Old 05-10-2007, 02:14 PM   #1
Pward
My Ride: bmw 3
HID Kit
Hi I'm having an issue with my E46 325ci BMW and the vision bulbs HID kit. when I turn on the kit the drivers side window goes down? any idea what's causing this? bad ground?
do I need a new relay? or reflash LCM?
Phil
Visionbulbs
"That is a first. Seems that it's conflicting. Shouldn't need a flash.
Best thing to do is post this in the tech forum, and see what the guys say.
Let us know what you find out."
Does anyone know what i need to do?
Cheers
Phil
Pward is offline   Reply With Quote
Old 05-10-2007, 04:06 PM   #2
VisionBulbs
Past Site Sponsor
VisionBulbs's Avatar
My Ride: BMW Lighting Expert
Are you using the relay, or the standard connectors?
VisionBulbs is offline   Reply With Quote
Old 05-11-2007, 05:22 AM   #3
sillieidiot
My Ride: '06 AW 330ci
i really have never heard of this happen before. what happens if you uninstall the kit and then turn on your lights? maybe try resetting the car by taking one of the leads off the battery in the trunk.
Old 05-13-2007, 03:12 PM   #4
Pward
My Ride: bmw 3
"Are you using the relay, or the standard connectors?" I've tested both.. (Have the relay fitted at the moment) only the drivers side window drops for some stupid reason
"I really have never heard of this happen before. what happens if you uninstall the kit and then turn on your lights? maybe try resetting the car by taking one of the leads off the battery in the trunk."
Without the kit the window is fine, also been fine with original bulbs.
Going to ask BMW on Thursday, have 0% confidence they will fix it.
Also going to get the LSZ/LCM reflashed for Xenon bulbs I think not Bi-Xenon right?
Cheers
Phil
Old 05-14-2007, 04:17 AM   #5
sillieidiot
what year is your car? 02+ you have to flash for bixenons or it won't work.
Old 05-14-2007, 07:51 AM   #6
Pward
My Ride: bmw 3
The car is Feb 2003 so should be able to reprogram the LCM no problem, i hope.. ?????
So Thursday i should ask BMW to reflash for BiXenons? will main beem still work ok?
I have the lights connected via a separate relay wiring system? only the drivers side is connected to the system to switch the relay.
The reflash will stop the system detecting if the bulb has blown? just give 12v when i flick the switch?
Phil
Old 05-14-2007, 08:24 AM   #7
cabl3i
My Ride: 03 330i ZHP
this isnt gonna answer your quesiton..but about a year ago, when my brother was driving my car (yea they just gave me his car).....for about 2 months at around 6 am every day, the cars passenger window would lower itself......wierd....it just went away by itself....
cabl3i is offline   Reply With Quote
Old 05-14-2007, 02:56 PM   #8
sillieidiot
yea you will be able to flash no problem. flash for bixenons. your highs will only work for flash to pass. you can try to flash for xenons, there have been some instances where it was possible. but that's a dime in a dozen.
you don't need to connect the lights via relay. you can just connect it through the existing wiring.
it will still detect if a bulb has blown. it's just that the way it detects it changes. instead of sending out a signal for a filament. it waits to get feedback when you turn on the headlights instead. so when a bulb is blown, it'll still show up
Old 05-15-2007, 04:06 AM   #9
Pward
My Ride: bmw 3
Interesting, I'll ask them to try for Xenon's.. Still want my high beam to work the same
Starting to feel I'll never get this working, need the high beam.
Just praying that when they flash for Xenon's it works and stops the window going down….
I'll let you know
Thanks for your help
Phil
Old 05-17-2007, 08:30 AM   #10
Pward
My Ride: bmw 3
Hi,
Had my car LCZ reflashed for Xenon headlights & Led Rear lights, it worked hopefully everything will just work now.. I'll let you know next week
Got to finish off over the weekend.
Cheers
Phil
