Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 4.93 average. Display Modes
Old 08-20-2010, 03:38 PM   #61
Manka16
My Ride: 323330x3
this is a good diy instruction but does anyone actually have what color wires come from the mirror pin by pin and...what plug do they go to white or black if the black were used for the mirror wires that come from the moter then what would the input be from the door harness to the white plug ? there is two plugs both are 12 pin but how do they work input door harness to one of the plugs to the output on the module to the mirror? Switch <---> White Module
Pin 2 <---> Pin 4
Pin 3 <---> Pin 11
Pin 4 <---> Pin 10
Pin 1 <---> Pin 5
switch---whiteplug
is this the way that 4 pins transfer from plug to plug? if thats true what colors are the ones comming from the mirror to the module?
Manka16 is offline   Reply With Quote
Old 01-11-2011, 09:53 PM   #62
genuity
My Ride: 2001 330iS
OP, have you been able to find the contact bushing part number 61130006663 but without the stupid wire? I like crimping my own wire instead of having to soldier their weird gauge wire into the standard gauge wiring.
Thanks for this DIY
genuity is offline   Reply With Quote
Old 04-03-2011, 02:19 PM   #63
Topazine
My Ride: '02 330i
Hello,
I recently purchased a pair of oem 12 pin m3 mirrors w/ autofold for my sedan.
I was told the mirrors are autofold, so I assume they have the optional motors already built in?
my question is, what do I need in order to install the mirrors on my sedan with all the stock features, plus add the autofold option?
I understand I need to modify the base plate, that's not what I'm concerned about here
I still have to check but I think my car is 12 pin. I have memory seats (not heated), memory mirrors, heated mirrors, and passenger side revere tilt. I assume it's plug and play for all these standard features.
what do I need for my sedan to add the autofold feature? Is OP's post exactly what I need to do? thanks
Formerly: TheBeerAssassin
Topazine is offline   Reply With Quote
Old 09-11-2011, 02:28 AM   #64
rodsfromday
My Ride: 323CI
What a great DIY. Just completed it and works perfect. Followed it step for step. Very easy to do!! Thanx man!!!
German Engineering at its best
rodsfromday is offline   Reply With Quote
Old 08-19-2012, 11:10 AM   #65
Tayne500
My Ride: '02 330Ci
Can someone confirm that this isn't a powerfold mirror?
Mirror by Tayne, on Flickr
I have a December 2002 330 Sport with memory seats and reverse tilt.
The mirrors were a bargain on ebay so I picked up the purple backed switch (it fits and adjusts mirrors) and was about to fit these mirrors today.
They have a 12 pin connector with only 9 wires (same as my current mirrors).
Further to this (assuming I do end up with a correct set of powerfold mirrors), can I swap the piece that mounts onto the outside of the car as I need shadowline trim?
Also, do I definitely have to take the door card off?
I was hoping there was a multiplug on the inside of the mirror...
Tayne500 is offline   Reply With Quote
Old 09-28-2012, 02:33 AM   #66
ryn004
My Ride: '04 316i Sport
Send a message via ICQ to ryn004
Has anyone attempted this with the 6pin folding mirror?
ryn004 is offline   Reply With Quote
Old 02-17-2013, 11:11 PM   #67
Tiag46
My Ride: e46
Just bumping this to say thanks OP.
Great DIY!
*Wrecking* - Heaps of parts available.
http://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
Old 05-19-2013, 05:31 AM   #68
zmeutz
My Ride: E46 330Ci
does anybody have 12 pins mirror connector with wires colors and numbers?
I saw in this thread some unfinished information...
Pin 1 - Driver Mirror (white wire)
Pin 2 - Driver Mirror (yellow wire)
Pin 3 - Fuse Box, position 57 for 12V
Pin 4 - ? Green
Pin 5 - Ground Black
Pin 6 - ? Gray
Pin 7 - Passenger Mirror (white wire)
Pin 8 - Passenger Mirror (yellow wire)
Pin 9 - ?
Pin 10 - ?
Pin 11 - Speed Sensor (Pin 21 of ABS Unit)
Pin 12 - To Pin 6 on driver mirror switch
I have 10 wires, on other forum I have find:
#3 Red
#4 Green
#5 Black
#6 Gray
but I don't have all colors )
Thanks!
zmeutz is offline   Reply With Quote
Old 09-04-2014, 02:23 PM   #69
Choffa
My Ride: BMW E46 325i Touring
I'm about to do this to my car.
How many of the contacts do I really need?
I'm asking about these two:
61130006663
61130006664
Choffa is offline   Reply With Quote
