Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 4.93 average. Display Modes
Old 05-07-2007, 03:29 PM   #21
Sharky06
My Ride: 06 ZHP 6-SP
Send a message via AIM to Sharky06
The ribbon connectors pp are still in the dark. I'll try to work on my ribbons tomorrow.
Sharky06 is offline   Reply With Quote
Old 05-07-2007, 03:51 PM   #22
blue dragon
My Ride: '02 PY M3
Thats a lot of work just to get mirrors to autofold Hopefully I don't have to do that because I already have memory mirrors with reverse tilt, so what else do I need?
blue dragon is offline   Reply With Quote
Old 05-07-2007, 08:36 PM   #23
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
A ribbon cable is essential wires in a sense, you would just need to figure out what pinouts from the ribbon connectors do what. You could cut the ribbon cable in halve and splice the wires to a connector.
You may already have the mirror memory modules, but you will still have to access the fuse panel for F57 in order to do it the OEM way at least or you could go the simple way and find any old 12v source.
Jared
Ivegotissues666 is offline   Reply With Quote
Old 05-07-2007, 08:48 PM   #24
e.barr
My Ride: 320ci
Hi, Jared, I have a set of ACS mirrors that do not fold but i would like to add the auto tilt function only.
Do i still need to get the mirror memory modules that mount on the doors to get this to work?, and if so what wiring mods will i have to do?.
Cheers
e.barr is offline   Reply With Quote
Old 05-10-2007, 03:22 AM   #25
m3in30days
My Ride: 330i
i have a 330i 2001. with memory and autotilt.
i bought the autofolding mirrors from eurospec, they are painted and installed...it was just plug and play...the mirrors work fine. i have 12 pin mirror...i ordered the switch from bmw. do i need to rewire...or will the switch plug and play...how can i check so i can prepare before my part comes in?
argh i never thought these mirrors would be so much trouble to work...
as i understand it...i also have to rewire if i want the mirrors to be conected to my remote control.
m3in30days is offline   Reply With Quote
Old 05-10-2007, 06:58 PM   #26
Ivegotissues666
Cheers
Yup you would still need the memory modules and the wiring should be exactly as I posted granted you have 12 pin mirrors like in the DIY.
I don't follow, does your car already have mirrors that fold and reverse tilt? If so no other wiring modifications should be needed unless of course you are swapping between 6 pin, 12 pin or ribbon cabled mirrors.
Also I keep hearing this key working with mirror memory setting feature, I'm not sure exactly what it's all about to be honest (Someone inform me). I t most likely would need coding work to be done at the dealer for it to work though.
Jared
Old 05-10-2007, 07:47 PM   #27
m3in30days
My Ride: 330i
i bought auto folding mirrrors from eurospec...they are twelve pin...my car was twelve pin.....i then bought the switch from bmw... my car did not originally have auto folding mirrors. it only had the auto tilt feature when i put it in reverse..but i purchased autofolding mirrors and installed them.... not sure if that cleared anythign up?
Old 05-10-2007, 07:56 PM   #28
Ivegotissues666
Ok that cleared things up. Well if you had reverse tilt then you should have the mirror modules (Not 100% sure though). Your best bet would be to pull the door panels to find out. And as for the wiring it would be the same as in the DIY I posted.
Jared
Old 05-10-2007, 07:58 PM   #29
m3in30days
My Ride: 330i
so the switch will not be plug and play?
anyone in san diego that has done this... pm me please
Old 05-10-2007, 10:06 PM   #30
m3in30days
My Ride: 330i
I FINALLY GOT MY CAR! wahoooooooooooooo! ill post of my mirrors up soon....
ok...i have the switch...do i need to remove the door cover to replace it...or i do i just pry it out?
Old 05-20-2007, 01:01 AM   #31
m3in30days
My Ride: 330i
here the pics! i definitly see the difference between the oem and replica mirrors...i still think they look better then stock...but see how oem look better.
ID:	227609   Click image for larger version
ID:	227610   Click image for larger version
ID:	227611   Click image for larger version
Old 05-20-2007, 01:08 AM   #32
m3in30days
My Ride: 330i
here are the before pics... i think it looks way better... opinions...comments???
ID:	227614   Click image for larger version
ID:	227615   Click image for larger version
ID:	227616   Click image for larger version
ID:	227618   Click image for larger version
Old 05-20-2007, 09:18 AM   #33
Ivegotissues666
Just use a thin flathead and pop the switch up just enough to grab with your fingers.
Nice mirrors!
Jared
Old 06-06-2007, 04:35 PM   #34
gkoutsis
My Ride: 04 330 Cabrio
To sum up....
12 pin mirrors have the 2 rows switch and 6 pin mirrors have the 1 row switch?
Is this correct?
George
gkoutsis is offline   Reply With Quote
Old 08-04-2007, 06:09 PM   #35
Ivegotissues666
Originally Posted by gkoutsis View Post
To sum up....
Is this correct?
No because I'm using a switch that has only 1 row 6pin connector and I have 12 pin mirrors.
Jared
Old 10-17-2007, 01:46 AM   #36
newagecustoms
My Ride: '04 325i, '96 318ti
so were your mirrors originally 6 pin and your new ones were 12 pin?(just asking because you say you bought 2 12 pin connectors.)
My car is 6 pin and i want to retrofit the autofold.
the new ones i got from euro spec are 12 pin, so do i just need to do exactly what you did? I dont have power seats or the reverse tilt.
Any help to make this job more clear for when I do it would help, thanks.
newagecustoms is offline   Reply With Quote
Old 10-18-2007, 07:17 PM   #37
Ivegotissues666
Yes thats correct mine were 6 pin mirrors stock, then I purchased a pair of M3 replica's 12pin off ebay.
Jared
Old 02-14-2008, 02:49 AM   #38
StavKon
My Ride: 318ci valvetronic
Hi,
just wanted to ask a question, since all the stuff about 6-pin and 12-pin is a little bit confusing.
I have a german spec e46 coupe with n42 engine (2 lt). It came from factory with power-heated seats with memory, and also it has the mirror tilt option when I put reverse gear in. It even has this switch already installed.
(I borrowed the image from Ivegotissues666 -btw thank u for that and also the write up)
Do u think my car is pre wired and ready, and I just have to swap the stock mirrors with the ones with motor?
thanx in advance fo all the replies....
StavKon is offline   Reply With Quote
Old 02-14-2008, 09:20 AM   #39
StavKon
I've just checked the fuse panel and I saw that there is a 5 amp fuse in position 57. So I guess I just need the mirrors and nothing else (wiring loom, switches etc). I just need a last confirmation from someone with greater experience than me on the case.
Old 02-14-2008, 09:45 AM   #40
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
great writeup
/_________\
O==[][]==O
