Angel Eyes, DDEs, lighted rings, Clear Turn Signals, LEDs, Xenon, HID, or Bi-Xenon. If it lights up and you want to discuss it, post here! |
#1 |
It really was a Rocky story
used resistors......
installed LED tail lights and used resistors to eliminate the blub out warning.... it worked for the driver side... but the pass. side is still on.... what could it be?
#2 |
bad resistors? try to swap side and see if it makes any difference.
#3 |
you probably didn't get a good connection with the taps you used on that side.
#4 |
do i use the resistor on the ground or the hot?
#5 |
Yep, I had to cut a plastic off the wire to get it thru
#6 |
#7 |
ohhhhh are you serious?
#8 |
#9 |
yes it should be (-)--tap---(resistor)---tap---(+) lol what a crappy drawing. o well hope that helps
Have a lighting problem? Read this first: Lighting-related Troubleshooting Guide |
#10 |
i got it guys... thank you
but um the parallel taps didnt work to well.... it worked for like 2 seconds and the resistor started smoking up but i found an alternate solution |
