Old 04-04-2007, 01:43 PM   #1
jpr
My Ride: '99 323i
DIY Front Toe Adjustment
In the course of fiddling with my alignment, I developed the following method for measuring toe. I found the two keys to accurately measuring toe are the use of slip plates and using as long a measurement baseline as you can. My experimentation with this method shows it has a repeatable accuracy of about 0.05deg within a 95% statistical confidence interval.
Here's what you need
Laser Level w/ manual beam adjustment - I'm using the Craftsman "4-in-1 Level with Laser Trac" Model No. 320.38251, LM01-002-01-L ($35 at Sears)
Tape measure
Scientific Calculator
Some sort of slip plates - I used two self-adhesive vinyl floor tires with wax paper backings next to each other
Some tape - I like the using the blue painter's tape
Measuring Toe
find a level-ish and preferably somewhat shady place to work
Drive your car on to the slip plates and bounce it a few times
mark out 36 inches forward of the axle on each side (put a small piece of tape on the ground and make your mark on that
run a tape measure out about 86+ inches across the car at the 36 inch marks
with one hand hold the laser level and flush on the hub
use the projected beam to set the tape measure at 80 inches
move the other side of the car, position the laser level and flush, and read the tape where the laser crosses - you should be able to read it to the nearest 1/32 inch
repeat at 36 inches aft of the axle
Take the difference between the toe and use your calculator to figure out the total toe angle where tan-1[(aft-fwd)/72] = total toe angle
Adjusting Front Toe
The two issues in adjusting your toe are the total amount and a centered steering wheel when you are done. Toe itself is adjusted by changing the length of the tie rods. Make them shorter, the magnitude of toe-in is increased, make them longer and it is decreased.
One full turn of a tie rod will change your toe by about 0.24degrees, which is far more than you will likely need. Accordingly, make toe adjustments in small increments, using the flats and points of the tie rod as points of reference. A one nut-flat turn of the tie-rod will change your toe by about 0.04degrees, which is coincidentally about the limit of what you can repeatably measure. You can make smaller adjustments using the points as a half-turn marker, but you will need to rely on art rather than science at that point. In making adjustments, it's easy to lose your place, so it's a good idea to mark your target flat with a little piece of tape, then adjust the tie rod until that target flat is on the bottom.
The steering wheel becomes off center when the tie-rods are adjusted unevenly, i.e. one is longer than the other. Here's an example of how to fix that -
The wheel will point towards the side with the shorter tie rod
The standard steering rack ratio on the E46 is 15.4:1
So if your steering wheel is off by say 1 deg, this means your wheels are self-centering by 0.06deg
This in turn means you have a toe differential of about 0.12deg
The threads on tie rod give you about 0.04deg of toe change per nut flat.
So lengthen the short tie rod by about 1.5 flats, shorten the long one by about 1.5 flats, and tah-dah - steering wheel is centered.
You can also use this method to measure your total rear toe, but you would need to establish a centerline reference to measure individual toe.
jpr is offline   Reply With Quote
Old 04-04-2007, 01:48 PM   #2
Hrvat
My Ride: 02 Imola Red M3
Hail to the king of steering and suspensions
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Old 04-04-2007, 04:53 PM   #3
phelix
My Ride: 328i
Another quick and dirty way is to put pieces of tape with vertical lines on the trailing faces of each front tire at the height of the wheel center. Drop a plumb line down to just above the ground on each side and measure the distance. Roll the car forward until the tape is at the front at wheel center height and repeat the measurement. If the front measurement is less than the rear you have toe-in. The math of calculating the exact amount of toe is left to the reader.
phelix is offline   Reply With Quote
Old 04-04-2007, 05:06 PM   #4
jpr
My Ride: '99 323i
I experimented with a few methods and settled on the one detailed above as the most accurate and repeatable.
The two limitations of the method you describe are:
* Repeatability suffers from not using slip plates. You will end up measuring a lot of bushing squirm and consequently have trouble getting the same measurements on repeated trials.
* Accuracy is limited by the short baseline. If you are using a tape measure, +/- 1/32inch is about the smallest increment you can reliably measure. With a 72 inch baseline, this equates to about +/- 0.025deg. But with only a 25inch baseline it works out to about +/- 0.072deg.
In the end though, it is up to the user to decide what level of accuracy suits their needs and how much time and effort they have available to achieve it.
Old 04-05-2007, 12:26 AM   #5
phelix
My Ride: 328i
I did say it was quick and dirty...
I've found it quite repeatable and excellent for use after changing front suspension components so that you can get the car to a shop for a proper setup.
Old 04-05-2007, 02:39 AM   #6
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
subscribed.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 04-05-2007, 07:54 AM   #7
jpr
My Ride: '99 323i
I think it would work quite well for that.
The motivation in my case was actually having just had an alignment, but being unsatisfied with the front toe settting. It wasn't really the shop's fault, it was a matter of not knowing what I wanted as a result of both an increase in front camber and installation of the stiffer powerflex bushings. Being able to DIY it let me experiment and test with a few different settings to find the one I liked (ended up with zero toe incidentally).
FWIW, I found taking the measurements to be about a 10 minute task.
Old 06-01-2008, 07:41 PM   #8
328iBMW
My Ride: C320
Huh.
I'd like to give it a try this summer. Thanks.
How do we adjust camber?
What makes you come alive?.........Go do it.
328iBMW is offline   Reply With Quote
Old 06-02-2008, 12:03 PM   #9
jpr
My Ride: '99 323i
Check out post #13 in the "Alignment" thread linked in the sig below - it's got the TIS instructions attached
Old 03-14-2010, 01:08 AM   #10
Albobmw
My Ride: 01 bmw 325i
great thread/
Albobmw is offline   Reply With Quote
Old 09-07-2011, 09:01 AM   #11
SpitfireRcp
My Ride: 2002 BMW M3
I can't thank you enough. No one wants to do a front end alignment on my car because it is too low, now I can do it on my own and save $100
SpitfireRcp is offline   Reply With Quote
Old 08-09-2014, 10:34 AM   #12
2001BlackOnTan
My Ride: 2001 330Ci
How about making slip plates out of pieces of steel (or wood) and some ball bearings?
2001BlackOnTan is offline   Reply With Quote
Old 08-11-2014, 01:33 AM   #13
phelix
My Ride: 328i
No need to use ball bearings; just grease.
Old 11-03-2016, 10:04 AM   #14
dan_roh
My Ride: BMW 320i Touring
Great pieces of information thanks
dan_roh is offline   Reply With Quote
