is probably not enough material to spare to make machining a safe option.
Old 03-28-2007, 07:36 PM   #24
sd203
Banned
My Ride: DINAN 3 & 330i ZHP
Thank you for this great post.
Just replaced the pads and Rotors. Probably could have let the Rotors go.
But I don't mess around with three things :
Brakes
Tires &
Married women
(who need brakes & Tires )
sd203 is offline   Reply With Quote
Old 03-28-2007, 09:10 PM   #25
jpr
My Ride: '99 323i
Brakes
Tires &
Married women
Sounds like a fairly wise policy, especially considering that problems with the third one can sometimes result in problems with the first two.
Old 03-29-2007, 10:23 AM   #26
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Happy reading, this thread explains why I don't beleive in turning any rotor
http://forum.e46fanatics.com/showthr...t=Brake+Rotors
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 03-29-2007, 10:29 AM   #27
jpr
My Ride: '99 323i
There is some good info in that thread, it's just you have to wade though a lot of acrimony to get there.
Quick summary -
* new rotors will work better than old rotors
* you can machine your non-M rotors, but it's very unlikely to be worth the trouble
Old 10-30-2009, 06:30 PM   #28
fayraree
flock killer
fayraree's Avatar
My Ride: 04 M3 vert
Originally Posted by jpr View Post
Just to consolidate info, here's the E46 M3 rotor sizes -
M3 - 325x28 front, 328x20 rear
M3 optional drilled (ZCP) - 345x28 front, 328x20rear
I believe the minimum thickness would then be 26.4mm and 18.4mm, but it would be nice if someone could confirm this.
confirmed.
fayraree is offline   Reply With Quote
Old 10-30-2009, 07:06 PM   #29
mistrzmiasta
My Ride: GLK350,ML63, Duc1098
Originally Posted by fayraree View Post
confirmed.
that was quick...i mean only 2 years
mistrzmiasta is offline   Reply With Quote
Old 04-01-2010, 08:56 AM   #30
33beto
My Ride: 08 328i Sedan(R.I.P)
Send a message via AIM to 33beto
so, for me to upgrade to 330 brakes i will need 330 calipers, rotors and brackets all around?
but if i only want 328 brakes (slightly bigger) all i need are rotors?
Thanks!
33beto is offline   Reply With Quote
Old 06-22-2010, 05:21 AM   #31
Alex323Ci
My Ride: M3 & 323Ci (sold)
Thanks!
for the fronts you'd need 330 calipers, carriers(aka brackets), rotors and pads. the rears are VERY hard to swap because of the emergency brake and most consider it way too much work. not a plug n play swap.
if you want 328 brakes (which btw are what the 325 got/same size) you need the front carrier(bracket) and rotors. for the rears i believe it's just the rotors
Old 03-13-2012, 10:33 PM   #32
rkneeshaw
My Ride: 330i ZHP
I listed the 330 rotor minimum thickness as deduced since, my version of the TIS predates the introduction of the 330 and does not have that info. The deduction is that they use the same designed rotor wear rate. IF you can confirm it, that would be helpful.
I can confirm that for you, just had the stock rear rotors off my 330i and stamped on the bell is the minimum thickness figure: 20.4mm.
Very good thread. Why isn't this thread stickied? EDIT: And moved to the brake forum
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 04-13-2013, 04:27 PM   #33
E46brb
My Ride: 05 e46 325xi
Brakes
I have an 05 325xi. Thinking about going to bigger brakes in the front. Currently the rotors run out at 11.8". Can 2005 m3 rotors measuring at 345 mm be used on this car, with the "m" calipers and brackets?
E46brb is offline   Reply With Quote
Old 01-11-2015, 05:42 AM   #34
Oz Striker
My Ride: '00 330Ci, '07 350Z
I'm currently researching Big brake options and was googling for the OEM 330 rotor specs and came across this thread. Could OP or moderator add these specs to the opening post? Just makes its easier for others:
Centering/Bore diameter: 79mm
Total Disc Height: 52.5mm
Hat Height: 27.5mm
Distance between caliper/hub/spindle mounting holes is 122mm
Also found this useful 330i front brake rotor schematic:
Name:	330i Brake Schematic.jpg
My YouTube Channel incl Muffler delete vids: http://www.youtube.com/user/OzStryke...view_as=public
My blog on E46 DIYs & Mods http://lifewithabmw.blogspot.com/
Oz Striker is offline   Reply With Quote
Old 01-11-2015, 09:11 AM   #35
GuidoK
My Ride: Z4 3.0i ESS TS2+
Does anyone know the hat depth of a 328x20 rear CSL (& z4m) rotor?
For most rotors and pads (both bmw&other brands) Brembo has an unique database with very detailed measurement drawings and other data.
http://bremboaftermarket.com/En/Car_...ueBrand=Brembo
I used this a lot while building my rear custom bbk and ending up using rear X3 rotors (slightly altered on my lathe) on a Z4
Sadly not for M floating rotors as they dont manufacture them.
E85 Z4 3.0i | ESS TS2+ | Quaife ATB LSD | Custom Brembo BBK front/rear | Schrick cams | Schmiedmann headers/cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers | Sachs performance clutch
GuidoK is offline   Reply With Quote
Old 01-11-2015, 12:32 PM   #36
Oz Striker
Thanks for the link, just what i need to gather specs!
AFAIK the E46 CSL uses E39 M5 calipers, (i read it somewhere), so perhaps it uses the same discs?
Old 01-11-2015, 01:04 PM   #37
GuidoK
Same in diameter&thickness, but not same p/n. So maybe different hat hight or so (no info on that either).
Old 01-11-2015, 01:36 PM   #38
Oz Striker
Are none of the vendors able to help you out? They might be able to help if they thought they could get a sale??
