Old 05-20-2007, 09:11 PM   #1
forzam
My Ride: 04 325Ci
HID: OEM vs. Kit
Hello,
I want to upgrade my halogen headlamps on my 2004 325Ci to HID. Does anyone know if the halogen projectors/housing units are the same as the Xenon? The reason I ask is that I am concerned about using a HID kit in my current "halogen projectors." I don't want to create glare and I want the best results possible.
Two complete OEM HID headlamp units cost about $1300, while the HID Kit for both sides is $260.
forzam is offline   Reply With Quote
Old 05-20-2007, 09:40 PM   #2
curious_george
My Ride: '02 325i ZSP
No - they are not the same (halogens do not use projectors on the E46). I think the best route would be the P46 units - they are all-in-one replacements. Those kits you speak of will produce glare and not light the road correctly. The P46 units are cheaper than the factory units, but still more expensive than these "kits". This is not a place for a cheap solution though.
curious_george is offline   Reply With Quote
Old 05-20-2007, 10:23 PM   #3
forzam
My Ride: 04 325Ci
I am fairly certain I have projectors now with H7 halogen bulbs. There is clearly a lense for the low beams, yet a reflector for the high beams. On the headlamp unit, it also says H7 or D2S.
I just want to be sure that the housing is the same one if the car were originally built with HID Xenons (not adaptive).
Old 05-20-2007, 10:36 PM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Facelift coupes have projectors whether you have halogens or xenons. All you need is one of our HID Kits that you can retrofit into your stock housings. You have a couple of options, our premium ProLumen HID kit or our more affordable Piccolo HID kit, both would be H7.
ProLumen HID Kit
Piccolo HID Kit
Old 05-20-2007, 10:40 PM   #5
forzam
My Ride: 04 325Ci
But is the lense, the alignment, and everything else for the stock halogens the same that would be used if the car were OEM equiped with xenons? Are there "halogen projectors" vs. xenon projectors?
Old 05-20-2007, 11:28 PM   #6
curious_george
ProLumen HID Kit
Piccolo HID Kit
ah...forgot about the facelifted coupes!
Old 05-20-2007, 11:57 PM   #7
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
The housings are different but you can still run an HID kit in the halogen projector. It is not like running an HID kit in reflector based halogen housings, the projectors provide enough of a cut off to prevent glare as long as you aim them correctly.
Old 05-21-2007, 04:00 AM   #8
robin325ci
My Ride: Helrot 325Ci
we installed HIDs on my brother's mazda3 which comes stock with halogen bulbs on projectors. the beam pattern was excellent, and the cutoff was sharp. and no, they don't glare oncoming traffic
robin325ci is offline   Reply With Quote
