Old 05-16-2007, 08:39 PM   #1
Kanaljen
My Ride: 2002 330i, Honda F4
Legal? But would look so much cleaner
Don't like the look of the ember corner lights being on when the head lights are on. But of course need them to signal turning...
So, thought about rewiring them so they are off when the head lights are on but turn on when I use the turn signal.
But, is it legal in sunny Cali?
02 330i, b-sapphire, L&S package, Tan/black leather, 18" M72, Tint, Sway bars, F & R strut braces, LTW flywheel, M5 clutch, 3.15 diff, Modded exhaust, SSK, U-drive pullies, Clear front corners, smoked tail and sides, stealth bulbs, B/W roundels, blacked-out emblem, trunk spoiler, Bi-xenon, angle eyes, HID fog lights, drilled Brembo, LTW battery, VDO gauges, Premium HK, extra amps & subs, ESS S/C, PS2 235,265, pss10, adj rear ctrl arms, IC coming
Kanaljen is offline   Reply With Quote
Old 05-16-2007, 10:47 PM   #2
BimmerZealot
My Ride: N/A
Parking lights, which are the turn signals dimly on when your headlights are on is required for all cars in US. You can do it by doing the "corner delete mod" do a quick search and you'll find it. Hope this helps.
BimmerZealot is offline   Reply With Quote
Old 05-16-2007, 10:58 PM   #3
tblue3cibm
My Ride: allroad / Hayabusa
the "corner delete mod" is your friend
tblue3cibm is offline   Reply With Quote
Old 05-16-2007, 11:02 PM   #4
jt330ci
My Ride: 2003 bmw 330ci
is it true that this mod messes up you LCM. thats what i have heard
-jt330ci
jt330ci is offline   Reply With Quote
Old 05-16-2007, 11:06 PM   #5
mycool
My Ride: needs rims 325i
i like corners they look nice pauls nub
bmw 325i 2001
|smoked corners|smoked side markers|Umnitza angel eyes 6k|benferCAI|xenon interior|
|xenon match fogs|chrome ambers|blackoutgrille|LED license plate lights|smoked tails|
CF emblems|cf gauge overlay| Gauge Rings|Projectors!|6k HID kit|CUSTOM CF eyelids
Project:CSL
mycool is offline   Reply With Quote
Old 05-17-2007, 11:30 AM   #6
Kanaljen
Great help, thank you!
Funny, I thought I came up with a cool way of doing something new... Should have known better; if it's possible, someone would have tried it!
I saw a question about screwing up some LCM?? What's that and what's the answer on that?
Old 05-17-2007, 03:58 PM   #7
BimmerZealot
My Ride: N/A
Well basically you are tapping your blinkers into your sidemarkers. So when the sidemarkers blink the blinkers blink with it. Because the sidemarkers are not on as parking lights your blinkers are no longer on as well. The resistor is wired across the original blinker wires so you dont get a bulb out warning on your dash.
As far as why it affects your LCM essentially you are pulling much more current through the part of the LCM that deals with the sidemarkers because now you are running sidemarkers and blinkers off that part of the circuit. There have been reports of that circuit going bad, so that is what people mean by damaging the LCM. Every LCM is different and everyone's luck is different.
However, a general consensus has been that if you use LED sidemarker bulbs and LED blinker bulbs you will be safe. The reason being that LEDs use a lot less power, thus the total power used by both is within a safe range to keep the LCM from frying.
Hope this helps
Old 05-17-2007, 04:56 PM   #8
Kanaljen
Cool..
I was planning on using a high resistant (coil ohm) relay anyway, to minmize the draw from the side markers... Maybe over-kill, but I don't want to fry something and pay serious $$ at the stealership to get it fixed.
Thanks for the info!
Old 05-17-2007, 06:04 PM   #9
NHskibm
My Ride: E46, E36, E30
check your state laws. Out here in NH the law says NO Blue and rears have to be yellow or red.
I run PIAA superswhite for my corners. Look pretty good with 6000k headlights...
Go to your state's DMV site and look for the law.
NHskibm is offline   Reply With Quote
Old 05-17-2007, 06:14 PM   #10
BMWPower06
BMWPower06's Avatar
My Ride: ///M5 & ///M3
Send a message via AIM to BMWPower06
Dont do it, YOUR LCM will get fried, its drawing too much power to power the front and fender signal, dont do it.
Current: E60 M5 6MT; E46 M3 6MT
Sold: E46 330CiA; E36 M3/2/5; E60 M5 SMG
DD: B8.5 Audi S4 6MT
BMWPower06 is offline   Reply With Quote
Old 05-17-2007, 06:39 PM   #11
jt330ci
Hope this helps
thanks for the info
-jt330ci
Old 05-17-2007, 10:35 PM   #12
Kanaljen
Just use a relay..
