Old 04-16-2007, 11:02 PM   #1
rzarezai
My Ride: 1999 328i
Exclamation What are bad water pump or pulley symptoms?
I have a 99 328i. And it makes this weird noise when accelerating and at idle. I think it might be the water pump or it's pulley.
What are common symptoms of a bad water pump or pulley?
thanks
rzarezai is offline   Reply With Quote
Old 04-16-2007, 11:07 PM   #2
KrisL
My Ride: 03 330i ZHP
Send a message via AIM to KrisL
Symptoms of a bad water pump are your car overheating.
Symptoms of a bad belt, belt tensioner, or pulley is a squealing sound that increases in audio frequency with engine speed and usually goes away once the parts are warm.
KrisL is offline   Reply With Quote
Old 04-16-2007, 11:37 PM   #3
JSanders
My Ride: Breaks too often
On the water pump stick your hand down to the pulley and try and wiggle it.If its loose, replace it. Over heating will occur if you drive it with the bad water pump for a period of time, and can cause mager damage. you can check the tensioner pully the same way, the 'wiggle' method, and it will cause a screeching or squeeling noise while driving/idoling.
JSanders is offline   Reply With Quote
Old 04-17-2007, 06:00 AM   #4
Hrvat
My Ride: 02 Imola Red M3
Do you hear/see this?
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Old 04-17-2007, 10:20 AM   #5
thaiunit
My Ride: 2003.5 M3
Yeah, that happen to my car a few months ago. I was lucky that my car made it to campus when I started to hear that noise. Then had to tow it.
2000 E46 323i (SOLD)
2006 E90 330i (SOLD)
2003.5 E46 M3 Joy!
thaiunit is offline   Reply With Quote
