Old 05-16-2007, 04:13 AM   #1
e46Freak
My Ride: Coupe
Send a message via Yahoo to e46Freak
Angel Eye Remote Wire
I'm trying to get the relay wire through the firewall to install Angel Eye remote. Where should I stick the wire through? The only two hole I see is in the picture. These hole are on the passenger side next to the ECU box.
e46Freak is offline   Reply With Quote
Old 05-16-2007, 04:41 AM   #2
iseedipp
My Ride: SMG II M3 and H2
Send a message via AIM to iseedipp
your ecu box is on the drivers side, i wired mine through my drivers side hole, there's a plastic part and then i tapped into my footwell light.
For Sale 2002 Topaz Blue Metallic Sequential Manual Gearbox M3 Coupe
CF front splitters|Gruppe M Ti exhaust|19" v715 Matte black with SS lip|Black out package|Phillips Ultinon 6k|6k Angel eyes|OEM LED tails|Pioneer Avic N2 and more
2003 White on Beige Hummer H2
33" toyo open country and dubs otherwise stock.
_________________
Coming soon
06 Yamaha R6
08 Jeep Grand Cherokee SRT-8
Myspace/vivaladipp
iseedipp is offline   Reply With Quote
Old 05-16-2007, 05:00 AM   #3
e46Freak
My Ride: Coupe
right...driver side...my mistake.
of those two hole which is the correct one?
The bottom looks like the most logical but has a hard piece of plastic covering it. I tried to pop it open with a screwdriver but it seems pretty solid.
Old 05-16-2007, 05:21 AM   #4
sillieidiot
My Ride: '06 AW 330ci
open the panel under your steering wheel. then you'll know which hole to choose.
Old 05-16-2007, 05:32 AM   #5
e46Freak
My Ride: Coupe
So it not either of those holes in the pic?
Old 05-16-2007, 08:16 AM   #6
KrisL
My Ride: 03 330i ZHP
Send a message via AIM to KrisL
I went through the passenger side - much less stuff on that side to deal with. You've got the big open hole under the hood, and you've got tons of room on the other side once you remove the glove box.
KrisL is offline   Reply With Quote
Old 05-16-2007, 09:27 AM   #7
CanUSayBimmy
My Ride: 323i
----- Clear Corners ----- Projector 46s ----- Predator 8000k Angel Eyes ----- Prolumen 8000k HID's ----- Kenwood DNX5140 ----- JL 500/1 Mono Amp ----- Image Dynamics IDQ 12 V3 Sub ----- ViS CF Hood ----- Dinan CF CAI -----
CanUSayBimmy is offline   Reply With Quote
Old 05-16-2007, 09:29 AM   #8
KrisL
and here's some pics of my install for ya:
Old 05-16-2007, 09:41 AM   #9
flyinj3x
flyinj3x's Avatar
My Ride: 03/03 330ci
Send a message via MSN to flyinj3x Send a message via Yahoo to flyinj3x
clean install kris. if i can ever get over the stigmata of opening up a perfectly good set of non-leaking head lamps and later cooking them again, ill follow your pics. nice job!
flyinj3x is offline   Reply With Quote
Old 05-16-2007, 09:58 AM   #10
ca1242
My Ride: 2003 330i
Passenger's side is easier, but if you want to go on the driver's side, first go into the ECU box. There is an open space between the ECU box and the inside of the car, so it is really easy to go in that way.
Old 05-16-2007, 10:03 AM   #11
KrisL
Thanks! Amazing what $4 in wire loom and a few small zip-ties can do to clean everything up. I actually ran the wiring for my LeatherZ Gauge Kit through the same loom. There's now a "T" just in front of the driver's side shock tower where the oil pressure/temp sensor wires split off and go down to the block.
Old 05-18-2007, 05:54 AM   #12
e46Freak
My Ride: Coupe
The wire loom makes it look oem....good job.
I think I will pick some up too. Thanks for the inspiration.
Old 05-18-2007, 06:01 AM   #13
e46Freak
My Ride: Coupe
Forgot to update the thread but I was able to find the hole in the ECU box by opening the driver side panel as you suggested.
I finished the install yesterday. Awesome feature. I had my angel eyes for almost too year but was too lazy to connect the remote wire. I didn't know what I was missing. Such a simple feature has a lot of cool and useful asthetics (finding your car at night). Glad I did it.
Thanks to everyone else for helping out.
Old 05-18-2007, 06:08 AM   #14
e46Freak
My Ride: Coupe
I had to go through the driver side since my kit was already pre-wired for the driver side.
This side was also really convienent for me since I was also putting in the Angel Eye switch which had to go in from this side. Killed two bird with one stone.
I like it better on this side also because it the ECU box covers my wire from sight.
Old 05-18-2007, 12:08 PM   #15
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
We usually find it easier to run it through the empty compartment on the passenger side and into the driver's footwell. Either way works though!
