Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 4.93 average. Display Modes
Old 03-06-2008, 02:35 PM   #41
daytonaviolet
My Ride: 2004 M3
Send a message via AIM to daytonaviolet Send a message via MSN to daytonaviolet Send a message via Yahoo to daytonaviolet
Originally Posted by StavKon View Post
I've just checked the fuse panel and I saw that there is a 5 amp fuse in position 57. So I guess I just need the mirrors and nothing else (wiring loom, switches etc). I just need a last confirmation from someone with greater experience than me on the case.
pull out your oem mirrors and see if you have the 12pin harness. if so, i think all you need are the euro power fold mirrors.
daytonaviolet is offline   Reply With Quote
Old 03-17-2008, 02:35 PM   #42
GWU_Greek
Banned
My Ride: 325
i have replica m3 mirror already. can i just buy the auto-folding motor and retrofit this project myself
GWU_Greek is offline   Reply With Quote
Old 03-17-2008, 02:39 PM   #43
Snik
Snik's Avatar
My Ride: IR M3 Vert.
oh SNAP!
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 05-13-2008, 04:06 PM   #44
Romaz
My Ride: 330 cab
Very nice write up! I'm thinking of getting a set of these myself.
- - - Earth women are delicious - - -
Romaz is offline   Reply With Quote
Old 05-20-2008, 10:54 AM   #45
jms_w
My Ride: '08 E93 M3
Great writeup!
FWIW, I bought my power fold mirrors from eBay a couple of years ago and it was pretty much plug and play. I have the 12-pin connector I think. Just needed to buy the OEM mirror control with power fold button and get the mirrors painted. Very easy. I don't remember doing anything with the fuses to get power but it was a long time ago. Memory and heat still work as well as reverse tilt. Also, the button is already programmed to not fold the mirrors while you're driving over 5-10 mph.
jms_w is offline   Reply With Quote
Old 06-01-2008, 12:13 PM   #46
skippy911
My Ride: 04 325ci
Hey all, I have a 04 325ci. Is it possible to do this mod on my car? I read in another thread that the facelift cars may have a ribbon connector and then someone with an 06 had one without a ribbon connector so im confused. Also wha does reverse tilt do? And lastly, if you turn the car off do the mirrors automatically fold?
skippy911 is offline   Reply With Quote
Old 06-01-2008, 01:27 PM   #47
Zorba
My Ride: BMW 2003 325I Sedan
skippy911
The answer to your question would be YES and YES I have a '03 325I in Atlanta, Ga. and got a pair of these black carbon fiber mirrors from Mod
Bargains they also come in silver carbon fiber they are plug in play but check pin amount either 6 or 12 from dealership
Zorba is offline   Reply With Quote
Old 06-01-2008, 01:44 PM   #48
skippy911
My Ride: 04 325ci
Sweet, thanks for the info.
Old 06-11-2008, 10:30 PM   #49
skippy911
My Ride: 04 325ci
Anyone have a good source for the mirrors them selves without me getting totally ripped off. I saw some hongkong ones on ebay but they looked cheaply made and they were still 245+ shipping! TIA
Old 09-17-2008, 11:57 PM   #50
notslow
My Ride: 03 e46 4dr
Question how about with ribbon connector?
Okay, I installed some aftermarket autofold mirrors in an "05 e46 facelift car. It has ribbon connectors so I did a motor swap. Everything works like stock, reverse tilt and all. The problem is there is nowhere to hook up the 2 wires to the autofold motor. I installed the new switch in the drivers door, but no idea where to hook up the fold motors. Any ideas?
Thanks, Will
notslow is offline   Reply With Quote
Old 11-25-2008, 03:24 PM   #51
the_big_1
My Ride: E46 330 D
Same prblem here, did you fix it?
the_big_1 is offline   Reply With Quote
Old 11-25-2008, 03:32 PM   #52
daytonaviolet
My Ride: 2004 M3
i believe the two wires for the foldning mirrors goes to pos #1 and #2 in the 12pin wire hardness. when you press the folding button, those pins will go from 12V to GND. measure it with your meter first
Old 11-25-2008, 03:49 PM   #53
the_big_1
My Ride: E46 330 D
There is no 12 pin connector if they are ribon mirrors?
Old 11-25-2008, 03:54 PM   #54
daytonaviolet
My Ride: 2004 M3
sorry, i never worked on the ribbon cable style before.. this diy was for 12pin cable
Old 11-25-2008, 03:57 PM   #55
the_big_1
My Ride: E46 330 D
I have sorted the ribon bit out, just can not find where on a car where the mirror memory unit isnt in the door, where the fold wires should go
Old 11-25-2008, 05:29 PM   #56
notslow
My Ride: 03 e46 4dr
I believe everything is integrated into the ribbon mirror adjust motor. There is an extra ribbon I am pretty sure plugs into the fold motor. There are no wires or harness connections in the door anywhere else that the fold motor could possibly plug into. I am trying to get someone with stock ribbon auto folds to verify that the fold motor is connected to the extra ribbon. If anybody else knows of someone with stock ribbon auto folds ask them if they can check.
Old 03-24-2009, 07:45 AM   #57
toffa
My Ride: 320ci
Send a message via MSN to toffa
Just a question: your car had the auto-folding module behind the fusebox?
toffa is offline   Reply With Quote
Old 05-11-2009, 05:01 AM   #58
toffa
My Ride: 320ci
Guys, I did it. It's fantastic!!!!
The only difficulty is that it is damn difficult to connect the positive behind the fuse box
Old 05-11-2009, 05:02 AM   #59
toffa
My Ride: 320ci
wiring diagrams
I added the wiring diagrams (with colors), if it can help someone.
drive side:
passenger side:
Old 05-12-2009, 03:57 AM   #60
the_big_1
My Ride: E46 330 D
Hi,
I asked at BMW when my car was in for a INS 1 and the tech guy said that if the mirrors are fitted to a vehicle, ribon ones that is, and the correct adjust switch, they should work without any programming etc but I dont know of anyone that has fitted any ribbon type folding mirrors
