Old 04-10-2007, 03:02 PM   #1
CA AUTOMOTIVE UK
Past Site Sponsor
My Ride: E36 M3 TURBO
Uprated Engine Mounts E46 M3
From Rogue engineering :
Finally, a real performance engine mount for those looking for the extra edge. Until now, the only performance engine mount to really consider was the BMW Motorsport Group N engine mounts priced at an incredible $800/pair! These uber expensive mounts were just like factory engine mounts except they were produced with a harder rubber, approximately 30% stiff than stock.
The Rogue Engineering Performance Engine mount is a affordable alternative to the BMW Motorsport Group N mounts, at a fraction of the price. Because these are produced with isolated mounting plates, it does offer similar vibration dampening characteristics like stock. Of course, because of the harder nature of these bushings, some additional vibration may be experienced, just like the BMW Motorsport Group N engine mounts.
Just like factory, but better
The factory-like design incorporates the anti-rotational tabs ensuring that the mounts do not rotate. Use of these mounts virtually eliminates all deflection created from the engine. This is especially true for high-powered vehicles such as those with turbos or superchargers.
The internals of the mount feature a unique locking system in the event of a crash, the internal hardware of the mounts prevent complete failure of the mount. Whereas the integrity of the mount will be compromised, its internal construction prevents the mounts upper and lower plates from completely tearing away from each other. Whereas this may seem to be a small feature, this will ultimately decrease the chances of the engine from breaching the firewall, and entering the internal compartment of the vehicle. No other performance mount can make this claim.
Additional Features
While these mounts are produced in limited quantities here in the US, we have also built these engine mounts to be 5mm shorter than stock, to allow for lower engine mounting height (lowering the center of gravity). Matching performance transmission mounts are also available with purchase. The mounts include 5mm spacers, in the event the user would like to maintain the factory engine mounting position.
Fits the following vehicles:
All 1992-1999 E36 M3, 328, 325, 323, 318
All 1999-2006 E46 M3, 330, 328, 325, 323
All Z4
All Z3
Cost is £230 / pair
CA AUTOMOTIVE UK is offline   Reply With Quote
