Old 05-04-2007, 03:07 PM   #1
Timbo126
My Ride: 2004 330xi
Where to Mount Resistors
I just did a corner delete mod and i just installed the resistors to get rid of the lamp out light. But the resistors get extremely hot. Is there any place that would be safe to mount them? And what adhesive do you use to mount them?
Timbo126 is offline   Reply With Quote
Old 05-04-2007, 03:56 PM   #2
sstainba
My Ride: 02 325Ci
I mounted them to the outter side of the engine bay (not the inside of the painted fender). And i used 3m double sided foam tape. has worked just fine.
sstainba is offline   Reply With Quote
Old 05-04-2007, 07:57 PM   #3
sillieidiot
My Ride: '06 AW 330ci
you can put them just inside the bumper reinforcement bar. that's where i put resistors for my led corners
Old 05-05-2007, 09:05 AM   #4
Timbo126
My Ride: 2004 330xi
Wouldnt the 3m tape get to hot and loose its adhesive
Old 05-05-2007, 02:42 PM   #5
sstainba
My Ride: 02 325Ci
It's been there for nearly 2 years so far. I did try to take one of them off.... Even with the heat, it does not come off easily. I had to pry it off with a screwdriver.
