Old 04-23-2007, 02:29 AM   #1
crosse46
Past Site Sponsor
CryO2™ Intercooler Sprayer Kit
The concept is simple… an intercooler increases power by cooling charged air as it flows toward the intake. Therefore any improvement in the cooling efficiency of the intercooler produces greater increase in power output.
Design Engineering, Inc. (DEI) a leading aftermarket supplier of thermal tuning products and cryogenic intake systems has just introduced a variation of it’s SEMA Award winning CryO2 cryogenic cooling technology with it’s new Intercooler Sprayer Kit.
Using the super cooling properties of carbon dioxide (CO2), the kit improves air-to-air intercooler efficiency by up to 50%! That means a cooler, more powerful intake air charge for improved engine performance. This non-invasive system is designed to dramatically reduce the temperatures that affects the horsepower output of an engine. The bottom line? A boost in horsepower at a cost substantially less than that of nitrous.
For turbo or supercharged systems, the CryO2 Intercooler Sprayer mounts directly to the front of the intercooler and vents CO2 directly on the cooling fins. This enhances the thermal transfer ability of the intercooler for greater efficiency. The system can be configured to be activated by either a full WOT micro-switch or controlled manually with a momentary push button.
CryO2 Intercooler Sprayer Kit:
Lowers air temperatures by as much as 35%
Improves intercooler efficiency by as much as 50%
Non invasive system
Ability to run more boost safely
Straightforward easy-bolt installation
CO2 is substantially less expensive to refill than nitrous
Everything required for improved cooling for more power in one kit
Optional CryO2 Timer Switch available for automatic on / off pulsing
CryO2 Water Sprayer is available for greater I/C efficiency
Each CryO2 Intercooler Sprayer Kit includes a 10 lb tank, mounting brackets, 14' stainless steel braided feed line, full WOT and arming switches, momentary push button, all necessary fittings, electrical & hardware pack, cryogenic solenoid valve, 16” x 5” front-mount intercooler sprayer & high-quality long-lasting stainless steel zip ties for securing the sprayer. Everything needed for a simple and straightforward installation in one kit.
pm for price.
Sammy
crosse46 is offline   Reply With Quote
Old 04-29-2007, 04:50 PM   #2
SammyV
My Ride: CB M3
Send a message via AIM to SammyV
prices?
SammyV is offline   Reply With Quote
