Old 06-17-2007, 02:54 AM   #61
Owtlaw333
My Ride: 2009 Mazdaspeed 3 GT
Well... of course since I was one of the first to call BS, I got hit with this problem I don't even have a large system - 500w amp with a 10w6v2.
I was driving down the road and all of a sudden my throttle got totally shut off. I would hit the gas and the car would just sputter below 1500rpms and barely move. I had stopped the car, restarted it, but it didn't help. It wasn't til after I restarted the car that my tranny failure light came on. I was able to drive the car perfectly fine though as long as I kept my RPMs below 3k. As soon as I would go over 3k, the throttle would cut off again. It was strange. But then I remembered this thread, popped my trunk open and disconnected my amp... lo and behold, problem solved. But I want my sub back!
Any update on that "upgrade"? Any idea what this "upgrade module" is and the part number and price?
I'm not too savvy on caps since I never thought I'd need one with a 500w system, but what would be sufficient. 1farad? And how hard is it to drain a cap? Like how quickly does one drain? What happens when it does?
Bringing it back for the new people...
productionof1.com
|||_Buy my photos?_|||
Owtlaw333 is offline   Reply With Quote
Old 06-17-2007, 02:48 PM   #62
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Wow mabey I know a thing or two about these cars??
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 06-17-2007, 03:50 PM   #63
shady3one3
Banned
shady3one3's Avatar
My Ride: gets replaced soon.
Send a message via AIM to shady3one3
this thread makes me laugh
that is all
shady3one3 is offline   Reply With Quote
Old 06-19-2007, 01:37 PM   #64
Owtlaw333
I don't think I ever said differently. I do believe I asked for help, not swagger.
productionof1.com
|||_Buy my photos?_|||
Old 06-19-2007, 03:05 PM   #65
jbeurotech
Regional Sponsor
LOL sorry I posted that on a bad day dealing with customers, I apolgize it was not aimed directly at you I got so many nasty PM's and stuff when i posted that info. I am not aware of any factory update at the current time.
Seth Thorson
Old 04-16-2009, 08:02 AM   #66
jbeurotech
Regional Sponsor
SI B 24 04 06
September 2006
Automatic Transmission
Technical Service
This Service Information bulletin supersedes S.I. B24 04 06 dated September 2006.
[NEW] designates changes to this revision
SUBJECT
ZF 5HP19 - Diagnosis of EGS FC 059 & 065
MODEL
[NEW] E46: 325i, 330i with M54, M56 and ZF 5HP19 up to 04/2004
E39: 525i, 530i with M54 and ZF 5HP19
E85: Z4 with M54 and ZF 5HP19 up to 04/2004
SITUATION
Transmission warning light is illuminated and transmission enters fail-safe mode.
Fault codes FC 059 (3B) "Stall speed plausibility", and/or FC 065 (41) "Gear monitoring 4, limp-home program" are stored in the EGS control module.
Also, the following ambient conditions are stored in EGS for the gear monitoring faults 065, or 059: l
- "Throttle valve angle 0%",
- "Battery voltage 0 V ".
IMPORTANT NOTE: If any other fault codes are stored in the EGS control unit in conjunction with FC 059 and/or 065, then contact BMW Technical Hotline/Drivetrain (via PuMA) for further assistance.
CAUSE
Possible causes: electromagnetic interference or voltage fluctuation in vehicle's electrical system affecting the transmission turbine speed signal.
Non-approved aftermarket electrical equipment, or loose/corroded connections in the electrical system are the main reasons for the electromagnetical interference.
PROCEDURE
1. NEW Inspect vehicle for presence of various, non-approved aftermarket electrical equipment. If such an equipment is installed, contact a customer and with his/her permission disconnect it (remove it) from the vehicle.
2. NEW In case a customer does not wish to remove aftermarket equipment which may be causing an electromagnetic interference, provide him/her with an option of installing a special EGS control module (step 5 of this procedure). This repair and diagnostic time would NOT be covered by BMW warranties (customer pays for parts and labor).
3. In case aftermarket equipment is not found, then inspect connections and repair if needed at:
- Battery terminals,
- Battery ground connection,
- Ground/B+ splices/connection in engine and body harness,
- Ground connection at the ignition secondary windings, etc.
4. Using DIS/GT1 check the DME fault memory to determine if there is any fault in the primary or secondary ignition. Correct if needed.
5. In case, no problem can be found in the vehicle's electrical or ignition systems, then install the improved EGS control module (PN 24 60 7 548 312) fitted with interference suppression capacitor. The improved control module can be recognized by the index number "002", or higher, printed on the white, Bosch label below the second bar code. Currently, all EGS control modules available for BMW PDCs are equipped with the interference suppression system.
6. Program and code the basic EGS control module.
Seth Thorson
