Old 04-03-2007, 12:44 PM   #1
crosse46
Past Site Sponsor
Ksport Procomp Big Brake Kit
Ksport big brake kits provide the ultimate in stopping power for your vehicle. Integrating new brake technology into the design of the kits allows for a kit that highly reduces brake fade and continually cools and refreshes the brake pads surface under braking. These brake systems are designed for easy installation with minimal tools required (in most applications).
The Ksport big brake kit includes:
8-Piston Aluminum calipers
High quality brake pads
D.O.T. Compliant Stainless steel brake lines
Machined aluminum hats
Carbon steel brackets
330mm (13") large ventilated discs (17" wheels required)
Ksport SC5 street brake pads (RC1 race pads available for additional cost)
Extreme Lightweight Caliper:
Our extreme lightweight caliper comes in differential bore configuration. It is machined from aircraft quality billet, weighs just over 5lbs. each, and has machined in protection grooves for the bridge tubes. Aluminum pistons, high temperature seals, and stainless steel brake pad wear plates are also standard on each caliper design. The opposed piston caliper design greatly improves pad wear and caliper rigidity over the OEM design. The stainless steel brake lines stop expansion under pressure.
High Performance Rotor:
Most applications utilize the 2-piece floating disc assembly which reduces weight both rotating and unsprung. The floating disc also stops thermal stresses of extreme heat from warping the disc or cupping the braking surface. The unique slot design on the rotor greatly reduces braking noise and expels gas and pad debris faster than conventional slot designs. Every rotor is always heat treated and balanced before shipment for the best possible performance.
Ksport SC5 Street Pads:
These NAOC ceramic pads are designed to give you the optimal braking performance under street and occasional track conditions. Optimal operating temperatures are between 194F - 1022F for fast warm up under normal driving conditions. These pads reduce the amount of brake dust by 50% or more when compared to our race pads. The SC5 pads also greatly reduce the amount of noise and wear on the rotor over the race pads. The average coefficient of friction on this pad is between .46 and .53.
Ksport RC1 Race Pads:
These carbon metallic race pads are designed to give you the best stopping power possible under extreme track conditions. Optimal operation temperatures are between 480F - 1472F so it is not recommended for street use due to high temperature needed for optimal performance. Designed for the racer in mind to reduce brake fade under extreme conditions. The average coefficient on this pad is .5.
PLEASE PM US FOR PRICE, TOO LOW TO LIST
ID:	221421   Click image for larger version
ID:	221422   Click image for larger version
crosse46 is offline   Reply With Quote
Old 04-05-2007, 02:33 AM   #2
crosse46
Past Site Sponsor
all pm's replied offering super low prices for some test and review cars.
Old 04-05-2007, 08:34 PM   #3
BruceWonder
My Ride: 2011.5 E92 M3
quote for both front on 03' z4
BruceWonder is offline   Reply With Quote
Old 04-06-2007, 10:45 AM   #4
BentleyJava
My Ride: 2003.5 M3
PM me price for e46 m3 fit, fronts.
BentleyJava is offline   Reply With Quote
Old 04-06-2007, 12:42 PM   #5
crosse46
Past Site Sponsor
All pm's replied looking for a few track guys , please pm me is you track your vehicle.
Old 04-06-2007, 04:22 PM   #6
whodo
My Ride: 2003 330i
You didn't get my pm yesterday?
whodo is offline   Reply With Quote
Old 04-06-2007, 10:30 PM   #7
crosse46
Past Site Sponsor
No , sorry i did not receive one.
Sammy
Old 04-07-2007, 01:46 PM   #8
FLPSIDE
My Ride: 325ci
Send a message via AIM to FLPSIDE
i PMed u again! i gotta bump this cuz the quote that i got was shocking! talking about LOW!!! wow....
FLPSIDE is offline   Reply With Quote
Old 04-07-2007, 07:52 PM   #9
crosse46
Past Site Sponsor
Hey.....lol, this is a promotional offer for our new lines, however do not be concerned low prices here will not equate to bad service.
Old 04-07-2007, 07:56 PM   #10
Jeuprx-8
My Ride: rolls only Michelins
pm'd you
2006 Corvette Z06 Red/black
2006 BMW M5 Sepang/Sepang SMG III
2006 BMW M6 White/Black 6-speed
Jeuprx-8 is offline   Reply With Quote
Old 04-07-2007, 08:13 PM   #11
Moltenburn
My Ride: 330i
PMed hit me up
Moltenburn is offline   Reply With Quote
Old 04-08-2007, 04:43 PM   #12
crosse46
Past Site Sponsor
All pm's replied and we thank you for your intrest and kind comments.
Sammy
Old 04-08-2007, 08:31 PM   #13
hockeyguy
My Ride: 2001 330CI
pm'd
hockeyguy is offline   Reply With Quote
Old 04-08-2007, 09:21 PM   #14
crosse46
Past Site Sponsor
all pm's replied.......
Old 04-08-2007, 11:36 PM   #15
My1stM3
My Ride: Alpine White M3
please pm me a price for ///m3 fronts. Thanks
My1stM3 is offline   Reply With Quote
Old 04-09-2007, 11:51 PM   #16
AssassinGT
///Andrew Alewine
AssassinGT's Avatar
My Ride: 2000 BMW 323Ci
Send a message via ICQ to AssassinGT Send a message via AIM to AssassinGT Send a message via MSN to AssassinGT Send a message via Yahoo to AssassinGT
Price Quote for 323Ci and E92 335i
(Click Sig for More Pics)
AssassinGT is offline   Reply With Quote
Old 04-10-2007, 02:02 PM   #17
crosse46
Past Site Sponsor
all pm's replied.
Old 04-10-2007, 11:29 PM   #18
DJ BeBe
My Ride: 2000 328i sedan
Send a message via MSN to DJ BeBe Send a message via Yahoo to DJ BeBe
can i please get a quote for a 2000 e46 328i ?
Vote for BEBEMUSIC @ The DJ List!
CLICK BELOW FOR MY LATEST MIXES
DJ BeBe is offline   Reply With Quote
Old 04-10-2007, 11:32 PM   #19
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
quote for a 323ci pleaaase
BreakMyWallet is offline   Reply With Quote
Old 04-17-2007, 03:26 PM   #20
Geeza
My Ride: Megabusa
Left a message this morning, quote for Front and Rear, thanks
[SIGPIC]
Geeza is offline   Reply With Quote
