Old 05-06-2002, 11:42 PM   #1
Haftalife
My Ride: 325CI
Send a message via AIM to Haftalife
Why are my Xenons not as bright as the older models?
Can I get this adjusted to where it has the light blue glow? Mine Xenon are just bright white.
Haftalife is offline   Reply With Quote
Old 05-06-2002, 11:46 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
After a while, your Xenons will lose that blue color, thats just a fact u have to live with. What you could do is buy new bulbs from the dealer but I doubt the dealer will reinstall bulbs for free just because you want a blue color. You probably won't care that much about this but I will tell ya ne ways, Xenons are the most powerful when "broken in" (for lack of better words). The white light they produce shine the brightest which will illuminate the road better. If you want the blue color, I would go with the bulbs Audi uses (there was a post about Audi bulbs and they do fit BMW's). Sorry if that doesn't help...
Old 05-07-2002, 05:35 AM   #3
Haftalife
My Ride: 325CI
Oh I don't want to get new bulbs to replace my Xenons. I just wanted to see if they could adjust the level my light shines at now. I think they lower the voltage on my year because I see 2000 bmw with Xenons with a much bluer look. And mine just looks really bright white.
Old 05-07-2002, 05:45 AM   #4
Karl
Engineer
My Ride: 2001 330xi
The color of a xenon headlamp bulb is a function of its color temperature, a setting that is dervied from the plethora of gases that make up the mixture inside its actual discharge tube. To make a (very) long story short, your xenon lights are no less bright than a "bluer" xenon light, they're probably even brighter - it's just that blue light appears brighter to the human eye. You will have better visibility with a whiter light because it won't desensitize your night vision as much as a bluer light, AND, with the additional light output you will have a sharper contrast with which to discern objects on the road. Blueness is NOT everything.
Karl is offline   Reply With Quote
Old 05-07-2002, 06:12 AM   #5
S4MadMan
My Ride: Heavily Modded S4
It's not about being blue...
...it's about being purplish-white. See here :smile::
S4MadMan is offline   Reply With Quote
Old 05-07-2002, 03:30 PM   #6
Karl
Engineer
My Ride: 2001 330xi
Whether blue or purplish white, brightness is decreased from just plain white.
Old 05-07-2002, 05:39 PM   #7
Enarchy
My Ride: 02 325Ci, PP
Send a message via ICQ to Enarchy
but the look alone is pure eye-candy
Enarchy is offline   Reply With Quote
Old 05-07-2002, 06:31 PM   #8
S4MadMan
While the aftermarket bulbs do have...
...about 300 to 400 less lumens; 3,200 lumens for stock bulbs vs. about 2,800 to 2,900 lumens for the Philips Ultinon 6,000Ks for instance; I will tell you, I as well as many others feel the 6,000Ks have superior lighting characteristics at night. I have driven with one stock and one 6,000K bulb for quite some time and I see more and better with the 6,000K Bulb.
Also, actually, 6,000K is closer to pure white than 4,300K. Please see the Kelvin Scale below:
But to each his/her own. :smile:
Old 05-07-2002, 06:38 PM   #9
Karl
Engineer
My Ride: 2001 330xi
Heh, well, according to your Kelvin scale, optimal lighting conditions occur under daylight - 5000k - because that's what our eyes are used to (not to mention that colors are also true-to-life). Doing the math, 5000-4300 is a 700k difference, and a 6000-5000 is a 1000k difference, and a 1000k higher difference at that, which is worse because it desensitizes your eyes - ruins your night vision. Although I can't argue against the looks of a set of 6000k's, I can argue for the 4300k's superior lighting characteristics :smile:. And yes, I've ridden in a vehicle with 6000k's and noticed that although they seem brighter, my ability to see beyond the reach of the the headlights is reduced (same for looking to either side of the vehicle).
